    MM doesn't start after last update
    20 Posts 5 Posters 6.5k Views 4 Watching
      JoeFranz
      Hello and happy new year :-)
      Yesterday I updated to 2.26 using the script from sdetweil.
      Unfortunately MM doesn’t start anymore :-(
      Hope that someone can help
      Greetings Jörg
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      2|MagicMir |     at node:internal/modules/cjs/loader:929:27
      2|MagicMir |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
      2|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1150:19)
      2|MagicMir |     at require (node:internal/modules/cjs/helpers:121:18)
      2|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:10:15)
      2|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
      2|MagicMir |     at Object..js (node:internal/modules/cjs/loader:1326:10)
      2|MagicMir |     at Module.load (node:internal/modules/cjs/loader:1126:32)
      2|MagicMir |     at node:internal/modules/cjs/loader:967:12
      2|MagicMir |     at loadModule (/home/pi/MagicMirror/js/app.js:181:19)
      2|MagicMir | (Use `electron --trace-warnings ...` to show where the warning was created)
      2|MagicMir | [02.01.2024 08:21.55.970] [ERROR] (node:21245) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      2|MagicMirror  | Warning: vkCreateInstance: Found no drivers!
      2|MagicMirror  | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      2|MagicMirror  |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
      2|MagicMirror  |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
      2|MagicMirror  |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
      2|MagicMirror  |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
      2|MagicMirror  |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
      J M 2 Replies Last reply Reply Quote 0
        JoeFranz @JoeFranz
        @JoeFranz
        > magicmirror@2.26.0 start
        [02.01.2024 12:11.41.006] [LOG]   Starting MagicMirror: v2.26.0
        [02.01.2024 12:11.41.016] [LOG]   Loading config ...
        [02.01.2024 12:11.41.022] [DEBUG] config template file not exists, no envsubst
        [02.01.2024 12:11.42.733] [ERROR] (node:19253) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
        Require stack:
        - /home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
            at node:internal/modules/cjs/loader:1084:15
            at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
            at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        [02.01.2024 12:11.42.736] [ERROR] (node:19253) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          sdetweil @JoeFranz
          @JoeFranz did u upgrade w my script? or manually
          go to the module folder and do
          npm install node-fetch@2
            JoeFranz @sdetweil
            It’s working again now, thank you very much :-)
              matt216 @JoeFranz
              @JoeFranz I’m getting these vulkan warnings too - any idea what they/it is?! Doesn’t seem to affect my mirror working…
                sdetweil @matt216
                @matt216 I think the vulcan warnings are a side effect of another error…
                can u send me that somefile.txt… same userid as here at gmail…
                i don’t look at any personal info… so try not to filter it…
                  JoeFranz @sdetweil
                  MMM-Tado doesn’t start, here are the error messages :-(
                  1|MagicMir |     at process.processTimers (node:internal/timers:512:7)
                  1|MagicMir | [02.01.2024 16:25.56.242] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 36)
                  1|MagicMir | [02.01.2024 16:30.56.239] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: TypeError: self.tadoClient.login is not a function
                  1|MagicMir |     at Class.getData (/home/pi/MagicMirror/modules/MMM-Tado/node_helper.js:20:25)
                  1|MagicMir |     at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Tado/node_helper.js:103:22)
                  1|MagicMir |     at listOnTimeout (node:internal/timers:569:17)
                  1|MagicMir | [02.01.2024 16:30.56.240] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejec
                  tion. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 40)
                  1|MagicMir | [02.01.2024 16:35.56.242] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: TypeError: self.tadoClient.login is not a function
                  1|MagicMir | [02.01.2024 16:35.56.243] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 44)
                  1|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                    sdetweil @JoeFranz
                    @JoeFranz yeh tado seems to be affected by a change in how nodejs does context scoping.
                    I’ll try to make fork in the morning
                      @JoeFranz try my fork
                      rename the current module folder out of the way
                      cd ~/MagicMirror/modules
                      git clone https://github.com/sdetweil/MMM-Tado
                      cd MMM-Tado
                      npm install
                      restart mm
                        JoeFranz @sdetweil
                        That worked, thank you very much :-)
                        Now I’m only missing two calendars that aren’t displayed.
                        One from icloud and one from google. Other iCloud calendars are displayed. I hope I find the error :-)
                        N 1 Reply Last reply Reply Quote 1
                        • N Offline
                          nechry @JoeFranz
                          @JoeFranz hello I also got, I think same issue, about 2 ical didn’t load. did you figure out the issue?
                            JoeFranz
                            No, unfortunately not… :-(
                              sdetweil @JoeFranz
                              @JoeFranz still trying to find the cause…
                              so far every cal url I have received works great on my local MM systems. 2.25 and 2.26, x86, pi3, pi4 and pi5.
                              so, i’m not use what is going on…
                              in all the cases if the cal is parsed the events are broadcast but cal says no events… ???
                              weird…
                                sdetweil @JoeFranz
                                @JoeFranz lets get you back to working, move you back to whatever release worked…
                                stop mm if running
                                on the command line
                                git  tag -l
                                to list the tags (checkpoints in the list f changes, made at every release)
                                you should see a list
                                then whichever release you were last working on do
                                git checkout -b tempbranch tags/v???  the number,  2.25.0 or whatever
                                like
                                git checkout -b tempbranch tags/v2.25.0
                                if successful
                                then
                                rm -rf node_modules
                                npm install
                                and give it a try
                                  JoeFranz @sdetweil
                                  Don’t work so hard…
                                  It was just a calendar where the appointments weren’t displayed. I have now copied these into another calendar and they are now displayed there. I’m glad that everything else is working fine again, thank you for your help! :-)
                                  The command “git tag -l” only shows me up to version v2.2.0.
                                  I think I’ll leave it like that for now…:winking_face:
                                    sdetweil @JoeFranz
                                    @JoeFranz weird. but thanks for the info
                                    • plainbrokeP Offline
                                      plainbroke
                                      @sdetweil > git tag -l
                                      Sam,
                                      I am running MM 2.24.0 if I update to 2.26 Do you think it will break MMM-RTSPStream? I have 4 different instances of it running in carousel. We love the way it works showing us video of all 4 sides of our house outside.
                                        sdetweil @plainbroke
                                        @plainbroke no idea, don’t upgrade
                                        if u see the new update message, just add
                                        disabled: true
                                        to the updatenotifications module
                                        and restart mm
                                        plainbrokeP 1 Reply Last reply Reply Quote 0
                                          plainbroke @sdetweil
                                          Ok thanks for the honest answer.
                                          You the man.
                                            @plainbroke there is NEVER any reason to upgrade, unless there is something you NEED .
                                            if it ain’t broke, don’t ‘fix’ it…
