    MM loading all modules is taking 2-3 minutes.
    19 Posts 2 Posters 6.1k Views 2 Watching
    • plainbrokeP
      plainbroke
      I am having a new to me weird issue where when i restart mm it takes 2-3 minutes to load. During that time it is loading all the modules under mmm-carousel module. Eventually they will all load and work as they should. Any Ideas what causes this?
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @plainbroke
        These are the modules I am running under MMM-Carousel.
        MMM-CalendarExt3 calendar facts iFrame
        MMM-ATM MMM-Bored MMM-CalvinAndHobbes MMM-CloneWarsQuotes
        MMM-RTSPStream MMM-Cocktails MMM-DailyQuote MMM-DateCounter
        MMM-Dogs MMM-EmbedURL MMM-Evil MMM-EyeCandy //flying Calvin
        MMM-RTSPStream2 MMM-Fuel MMM-Globe MMM-GmailFeed MMM-History
        MMM-icanhazdadjoke MMM-iFrame-GSlides MMM-ImagesPhotos
        MMM-Jast //ups stock MMM-MyWordOfTheDay MMM-NetworkScanner
        MMM-NFL MMM-Oneliner MMM-RTSPStream4 MMM-OpenWeatherForecast
        MMM-quote-of-the-day MMM-RAIN-MAP MMM-rfacts MMM-SimpleLogo
        MMM-TrivialAbyss MMM-WebView MMM-WiFiPassword random_quotes
        MMM-RTSPStream5
        • plainbrokeP
          plainbroke
          Which browser should I use?
          Chromium, Midori, Firefox, Surf or is there a better one to help with the load on the RaspberryPi 4-8gb version?
          Since I am running so many modules on one pi under MagicMirror 2.24
            sdetweil @plainbroke
            @plainbroke you should not have a problem on pi 4 8gb.
            if you run speed test does the network speed look proper?
            can you do free -m
            you should have no swap
            also run top to look at CPU performance and active processes
            • plainbrokeP
              plainbroke @sdetweil
              I do have a swp file.
              Do I need to get rid of it and if so, how?
              total used free shared buff/cache available
              Mem: 7846 535 6374 230 936 6862
              Swap: 99 0 99
                @plainbroke said in MM loading all modules is taking 2-3 minutes.:
                Swap: 99 0 99
                but not used… size 99meg, free 99meg…
                so, its not a memory problem (6862 meg free)
                • plainbrokeP
                  Do not know how to post the top part it keeps changing.
                  Only lets me copy part of it.
                   PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                    884 pi        20   0  494048 193120  87580 S  58.3   2.4  11:53.37 electron
                    875 pi        20   0  745824 472024 434912 S  35.1   5.9   3:47.87 electron
                    909 pi        20   0  345508 114484  78316 R  22.5   1.4   1:44.53 electron
                    879 pi        20   0  298500  63208  49584 S  21.5   0.8   4:18.07 electron
                    778 pi        20   0  731340 236804 108916 S  19.2   2.9   4:03.12 electron
                   1034 pi        20   0  194140  29260  20112 S   6.3   0.4   0:42.24 omxplayer.bin
                    590 root      20   0  124324  47660  32436 S   6.0   0.6   0:30.80 Xorg
                    436 root      20   0       0      0      0 I   5.3   0.0   0:12.04 kworker/u8:3-ext4-rsv-conversion
                   1393 root      20   0       0      0      0 I   4.6   0.0   0:06.66 kworker/u8:1-brcmf_wq/mmc1:0001:1
                   1033 pi        20   0  194036  28920  20056 S   4.3   0.4   0:37.70 omxplayer.bin
                     85 root      20   0       0      0      0 I   3.6   0.0   0:08.36 kworker/0:4-events
                    250 root      -2   0       0      0      0 S   1.0   0.0   0:05.17 v3d_bin
                    251 root      -2   0       0      0      0 S   1.0   0.0   0:04.87 v3d_render
                     80 root       1 -19       0      0      0 S   0.7   0.0   0:04.30 vchiq-slot/0
                   1345 pi        20   0   10444   3000   2572 R   0.7   0.0   0:11.28 top
                      7 root      20   0       0      0      0 I   0.3   0.0   0:19.99 kworker/u8:0-brcmf_wq/mmc1:0001:1
                     11 root      20   0       0      0      0 S   0.3   0.0   0:00.56 ksoftirqd/0
                     12 root      20   0       0      0      0 I   0.3   0.0   0:02.51 rcu_sched
                     89 root     -51   0       0      0      0 S   0.3   0.0   0:02.53 irq/47-mmc0
                     94 root      20   0       0      0      0 S   0.3   0.0   0:01.11 jbd2/sda2-8
                    252 root      -2   0       0      0      0 S   0.3   0.0   0:01.25 v3d_tfu
                   1363 root      20   0       0      0      0 I   0.3   0.0   0:12.62 kworker/u8:4-brcmf_wq/mmc1:0001:1
                   1377 root      20   0       0      0      0 I   0.3   0.0   0:00.70 kworker/3:1-events
                   1392 root      20   0       0      0      0 I   0.3   0.0   0:00.09 kworker/1:3-events
                   1408 root      20   0       0      0      0 I   0.3   0.0   0:00.41 kworker/0:2-events
                      1 root      20   0   33708   8296   6680 S   0.0   0.1   0:05.23 systemd
                      2 root      20   0       0      0      0 S   0.0   0.0   0:00.01 kthreadd
                      3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                      4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                      6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
                      8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                      9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
                     10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
                     13 root      rt   0       0      0      0 S   0.0   0.0   0:00.01 migration/0
                     14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                     15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                     16 root      rt   0       0      0      0 S   0.0   0.0   0:00.02 migration/1
                     17 root      20   0       0      0      0 S   0.0   0.0   0:00.48 ksoftirqd/1
                     19 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-kblockd
                     20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                     21 root      rt   0       0      0      0 S   0.0   0.0   0:00.02 migration/2
                     22 root      20   0       0      0      0 S   0.0   0.0   0:00.35 ksoftirqd/2
                     24 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-kblockd
                     25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                     26 root      rt   0       0      0      0 S   0.0   0.0   0:00.01 migration/3
                    @plainbroke always please use code block for formatting
                    don’t ‘see’ anything…
                    • plainbrokeP
                      Ok this may be my problem : failed to open kms_swrast
                      I have seen reference to this before but am either brain dead or my google search is failing me.
                      0|mm | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                      0|mm | failed to load driver: kms_swrast
                      0|mm | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                      0|mm | failed to load swrast driver
                      0|mm | [875:0114/170050.541663:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                      0|mm | [875:0114/170113.661954:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                      0|mm | [875:0114/170115.296236:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                      0|mm | [778:0114/170757.084668:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.NetworkManager.GetDevices: object_path= /org/freedesktop/NetworkManager: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.NetworkManager was not provided by any .service files
                        no… that is the GPU driver stuff… usually not enabled in /config.txt in 2.26 we disable using the gpu by default to turn off these messages (instead of leaving it on in 2.25 and prior)
                        • plainbrokeP
                          I am still on 2.24 so I can use MMM-RTSPStream, also still on Jesse for the same reason.
                          Should I run this to remove swap file?
                          sudo swapoff -a -v
                          sudo rm /swapfile
                          S plainbrokeP 2 Replies Last reply
                            @plainbroke so, I would be carefull… newer code doesn’t run on jesse and gosh knows what you have now…
                            4 OS releases back (2017), stretch , buster, bullseye, now bookworm
                            https://en.wikipedia.org/wiki/Raspberry_Pi_OS
                            so, you have an 8gig machine, but can only use 2gig (32bit OS)
                            • plainbrokeP
                              Sorry it is buster, it is the last one that allows the rstp modules I like so much…
                              Linux MM 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
                                armv7
                                32bit
                                aaarch64 is 64 bit
                                • plainbrokeP
                                  Can I load the 64bit version without reloading all my MagicMirror modules ect?
                                  I tried this :
                                  cd ~/MagicMirror
                                  export external_browser=midori
                                  export ELECTRON_DISABLE_GPU=1
                                  DISPLAY=:0 npm start
                                    @plainbroke you have to use my start script to make Midori work, after you install it
                                    change the package json {“start” line to {“start1”
                                    then add a new start line
                                    {"start":"./run-start.sh"},
                                    and download the run-start.sh from my script repo, and put it in the MagicMirror folder, mark it executable
                                    chmod +x run-start.sh
                                    • plainbrokeP
                                      Which one of the package.json files the one before MagicMirror folder or the one in the MagicMirror folder?
                                        @plainbroke in the MagicMirror folder
                                        there should not be one in the folder before
                                        • plainbrokeP
                                          Well I removed the package.json and packagelock.json from the folder MagicMirror sets in and ran your upgrade script and my MM loaded a whole lot faster and only time will tell if it is totally fixed or not…
                                          I appreciate your patients dealing with this issue.
                                          I will definitely add it to my saved stuff.
                                          I would like to try to use a different browser and see if it fixes a few other issues since I am using a 32 bit OS.
