    Netatmo module
    10 Posts 5 Posters 7.3k Views 4 Watching
    • zdenekZ Offline
      zdenek
      Hi all
      I´m newbie, I´m trying to get running Netatmo module. What I´ve did:
      • installed latest Magic Mirror
      • installed latest upates and upgrades
      • customized default modules
        Until now everything OK
      followed https://github.com/CFenner/MagicMirror-Netatmo-Module
      • get from github
      • registered new app on Netatmi API, get ClientID and Client secret
      • sent POST request to Hurl.it, got valid response with “access_token” and “refresh_token”
      • CTRL+C & CTRL+V entered Module section to .js including ID, Secret and Refresh_token
      After run Magic mirror I´ve got black screen with yellow sign in top-right corner.
      any idea, what´s wrong? or how to verify, settings?
      thanks for help
      Zdenek
      • yawnsY Offline
        yawns Moderator
        I know the readme does not state it, but usually a black screen after installing a new module means dependencies are missing.
        Please open a terminal
        cd ~/MagicMirror/modules/MagicMirror-Netatmo-Module
        npm install
        Then try to re run your magic mirror.
        • zdenekZ Offline
          zdenek
          I did, thanks. In my case the path is different
          cd ~/MagicMirror/netatmo
          the command took about a 2 mins, I did restart Raspberry, run Magic - still the same. There is no error during starting Magic, last row is Launching application
          disabling module in configure.js (by //) make Magic working properly
          BR, Zdenek
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @zdenek
            @zdenek you have to install modules in the path ~/MagicMirror/modules as yawns mentioned, otherwise the system cant find the module
            zdenekZ 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator
              Yes, my mistake, folder netatmo is correct, but it needs to be in modules
              Could you please start your mirror with npm start dev, open the console in your browser by pressing F12 and check for any errors there?
              • zdenekZ Offline
                zdenek @strawberry 3.141
                @strawberry-3.141 seems to be right. By running @yawns command I can see that there is row src=“modules/netatmo//netatmo.js”
                with error 404
                may I simply copy/paste to modules folder? Or have tu run again from github? and the command will be:
                git clone https://github.com/CFenner/MagicMirror-Netatmo-Module.git modules/netatmo
                Zdenek
                P.S.: simple copy/paste works. Thanks guys
                • K Offline
                  Kai-Christoph
                  @zdenek
                  Hi Zdenek,
                  I just installed the Netatmo-Module, but I can’t get the “refresh_token” vial Hurl-it.
                  I always get an “400 Bad Request”.
                  Where ist the trick?
                  Maybe it’s because I don’t know what the “gant_type” “password” is supposed to be?
                  Thank you for your help.
                  KC
                  • zdenekZ Offline
                    zdenek @Kai-Christoph
                    @Kai-Christoph To be honest, I´m newbie. I just followed the instructions. 1st - registered app and get appID and appSecret. Than insert URL to Hurl-It and add all mentioned parameters.
                    “gant_type” - it´s I guess typo - should be ““grant_type””
                    And it´s not a variable. The name of the parameter is ““grant_type”” and the Value is “password” - I guess, it´s a definition, that authentication will be done via username+password (probably there are other way - certificate? PIN? don´t know)
                    BR, Zdeněk
                    • K Offline
                      Kai-Christoph @zdenek
                      @zdenek Hihihihihi! The missing “r” was the key! Thanks for your hint!
                      Cheers
                      KC
                      • ? Offline
                        A Former User
                        Sorry for late Reply on this old Thread, buuuut…
                        I got everything installed very quick and get it started. But its loading and loading and loading…i dont get any Information from my Netatmo Station…i started it also with “dev” and got no errors or anything else…
                        What i’ve done wrong?
                        Refresh Token? I used the Login credentials from my dev account, maybe thats my mistake?
                        Thanks for your help
                        PS: How to use moduleOrder? I dont know how to use/insert into config ;) (Newbie)
