    Calendar not updating
    95 Posts 4 Posters 95.3k Views 6 Watching
    • M
      matt216
      Hi all,
      I’ve read a few of the search results on this. Struggling with my calendar not updating. It loads, just doesn’t update with new events. Feels like it’s done just the initial sync/load of events but won’t include any subsequent events added.
      pm2 restart or even a pi reboot doesn’t resolve.
      Calendar config:
      header: "calendar",
      		fetchInterval: 120000,
      		timeFormat: 'absolute',
      				url: 'https://my.cal.url/dav.php/calendars/user/default?export',
      					auth: 	{
      							user: 'user',
      							pass: 'pass',
      							method: 'basic'
      		maximumEntries: 5
      Baikal container hosted locally, if that’s any help.
      Possibly a caching issue…?
      Cheers,
      matt
        sdetweil @matt216
        @matt216 well, you.only have 2 minute refresh, so how do you know? is the calendar changing every 2 minutes?
        and u only have 5 entries
        • M
          matt216
          Hi Sam. My test is to add a new event that would show up within the next 5 events i.e. in a couple of hours time. My expectation is that the mirror would refresh the events it displays every 2 minutes and my new event should show up. Not happening.
            sdetweil @matt216
            @matt216 show me the output where you do npm start
            M 1 Reply Last reply
            • M
              matt216 @sdetweil
              pi@magicmirror:~ $ npm start
              npm ERR! code ENOENT
              npm ERR! syscall open
              npm ERR! path /home/pi/package.json
              npm ERR! errno -2
              npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/pi/package.json'
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
              Appreciate the support
                sdetweil @matt216
                @matt216 said in Calendar not updating:
                you need to be IN the MagicMirrror folder
                cd MagicMirror
                npm start
                • M
                  matt216 @sdetweil
                  @sdetweil Thank you!
                  pi@magicmirror:~/MagicMirror $ npm start
                  > magicmirror@2.26.0 start
                  sh: 1: ./node_modules/.bin/electron: not found
                    sdetweil @matt216
                    @matt216 weird
                    cd ~/MagicMirror
                    npm install electron@27.2.0
                    then
                    npm start
                    again
                    M 2 Replies Last reply
                    • M
                      matt216 @sdetweil
                      @sdetweil yep in between my previous 2 posts I thought I’d upgrade MagicMirror and it now won’t load with electron error.
                      Will install and get back to you.
                      • M
                        matt216 @sdetweil
                        @sdetweil ok it’s a big one…
                        [01.01.2024 20:09.38.801] [LOG]   Starting MagicMirror: v2.26.0
                        [01.01.2024 20:09.38.814] [LOG]   Loading config ...
                        [01.01.2024 20:09.38.823] [DEBUG] config template file not exists, no envsubst
                        [01.01.2024 20:09.38.834] [LOG]   Loading module helpers ...
                        [01.01.2024 20:09.38.840] [LOG]   No helper found for module: alert.
                        [01.01.2024 20:09.38.947] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.38.949] [LOG]   Module helper loaded: updatenotification
                        [01.01.2024 20:09.38.951] [LOG]   No helper found for module: clock.
                        [01.01.2024 20:09.39.477] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.39.480] [LOG]   Module helper loaded: calendar
                        [01.01.2024 20:09.40.633] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.40.636] [LOG]   Module helper loaded: MMM-UKNationalRail
                        [01.01.2024 20:09.41.573] [LOG]   Module helper loaded: MMM-Sonos
                        [01.01.2024 20:09.41.575] [LOG]   No helper found for module: weather.
                        [01.01.2024 20:09.41.585] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.41.587] [LOG]   Module helper loaded: MMM-MoonPhase
                        [01.01.2024 20:09.42.084] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.42.085] [LOG]   Module helper loaded: newsfeed
                        [01.01.2024 20:09.42.088] [LOG]   No helper found for module: MMM-WiFiPassword.
                        [01.01.2024 20:09.43.354] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.43.355] [LOG]   Module helper loaded: MMM-MyCommute
                        [01.01.2024 20:09.43.357] [LOG]   No helper found for module: MMM-EyeCandy.
                        [01.01.2024 20:09.43.469] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.43.469] [LOG]   Module helper loaded: mmm-hue-lights
                        [01.01.2024 20:09.44.432] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.44.433] [LOG]   Module helper loaded: MMM-HASS
                        [01.01.2024 20:09.44.439] [LOG]   Initializing new module helper ...
                        [01.01.2024 20:09.44.440] [LOG]   Check MagicMirror² version for node helper 'MMM-ip' - Minimum version: 2.15.0 - Current version: 2.26.0
                        [01.01.2024 20:09.44.443] [LOG]   Version is ok!
                        [01.01.2024 20:09.44.444] [LOG]   Module helper loaded: MMM-ip
                        [01.01.2024 20:09.44.445] [LOG]   All module helpers loaded.
                        [01.01.2024 20:09.44.466] [LOG]   Starting server on port 8080 ...
                        [01.01.2024 20:09.44.489] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [01.01.2024 20:09.44.518] [ERROR] Whoops! There was an uncaught exception...
                        [01.01.2024 20:09.44.521] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                            at Server.setupListenHandle [as _listen2] (node:net:1751:16)
                            at listenInCluster (node:net:1799:12)
                            at doListen (node:net:1948:7)
                            at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                          code: 'EADDRINUSE',
                          errno: -98,
                          syscall: 'listen',
                          address: '0.0.0.0',
                          port: 8080
                        [01.01.2024 20:09.44.522] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [01.01.2024 20:09.44.523] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        Warning: vkCreateInstance: Found no drivers!
                        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                            at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                            at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                            at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                            at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                            at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                          sdetweil @matt216
                          @matt216 pm2 stop all
                          then npm start again
                          no idea on the Vulcan driver issue…
                          what os are u running on what hardware…
                          uname -a
                          lsb_release -a
                          • A avano referenced this topic on
                          • M
                            matt216 @sdetweil
                            pi@magicmirror:~ $ uname -a
                            Linux magicmirror 6.1.21-v7+ #1642 SMP Mon Apr  3 17:20:52 BST 2023 armv7l GNU/Linux
                            pi@magicmirror:~ $ lsb_release -a
                            No LSB modules are available.
                            Distributor ID:	Raspbian
                            Description:	Raspbian GNU/Linux 11 (bullseye)
                            Release:	11
                            Codename:	bullseye
                            Stopped and re-started npm… the npm start seems to generate a rolling log output (with some sensitive info), so I’ve selected what I think is relevant to the calendar for my reply. There are no errors/warning this time :)
                            [02.01.2024 09:15.55.833] [LOG]   Module helper loaded: calendar
                            [02.01.2024 09:15.58.013] [LOG]   Connecting socket for: calendar
                            [02.01.2024 09:15.58.014] [LOG]   Starting node helper for: calendar
                            [02.01.2024 09:16.02.605] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
                            [02.01.2024 09:16.27.480] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                            [02.01.2024 09:16.47.441] [LOG]   Use existing calendarfetcher for url: https://my.cal.url
                            [02.01.2024 09:16.47.442] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                            [02.01.2024 09:17.12.085] [INFO]  Calendar-Fetcher: Broadcasting 380 events from https://my.cal.url.
                            Mostly looks ok, but the “use existing calendarfetcher for url:…” concerns me.
                            Still, I have an event upcoming soon that should be displaying in my 5 entries that isn’t.
                            • M
                              matt216 @matt216
                              I can also see in pm2 logs:
                              0|MagicMir | [02.01.2024 10:11.33.120] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                              I wonder why.
                              Getting the calendar to show in the first place was achieved by changing my baikal calendar WebDAV authentication type to ‘basic’ and setting the same in the calendar module. I’ve confirmed this is still set.
                                sdetweil @matt216
                                @matt216 well the type error is the problem.
                                the calendar.module doesn’t recover after the error.
                                can you open an issue on the mm GitHub page, with that info
                                are there any errors above that?
                                • M
                                  matt216 @sdetweil
                                  @sdetweil None that I can see.
                                  pi@magicmirror:~/.pm2/logs $ tail --lines=1000 MagicMirror-error.log | grep calendar
                                  [02.01.2024 10:29.43.758] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                                  [02.01.2024 10:31.53.769] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
                                  Will open an issue. Thanks for assisting. I might have a play with a couple of the other calendar modules there are out there…
                                    sdetweil @matt216
                                    @matt216 generally there is a more specific error earlier in the log.
                                    if you clear it
                                    pm2 flush
                                    the restart
                                    pm2 restart all
                                    you will have the smallest output to look at
                                    • M
                                      matt216 @sdetweil
                                      @sdetweil Can’t see any calendar errors in error.log now! :grinning_squinting_face:
                                      But still my new events are not showing up when they should…
                                      • M
                                        matt216
                                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
                                        Reply Quote 1
                                          sdetweil @matt216
                                          @matt216 thank you… i posted a an additional grep thru the log to the issue
                                            sdetweil @matt216
                                            @matt216 cant see any errors… well not with the grep search you do
                                            can u do this
                                            pm2 stop all
                                            cd ~/MagicMirror
                                            npm start >somefile.txt 2>&1
                                            wait, til UI up with no issues, or no updates
                                            ctrl-q on MM screen to end
                                            edit the somefile.txt
                                            loo at messages after “Starting server on port”
                                            • 1 / 5
