    Modifying the Config File
    101 Posts 7 Posters 174.0k Views 7 Watching
      jimb
      Sam, from the Pi I can use the browser to get to the Internet so it has an IP address. I can ping Google from it, too. At this point I think the best thing would be for me to start over with a fresh installation. I don’t want to be a PITA here!
        sdetweil @jimb
        @jimb not a PITA. just odd that ip addr didn’t give u all adapters info
        • bheplerB Offline
          bhepler Module Developer @jimb
          @jimb said in Modifying the Config File:
          IP Config from the OS prompt on the Pi yields -
          “Link/loopback 'all zeros…”
          “inet 127.0.0.0/8 scope host lo”
          This should be the first entry of three in the response when you enter ip addr. The next entry should be your ethernet port, and the final entry should be your wireless LAN. My suggestion is to try this on your pi: ip addr | grep inet
          Secondly, when Sam told you to switch on SSH, did you go into the config app and do it? You can get to it from the desktop but the fastest way is to type sudo raspi-config and then navigate to “Interface Options”->“SSH”. Make sure it is enabled.
            jimb
            Gents, my goal was not to build a watch, only to tell the time. I have bit the bullet and will be building a new image of the OS and setting it up to run from my PC. That way I’ll be able to copy configs for all to peruse, trying to get Magic Mirror up and running. Thanks for your continued support!
              jimb
              Sam, et all: I have installed a fresh copy of the OS to a new SD card , booted up the Pi, and installed a new copy of the MM2 files, etc. from Sam’s installation script. The only mistake I made was making the MM auto-install. I attempted SSH into the Pi to modify the config on my PC. Had the same “no connnection” issue I had before. However, I now have the IP address of the Pi and I’m not able to ping it from my PC. When the Pi boots this IP address is displayed in the upper right corner for a few seconds so I know it’s correct. An IP config /all display shows-
              C:\Users\Owner>ipconfig /all
              Windows IP Configuration
              Host Name . . . . . . . . . . . . : DESKTOP-LE5LUCM
              Primary Dns Suffix . . . . . . . :
              Node Type . . . . . . . . . . . . : Hybrid
              IP Routing Enabled. . . . . . . . : No
              WINS Proxy Enabled. . . . . . . . : No
              DNS Suffix Search List. . . . . . : attlocal.net
              Ethernet adapter Ethernet:
              Connection-specific DNS Suffix . : attlocal.net
              Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
              Physical Address. . . . . . . . . : 78-E7-D1-C8-69-02
              DHCP Enabled. . . . . . . . . . . : Yes
              Autoconfiguration Enabled . . . . : Yes
              IPv6 Address. . . . . . . . . . . : 2600:1700:d10:2900::681(Preferred)
              Lease Obtained. . . . . . . . . . : Wednesday, November 29, 2023 1:44:08 AM
              Lease Expires . . . . . . . . . . : Thursday, December 28, 2023 6:10:32 PM
              IPv6 Address. . . . . . . . . . . : 2600:1700:d10:2900:17cb:6c66:31f8:87bb(Preferred)
              Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:3974:7e8b:2c4:8999(Preferred)
              Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:e81f:6b5c:4ac6:b88d(Deprecated)
              Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:f895:4134:2f63:7933(Deprecated)
              Link-local IPv6 Address . . . . . : fe80::3b70:ff2e:ecd1:4297%12(Preferred)
              IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
              Subnet Mask . . . . . . . . . . . : 255.255.255.0
              Lease Obtained. . . . . . . . . . : Wednesday, November 29, 2023 1:44:03 AM
              Lease Expires . . . . . . . . . . : Saturday, December 2, 2023 1:44:06 PM
              Default Gateway . . . . . . . . . : fe80::3a3b:c8ff:fe33:13d9%12
              192.168.1.254
              DHCP Server . . . . . . . . . . . : 192.168.1.254
              DHCPv6 IAID . . . . . . . . . . . : 158918609
              DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-B7-F6-59-78-E7-D1-C8-69-02
              DNS Servers . . . . . . . . . . . : 2600:1700:d10:2900::1
              192.168.1.254
              NetBIOS over Tcpip. . . . . . . . : Enabled
              Wireless LAN adapter Wi-Fi:
              Media State . . . . . . . . . . . : Media disconnected
              Description . . . . . . . . . . . : 802.11n Wireless LAN Card
              Physical Address. . . . . . . . . : 68-A3-C4-EA-95-83
              Wireless LAN adapter Local Area Connection* 1:
              Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
              Physical Address. . . . . . . . . : 68-A3-C4-EA-95-85
              Wireless LAN adapter Local Area Connection* 2:
              Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
              Physical Address. . . . . . . . . : 68-A3-C4-EA-95-86
              DHCP Enabled. . . . . . . . . . . : No
              Wireless LAN adapter Local Area Connection* 11:
              Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
              Physical Address. . . . . . . . . : 68-A3-C4-EA-95-84
              C:\Users\Owner>
              Does anyone see anything weird?
              BKeyportB S 2 Replies Last reply Reply Quote 0
              • BKeyportB Offline
                BKeyport Module Developer @jimb
                @jimb that appears to be your windows computer, not the pi.
                  sdetweil @jimb
                  u mean auto start??? install was my script
                  ssh doesn’t work unless you enable it on the pi
                  desktop, menu top left,
                  preferences
                  raspberry pi configuration
                  then the itnerfaces tab, click the slide on the ssh row,
                  then press ok…
                  if latest os, then you don’t have to boot
                  open a terminal window on pi
                  type
                  ip addr
                  you should see like this
                  pi@raspberrypi4:~ $ ip addr
                  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                      inet 127.0.0.1/8 scope host lo
                         valid_lft forever preferred_lft forever
                      inet6 ::1/128 scope host
                  2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                      link/ether dc:a6:32:20:b0:94 brd ff:ff:ff:ff:ff:ff
                      inet 192.168.2.44/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
                         valid_lft 50521sec preferred_lft 36219sec
                      inet6 fe80::a5a6:f1d1:50e7:1c5/64 scope link
                  3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                      link/ether dc:a6:32:20:b0:95 brd ff:ff:ff:ff:ff:ff
                  in this setup my wifi (wlan0) is not connected but my ethernet (eth0) is
                     inet 192.168.2.44
                  doesn’t matter what the PC says…
                  do you have a guest network at home and did u connect the pi to that?
                  can’t connect to it from home network if so… intentional firewall…
                    jimb
                    Sam, the Pi is connected via wireless. Yes, I meant autorun on my first post. I did change the Pi configuration to allow SSH. I have Eero mesh AP’s connected to my home network. I don’t know how to check if access is being blocked to the Pi. Since everything is fresh on the install it makes sense that the network is the culprit. The reason I went with a new install was to enable pasting config, etc. files here on the forum.
                      sdetweil @jimb
                      @jimb i understand… if you can use a terminal window on the pi, can you ping xxxx, where xxxx is the hostname or ip address of the windows pc?
                      what is the output of ip addr ?
                      i know it stinks, but you can post a pic, third icon from the right above the forum post editor
                        @jimb I’d also suggest trying my MMM-Config module, which presents a form for config.js including outside modules… all done with discovery of the installed modules and there parms…
                        some modules cause trouble… but there are ways around with some extra work… it may not be for you… another pile of work to learn, it it doesn’t work…
                        https://github.com/sdetweil/MMM-Config
                        it doesn’t help with module install, only configure
                          jimb
                          Sam,
                          OK progress on the network front. I spent some time yesterday on the phone with eero tech support. At rhe end they suggested connecting my PC wirelessly and seeing if I could ping the rasberry. It works. I can ping and SSH/Putty into the pi, but have an additional snag. It accepts the login and sends a password request. BUT, I can’t enter anything- the keyboard is dead at that point.
                            sdetweil @jimb
                            @jimb ok, sounds like the wifi network is a guest, not connected to the regular ethernet network…
                            don’t use putty
                            open a cmd.exe window
                            ssh user_name@machine_ip
                            add one of the tools
                            winscp or bitvise ssh clients
                            they will give you a filemanager view of the files and an ssh window ,
                            per system you connect to…
                            bitvise also provides a filemanager view of the pc filesystem , so you can drag/drop files in either direction… (you would only do that for logs to pc, of special bug fix file , to pi)
                              jimb
                              Sam, success! I have d/l’d the SSH gui program and here is my config.js file. I have deleted my apiKey
                              			module: "alert",
                              			module: "updatenotification",
                              			position: "top_bar"
                              			module: "clock",
                              			position: "top_left"
                              			header: "US Holidays",
                              						symbol: "calendar-check",
                              						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                              			module: "compliments",
                              			position: "lower_third"
                              			module: "weather",
                              				apiVersion: "3.0",
                              				lat: 33.50872,
                              				lon: -96.612213,
                              				weatherEndpoint: "/onecall",
                              				type: "current",
                              				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                              				apiKey: "8eca2aec"
                              			module: "weather",
                              			header: "Weather Forecast",
                              				apiVersion: "3.0",
                              				lat: 33.50872,
                              				lon: -96.612213,
                              				type: "forecast",
                              				apiKey: "8
                              			module: "newsfeed",
                              			position: "bottom_bar",
                              				feeds: [
                              						title: "New York Times",
                                sdetweil @jimb
                                @jimb missing some at the bottom
                                I assume the apikey with a new line inside is a removal edit problem
                                always wrap config.js content in code block
                                paste into editor
                                blank line above and below
                                select pasted text
                                hit button </>
                                  jimb
                                  Sam, here is a copy of the config.js (with the apiKey deleted)
                                  let config = {
                                  	address: "localhost",	// Address to listen on, can be:
                                  	port: 8080,
                                  	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                                  	language: "en",
                                  	locale: "en-US",
                                  	timeFormat: 12,
                                  	units: "imperial",
                                  			module: "alert",
                                  			position: "top_bar"
                                  			module: "clock",
                                  			timezone: "America/Chicago",
                                  			showPeriodUpper: "true",
                                  			showDate: "true",
                                  			module: "weather",
                                  			units: "imperial",
                                  			windUnits: "imperial",
                                  			tempUnits: "imperial",
                                  			appendLocationNameToHeader: "true",
                                  			colored: "true",
                                  				apiVersion:"3.0",
                                  				weatherEndpoint:"/onecall",
                                  				lat: "33.50872",
                                  				lon: "-96.612213",
                                  				type: "current",
                                  				apiKey: "8acfbcab123ce212",
                                  			module: "weather",
                                  			units: "imperial",
                                  			winUnits: "imperial",
                                  			appendLocationNaneToHeader: "true",
                                  			colored: "true",
                                   				apiVersion:"3.0",
                                  				lat: "33.50872",
                                   				lon:"-96.612213",
                                   				type: "forecast",
                                  					apiKey: "8eca2acaacfbcab123ce212",
                                  			module: "newsfeed",
                                  				feeds: [
                                  						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                  				showSourceTitle: true,
                                  				showPublishDate: true,
                                  				broadcastNewsFeeds: true,
                                  				broadcastNewsUpdates: true
                                    jimb
                                    Sam, I tried to do the Ctrl-Shift_i keypress in the browser, but nothing happened. Do I need to do this at a certain point in time or from a certain place. The reason is because I’m still getting the 401-unauthorized messages if I perform the npm start dev process during application start.
                                    S 3 Replies Last reply Reply Quote 0
                                      sdetweil @jimb
                                      @jimb weird… always works for me.
                                      I meant to test w my apikeys today.
                                      will get to it
                                        sdetweil @jimb
                                        @jimb well, I used your exact weather config, and used my openweather api key , and it worked perfectly
                                          sdetweil @jimb
                                          @jimb and you’ve got some stuff out of position
                                          this is the more correct layout
        module: "weather",
        config:{
        units: "imperial",
        colored: "true",
                                                  //              position: "top_right",
                                                  //              config: {
        apiVersion:"3.0",
        lat: "29.8155405", //"33.50872",
        lon: "-96.0607878", //"-96.61",
        type: "current",
        //location: "Houston",
        //locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and fi>
        apiKey:""
                                            GNU nano 6.2                                                       config/config.js
        module: "weather",
        position:"top_right",
        config:{
        units: "imperial",
        colored: "true",
        //position: "top_right",
        //header: "Weather Forecast",
        //config: {
        apiVersion:"3.0",
        lat: "33.50872",
        lon:"-96.612213",
        type: "forecast",
        apiKey:"// "
                                            jimb
                                            Sam, that’s helpful, thanks! The items out of alignment happened when I deleted some of my apiKey. The original is perfectly straight. Since it worked with your Key, a couple of questions.
                                            1. Does your Key have 28 digits?
                                            2. Can you answer my question concerning the Ctrl-Shift-i keys to display the browser data. Can I stop the MM app and load the browser, or…
                                              JimB
                                            • 6
                                            • 4 / 6
