    Calendar shows incorrect time for a single changed event in a series
    9 Posts 4 Posters 2.0k Views 4 Watching
    • H Offline
      Hinge
      we use a Google calendar for the MM². My wife and I use this calendar on our cell phones and on the standard calendar at MM².
      I changed a single event in a series from 4:30 p.m. to 4:00 p.m. My wife sees it correctly. It appears correctly online on Google. But the MM² made it 5 p.m.
      The series of appointments was created in summer, when summer time was in force in Germany. All other dates in the series are displayed correctly (4:30 p.m.) regardless of summer or winter time. The appointments on Google have Berlin stored as the time zone.
      Is there something I need to change in the config or is this a previously unknown problem?
      THX a lot!!!
        sdetweil @gelaw
        @gelaw do
        cd ~/MagicMirror
         npm install node-ical@0.16.1
          sdetweil @Hinge
          @Hinge oh the joy. the library that processes recurring events and moved, has a bug. it’s not ours. I have spent months looking for a fix, none yet.
          KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @sdetweil
            @sdetweil Just out of curiosity: Is the library moment.js?
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO no, rrule
              it expects only local date/times
              node-ical converts all to utc based times…
              so we get some events that have todays date with tomorrows UTC time… Nov 6 -01:30 UTC -8
              for LosAngeles that makes the event date yesterday… Nov 5- 17:30… oops…
              but we in MM don’t ever look at the text in the ICS, so we have NO way of knowing of the mishmash date/time… and it seems to happen MOST with ByDay (only on thrusday or friday) …
              AND EVEN if we DID look at the ICS, we wouldn’t see this, as its a recurring date event, calculated by RRULE. from start and the rules… so unless WE recode RRULE, we would never ever know
                sdetweil @Hinge
                @Hinge @KristjanESPERANTO node-ical has just release a new version (0.17.0) which removes the luxon library which causes all the localdate/time issues…
                want to give it a try ? do
                cd ~/MagicMirror
                npm install node-ical@latest
                then start mm as usual
                • G Offline
                  gelaw @sdetweil
                  @sdetweil said in Calendar shows incorrect time for a single changed event in a series:
                  cd ~/MagicMirror
                  I have the same problem.
                  Did this fix work?
                    sdetweil @gelaw
                    @gelaw do
                    cd ~/MagicMirror
                    • G Offline
                      gelaw @sdetweil
                      @sdetweil Thanks!
                      This worked in my first tests. Is this now the official version? or still in work?
                        sdetweil @gelaw
                        @gelaw this is the version from prior release…
                        we’ll see what happens by April 1.(next mm release)
