    MM failed after updating
    16 Posts 3 Posters 4.5k Views 3 Watching
    • 1 Offline
      1a2a3a
      Hi, after updating my MM, when i try to start i get this error.
      node_modules/.bin/electron: not found"
      what should i do?
      • C Offline
        chrisfr1976 @sdetweil
        @sdetweil I was able to fix it. git reset --hard followed by npm run install-mm fixed the issue. I don’t know why but now everything is fine again. I’ll do a SD-card back-up now :-)
        Regards, Chris.
          sdetweil @1a2a3a
          @1a2a3a please tell me how you updated and what.platform you are on
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil on pi 5. updated using your script. while attempting to google search for fixes, i seems to have broken more stuff. trying to rebuild again from scratch…using your script… to update again…
              sdetweil @1a2a3a
              @1a2a3a can you show me the ~/MagicMirror/installers/upgrade.log
              in the future ask for help first, vs apply random answers.
              you could have just tried installing the electon version.
              • 1 Offline
                1a2a3a @sdetweil
                @sdetweil i cant. i deleted the entire folder. just installed using your script. now transferring the modules folder from backup to the pi.
                thats what i did actually, installing the electron but it keep throwing error like npm ERR! signal sigint
                npm ERR! code E404
                  sdetweil @1a2a3a
                  @1a2a3a thanks. i needed to see the actual npm install output
                  use my backup/restore scripts
                  • 1 Offline
                    1a2a3a @sdetweil
                    @sdetweil thanks. still in the midst of transferring.
                    why are you up so early? i recall you were some hours behind so when i posted this i figured i wouldnt get a response so soon hence my attempt of own answer.
                      sdetweil @1a2a3a
                      @1a2a3a i was on US west coast time for a couple months now back in central time. thanks for noticing…
                      • 1 Offline
                        1a2a3a @sdetweil
                        @sdetweil i see. anyway, my calendar, stocks and google photo are not loading. it says check logs for details – where can i find the logs again?
                        edit—
                        its odd. when i run npm start dev, everything is working fine, everything loads.
                        but when i run pm2 start MagicMirror - my cal, stocks and photos are not loading. am i suppose to let it sit there for awhile?
                          sdetweil @1a2a3a
                          @1a2a3a logs are output where the npm start is done.
                          pm2 captures them
                          do this
                          pm2 stop all
                          pm2 flush
                          wait 15 seconds
                          pm2 stop all
                          pm2 logs --lines=75
                          • C Offline
                            Same issue here:
                            chris@MagicPi:~/MagicMirror $ pm2 logs --lines=75
                            [TAILING] Tailing last 75 lines for [all] processes (change the value with --lines option)
                            /home/chris/.pm2/pm2.log last 75 lines:
                            PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] starting in -fork mode-
                            PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] online
                            PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] starting in -fork mode-
                            PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] online
                            PM2        | 2024-04-03T10:25:48: PM2 log: Stopping app:mm id:0
                            PM2        | 2024-04-03T10:25:48: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2024-04-03T10:25:48: PM2 log: pid=3783 msg=process killed
                            /home/chris/.pm2/logs/mm-out.log last 75 lines:
                            /home/chris/.pm2/logs/Display-Drehen-out.log last 75 lines:
                            /home/chris/.pm2/logs/Display-Drehen-error.log last 75 lines:
                            /home/chris/.pm2/logs/mm-error.log last 75 lines:
                            0|mm       | npm ERR! code EJSONPARSE
                            0|mm       | npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                            0|mm       | npm ERR! JSON.parse Failed to parse JSON data.
                            0|mm       | npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                            0|mm       |
                            0|mm       | npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                            Complete log:
                            0 verbose cli /usr/bin/node /usr/bin/npm
                            1 info using npm@10.5.0
                            2 info using node@v21.7.1
                            3 timing npm:load:whichnode Completed in 5ms
                            4 timing config:load:defaults Completed in 5ms
                            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
                            6 timing config:load:builtin Completed in 2ms
                            7 timing config:load:cli Completed in 6ms
                            8 timing config:load:env Completed in 2ms
                            9 timing config:load:file:/home/chris/MagicMirror/.npmrc Completed in 5ms
                            10 timing config:load:project Completed in 7ms
                            11 timing config:load:file:/home/chris/.npmrc Completed in 1ms
                            12 timing config:load:user Completed in 1ms
                            13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                            14 timing config:load:global Completed in 1ms
                            15 timing config:load:setEnvs Completed in 3ms
                            16 timing config:load Completed in 27ms
                            17 timing npm:load:configload Completed in 27ms
                            18 timing config:load:flatten Completed in 7ms
                            19 timing npm:load:mkdirpcache Completed in 0ms
                            20 timing npm:load:mkdirplogs Completed in 0ms
                            21 verbose title npm start
                            22 verbose argv "start"
                            23 timing npm:load:setTitle Completed in 2ms
                            24 timing npm:load:display Completed in 2ms
                            25 verbose logfile logs-max:10 dir:/home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-
                            26 verbose logfile /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                            27 timing npm:load:logFile Completed in 23ms
                            28 timing npm:load:timers Completed in 0ms
                            29 timing npm:load:configScope Completed in 0ms
                            30 timing npm:load Completed in 107ms
                            31 silly logfile start cleaning logs, removing 2 files
                            32 timing command:run-script Completed in 21ms
                            33 timing command:start Completed in 36ms
                            34 verbose stack JSONParseError: Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                            34 verbose stack     at PackageJson.fromJSON (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:162:24)
                            34 verbose stack     at PackageJson.load (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:156:17)
                            34 verbose stack     at async PackageJson.normalize (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:115:5)
                            34 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:72:27)
                            34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
                            35 verbose cwd /home/chris/MagicMirror
                            36 verbose Linux 6.1.21-v7l+
                            37 verbose node v21.7.1
                            38 verbose npm  v10.5.0
                            39 error code EJSONPARSE
                            40 error JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                            41 error JSON.parse Failed to parse JSON data.
                            41 error JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                            42 verbose exit 1
                            43 timing npm Completed in 228ms
                            44 verbose code 1
                            45 error A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                            :anxious_face_with_sweat:
                            Cheers,
                            Chris.
                            Regards, Chris.
                              sdetweil @chrisfr1976
                              @chrisfr1976 can you post the few lines of package.json around line 87
                              did you use my upgrade script?
                              if so can u email me the file
                              using the same userid as on this post at gmail
                              • C Offline
                                In the beginning I’ve used the described update method here:
                                https://docs.magicmirror.builders/getting-started/upgrade-guide.html
                                So only git pull && npm run install-mm was used. But I’ve used the back-up script you’ve provided. Then I found also your update script. I’ve used it then, too. But same error. I’ll send the update.log via email :-)
                                Here the lines around line 87. I’ve marked it to show the position only:
                                  // Loads a package.json at given path and JSON parses
                                  static async load (path, opts = {}) {
                                    const p = new PackageJson()
                                    // Avoid try/catch if we aren't going to create
                                    if (!opts.create) {
                                      return p.load(path)
                                *87*
                                    try {
                                      return await p.load(path)
                                    } catch (err) {
                                      if (!err.message.startsWith('Could not read package.json')) {
                                        throw err
                                      return await p.create(path)
                                Chris.
                                Regards, Chris.
                                  @chrisfr1976 hm…
                                  package.json looks like this
                                  • C Offline
                                    Regards, Chris.
                                      @chrisfr1976 weird, thanks for the update
