    MMM-CalendarExt2 not working
    8 Posts 3 Posters 2.0k Views 3 Watching
    • V
      veny
      The module stopped working. Disappeared from the screen. I tried to install it again, it didn’t help.
      What could be the reason?
      Thanks in advance everyone!
        module:"MMM-CalendarExtMinimonth",
        position:"top_right",
        module: 'MMM-CalendarExt2',
          calendars : [
              url: "https://calendar.google.com/calendar/ical/veny071%40gmail.com/private-55d2d67bbe5cXXXXXXXXX6e2a64/basic.ics",
          views: [
              mode: "",
          scenes: [
      output
      [2024-05-18 13:26:43.956] [LOG]   Starting MagicMirror: v2.27.0
      [2024-05-18 13:26:44.026] [LOG]   Loading config ...
      [2024-05-18 13:26:44.032] [LOG]   config template file not exists, no envsubst
      [2024-05-18 13:26:44.039] [LOG]   Loading module helpers ...
      [2024-05-18 13:26:44.042] [LOG]   No helper found for module: alert.
      [2024-05-18 13:26:44.672] [LOG]   Initializing new module helper ...
      [2024-05-18 13:26:44.673] [LOG]   Module helper loaded: updatenotification
      [2024-05-18 13:26:44.674] [LOG]   No helper found for module: MMM-FlipClock.
      [2024-05-18 13:26:44.677] [LOG]   No helper found for module: weather.
      [2024-05-18 13:26:44.953] [LOG]   Initializing new module helper ...
      [2024-05-18 13:26:44.955] [LOG]   Module helper loaded: newsfeed
      [2024-05-18 13:26:44.956] [LOG]   No helper found for module: MMM-yandex-route.
      [2024-05-18 13:26:44.957] [LOG]   No helper found for module: MMM-CalendarExtMinimonth.
      [2024-05-18 13:26:45.347] [LOG]   Initializing new module helper ...
      [2024-05-18 13:26:45.348] [LOG]   Module helper loaded: MMM-CalendarExt2
      [2024-05-18 13:26:45.349] [LOG]   All module helpers loaded.
      [2024-05-18 13:26:45.364] [LOG]   Starting server on port 8082 ...
      [2024-05-18 13:26:47.780] [LOG]   Server started ...
      [2024-05-18 13:26:47.783] [LOG]   Connecting socket for: updatenotification
      [2024-05-18 13:26:47.785] [LOG]   Starting module helper: updatenotification
      [2024-05-18 13:26:47.787] [LOG]   Connecting socket for: newsfeed
      [2024-05-18 13:26:47.790] [LOG]   Starting node helper for: newsfeed
      [2024-05-18 13:26:47.791] [LOG]   Connecting socket for: MMM-CalendarExt2
      [2024-05-18 13:26:47.793] [LOG]   Sockets connected & modules started ...
      [2024-05-18 13:26:49.319] [LOG]   Launching application.
      [2024-05-18 13:26:59.902] [LOG]   Create new newsfetcher for url: http://www.lenta.ru/rss/top7 - Interval: 300000
      [2024-05-18 13:27:02.920] [INFO]  Newsfeed-Fetcher: Broadcasting 13 items.
      [2024-05-18 13:27:04.072] [INFO]  System information:
      ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
      ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 5.15.32-v7+
      ### VERSIONS: electron: 29.3.2; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
      ### OTHER:    timeZone: Europe/Moscow; ELECTRON_ENABLE_GPU: undefined
      [2024-05-18 13:27:04.104] [INFO]  updatenotification: Updater Class Loaded!
      [2024-05-18 13:27:04.107] [INFO]  updatenotification: Checking PM2 using...
      [2024-05-18 13:27:04.112] [INFO]  Checking git for module: MMM-FlipClock
      [2024-05-18 13:27:04.192] [LOG]   [CALEXT2] calendar:0 >> Scanning start with interval:1800000
      [26285:0518/132704.348686:ERROR:CONSOLE(1)] "Request Autofill.enable failed. {"code":-32601,"message":"'Autofill.enable' wasn't found"}", source: devtools://devtools/bundled/core/protocol_client/protocol_client.js (1)
      [2024-05-18 13:27:04.748] [INFO]  Checking git for module: MMM-yandex-route
      [2024-05-18 13:27:04.858] [INFO]  updatenotification: [PM2] You are not using pm2
      [2024-05-18 13:27:04.883] [INFO]  Checking git for module: MMM-CalendarExtMinimonth
      [2024-05-18 13:27:04.994] [INFO]  Checking git for module: MMM-CalendarExt2
      [2024-05-18 13:27:05.414] [LOG]   [CALEXT2] calendar:0 >> Scanned: 1, Selected: 1
      [2024-05-18 13:27:05.470] [INFO]  Checking git for module: MagicMirror
      [26427:0518/132710.025314:ERROR:gles2_cmd_decoder_passthrough.cc(946)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
      [26427:0518/132710.054468:ERROR:gles2_cmd_decoder_passthrough.cc(946)] ContextResult::kFatalFailure: fail_if_major_perf_caveat + swiftshader
      [26427:0518/132723.341076:ERROR:x11_software_bitmap_presenter.cc(144)] XGetWindowAttributes failed for window 44040211
      [26285:0518/132849.824940:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
      [2024-05-18 13:32:03.222] [INFO]  Newsfeed-Fetcher: Broadcasting 13 items.
      [2024-05-18 13:37:03.466] [INFO]  Newsfeed-Fetcher: Broadcasting 13 items.
      [2024-05-18 13:42:03.689] [INFO]  Newsfeed-Fetcher: Broadcasting 13 items.
      M BKeyportB 3 Replies Last reply
      • M
        MMRIZE @veny
        @veny
        That error log doesn’t help. No idea.
        • BKeyportB
          BKeyport Module Developer @veny
          @veny I see you’re using google. They may have discontinued the access methods used within Ext2. You should upgrade to Ext3.
          V 1 Reply Last reply
          • V
            veny @BKeyport
            @BKeyport
            Can i use Yahoo Calendar or ohters?
            I’d like use plagin MMM-CalendarExtMinimonth because i like his appearance
            BKeyportB 1 Reply Last reply
            • M
              MMRIZE @veny
              @veny
              I tested but nothing special wrong.
              This is my config for my Google Calendar ics.
                  calendars : [
                      url: "https://calendar.google.com/calendar/ical/4b9c...6390%40group.calendar.google.com/private-e481c...c7cc/basic.ics",
              		scenes: [
              		views: [
              				mode: "daily",
              I used Secret address URL for ical format, you looks also use that URL too.
              Your log says the parsing completed successfully for your ics. It may have 1 event.
              However, I have no idea why the module doesn’t appear. Maybe other module may interrupt something.
              To make things simple, you can test a new config without other modules except MMM-CalendarExt2 and clock module. You can focus the issue only.
              • M
                MMRIZE
                Anyway, I stopped to maintain CX2.
                You can use MMM-CalendarExt3Agenda instead. It could have similar looks, though not identical.
                • BKeyportB
                  @veny Ahh, ext3agenda has a minimonth display, or if you’d like another take on it, my module, MMM-Multimonth does another style of mini calendar display. Both use the very same calendar base, and both will be supported.
                  Lots of options for better supported calendar operations. Please take a look at the 3rd Party modules in the title bar above. The List icon "Screenshot 2024-05-19 at 12.55.55.png " will lead the way.
                  • V
                    veny @BKeyport
                    @BKeyport
                    Hello. Thank you very much for the hint about the module. I installed it and am using it. Please tell me how I can increase the font size in the name of the month and numbers. Thank you in advance!
