    Update is not working..I need help please
    41 Posts 5 Posters 19.1k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      i am on a Mac mini
      i have done git pull and npm install not working
      i have tried a new installation not working
      Last login: Sat Oct  7 15:16:11 on console
      patrickhahn@Mac-mini ~ % cd MagicMirror
      patrickhahn@Mac-mini MagicMirror % npm start
      evalmachine.<anonymous>:45
      } = primordials;
      ReferenceError: primordials is not defined
          at evalmachine.<anonymous>:45:5
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
          at Module._compile (internal/modules/cjs/loader.js:1085:14)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          at Module.load (internal/modules/cjs/loader.js:950:32)
          at Function.Module._load (internal/modules/cjs/loader.js:790:14)
          at Module.require (internal/modules/cjs/loader.js:974:19)
          at require (internal/modules/cjs/helpers.js:92:18)
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      I hope someone can help …thanks
        Stoffbeuteluwe Project Sponsor @sdetweil
        the solution is to change the line 11 an 12 of calendarfetcher.js to this …
        /*const fetch = require("fetch");*/
        /*const digest = require("digest-fetch");*/
        now it works :folded_hands: :smiling_face_with_sunglasses:
        S 1 Reply Last reply Reply Quote 2
          Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
          now I have installed node
          after git pull and npm install it shows this …
          > magicmirror@2.25.0 start
          [07.10.2023 16:44.38.170] [LOG]   Starting MagicMirror: v2.25.0
          [07.10.2023 16:44.38.171] [LOG]   Loading config ...
          [07.10.2023 16:44.38.171] [DEBUG] config template file not exists, no envsubst
          [07.10.2023 16:44.38.172] [LOG]   Loading module helpers ...
          [07.10.2023 16:44.38.172] [LOG]   No helper found for module: alert.
          [07.10.2023 16:44.38.200] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.200] [LOG]   Module helper loaded: MMM-Remote-Control
          [07.10.2023 16:44.38.201] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.201] [LOG]   Module helper loaded: updatenotification
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: MMM-Snow.
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: MMM-MyWordClock.
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: clock.
          [07.10.2023 16:44.38.203] [LOG]   No helper found for module: calendar_monthly.
          [07.10.2023 16:44.38.222] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.222] [LOG]   Module helper loaded: calendar
          [07.10.2023 16:44.38.223] [ERROR] (node:28140) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
          Require stack:
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
          - /Users/patrickhahn/MM/js/app.js
          - /Users/patrickhahn/MM/js/electron.js
          - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
              at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
          (Use `Electron --trace-warnings ...` to show where the warning was created)
          [07.10.2023 16:44.38.223] [ERROR] (node:28140) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          2023-10-07 16:44:38.247 Electron[28140:158548] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe your version of node is not good enough You need either 18 or 20
            node -v
            will tell you
              sil3ntstorm @sdetweil
              I don’t have version 20 either but rather 16.14.2. How can I install version 20? Can you please help me?
                sdetweil @sil3ntstorm
                @sil3ntstorm you can try the node20_install script
                or you can try with upgrading mm using my upgrade script
                S StoffbeuteluweS 2 Replies Last reply Reply Quote 1
                  @sdetweil I installed it, thanks
                    @sdetweil Hi thanks for answering, the problem was 3 modules
                    the module
                    MMM-DWD-WarnWeather
                    MMM-Snake
                    MMM-MyCalendar
                    without the modules it works fine and with the modules it doesn’t work and I don’t know wy???
                    anybody an idea??
                    S S 2 Replies Last reply Reply Quote 0
                      @Stoffbeuteluwe it’s this
                      we removed node-fetch
                      I think
                      MMM-DWD-WarnWeather
                      put out a fix
                      git pull in that module folder and npm install
                        sil3ntstorm @Stoffbeuteluwe
                        @Stoffbeuteluwe Did you just deactivate the 3 modules in config.js, or did you also delete the 3 folders in the Modules folder? Did you have to do anything else to make it work?
                        S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                          @sil3ntstorm we removed some libraries in this release that modules use but don’t document So you have to fix the modules manually by installing the missing libraries.
                          I posted a link to the troubleshooting Post that shows you how to find the library and what to do about it
                            Stoffbeuteluwe Project Sponsor @sil3ntstorm
                            @sil3ntstorm I only deleted the module folder…
                              thanks DWD-Warnweather is fine
                              I can’t get MMM-MyCalendar to work, I’ve tried everything but unfortunately it doesn’t work.
                              As soon as the module folder (MMM-MyCalendar) is in the modules folder it doesn’t work…
                              Unfortunately I don’t know what to do next, sorry
                                sdetweil
                                @Stoffbeuteluwe show the output of the npm start
                                best way
                                pm2 stop all
                                cd ~/MagicMirror
                                npm start >somefile.txt 2>&1
                                wait 20 seconds
                                ctrl -c in the window for the above commands
                                then edit somefile.txt
                                and search for
                                Cannot find module
                                then next few lines will tell you which mmm module is affected
                                  [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
                                  [09.10.2023 21:11.47.231] [LOG]   Loading config ...
                                  [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
                                  [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
                                  [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
                                  [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
                                  [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
                                  [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
                                  [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
                                  [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
                                  [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
                                  [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
                                  [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
                                  [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
                                  [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
                                  [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                                  Require stack:
                                  [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                  2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                  /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                                    @Stoffbeuteluwe said in Update is not working..I need help please:
                                    Cannot find module ‘fetch’
                                    yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
                                    BUT fetch is provided in the base node 18 and 20… SO
                                    edit the
                                    and comment out the line (11) , by adding // to the start of the line
                                      i have done this
                                      /* MagicMirror²
                                       * Node Helper: Calendar - CalendarFetcher
                                       * By Michael Teeuw https://michaelteeuw.nl
                                       * MIT Licensed.
                                      const CalendarUtils = require("./calendarutils");
                                      const Log = require("logger");
                                      const NodeHelper = require("node_helper");
                                      const ical = require("node-ical");
                                      //const fetch = require("fetch");
                                      const https = require("https");
                                       * @param {string} url The url of the calendar to fetch
                                       * @param {number} reloadInterval Time in ms the calendar is fetched again
                                       * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
                                       * @param {number} maximumEntries The maximum number of events fetched.
                                       * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
                                       * @param {object} auth The object containing options for authentication against the calendar.
                                       * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
                                       * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
                                       * @class
                                      but it still does not work
                                        @Stoffbeuteluwe you are on the wrong level of code
                                        neither are there in 2.25
                                        do
                                        cd ~/MagicMirror
                                        git checkout modules/default/calendar/calendarfetcher.js
                                        then
                                        git status
                                        show the results
                                        karsten13K StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                        • karsten13K Online
                                          karsten13 @sdetweil
                                          MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
                                            @sdetweil said in Update is not working..I need help please:
                                            git status
                                            patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
                                            Updated 0 paths from the index
                                            patrickhahn@Mac-mini MM % git status
                                            On branch master
                                            Your branch is up to date with 'origin/master'.
                                            Untracked files:
                                              (use "git add <file>..." to include in what will be committed)
                                            	css/icons/
                                            	new_package.json
                                            	run-start.sh
                                            nothing added to commit but untracked files present (use "git add" to track)
                                              @Stoffbeuteluwe ok, now do
                                              cd ~/MagicMirror
                                              git pull
                                              npm run install-mm
                                              • 1 / 3
