    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 17.4k Views 5 Watching
      sdetweil @codac
      @codac which error? the node-fetch or the lib error?
      (@karsten13 we installed electron, my mistake… in docker, doah! )
      • C Offline
        codac @sdetweil
        @sdetweil the node-fetch error
        • karsten13K Offline
          karsten13 @codac
          @codac
          if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
            sdetweil @karsten13
            @karsten13 did they fix the module? I didn’t check
              karsten13 @sdetweil
              you are right, they “fixed” it in devDependencies instead in dependencies …
              then git pull is useless, you have to install the missing library in the module folder as sam already explained above
              • KristjanESPERANTOK Offline
                KristjanESPERANTO Module Developer @karsten13
                I created a PR to fix this, let’s see when @0m4r accept it.
                S 0m4r0 2 Replies Last reply Reply Quote 1
                  sdetweil @KristjanESPERANTO
                  @KristjanESPERANTO well, npm install would have installed the devDependencies too…
                  KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
                    KristjanESPERANTO Module Developer @sdetweil
                    @sdetweil Sure. But my PR removes node-fetch, so npm install is no longer necessary for this module.
                      karsten13 @sdetweil
                      This sentence clicked in my brain.
                      I have NODE_ENV=production as default in my images (expect images I use for testing) and with this
                      • npm install will install nothing
                      • npm install node-fetch@2 will install nothing
                      so @codac please go again in the folder of the module and run NODE_ENV=test npm install node-fetch@2
                      this should hopefully solve the issue
                      C 1 Reply Last reply Reply Quote 1
                      • C Offline
                        codac @codac
                        @karsten13
                        @codac said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                        root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
                        root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
                        -fetch@2
                        up to date, audited 1 package in 1s
                        found 0 vulnerabilities
                        How would I restart MM of the container?
                        pm2 is not set up.
                        DISPLAY=:0 npm restart
                        …results in
                        > magicmirror@2.26.0 restart
                        > npm stop --if-present && npm start
                        > magicmirror@2.26.0 start
                        sh: 1: ./node_modules/.bin/electron: not found
                        • C Offline
                          codac @karsten13
                          @karsten13 said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                          I could see that this time node-fetch got installed (different than before running npm install node-fetch@2 only).
                          But after restarting the docker container, the same error remained.
                            karsten13
                            did the same and it works, so no idea anymore
                            • C Offline
                              codac @karsten13
                              @karsten13 your are right… somehow the docker didn’t keep the installation after first try.
                              After installing it a second time and restarting the docker afterwards, the container kept the installation of node-fetch. Its working now.
                              Thank you guys for your massive support. Big time!
                              @karsten13, @sdetweil, @KristjanESPERANTO
                              • 0m4r0 Offline
                                0m4r Module Developer @KristjanESPERANTO
                                @KristjanESPERANTO thank you!
                                …and apologies for missing the whole discussion, I have updated my preferences to get e-mails when someone mentions me :)
