    MMM-Remote-Control Alternative
    15 Posts 4 Posters 6.1k Views 4 Watching
      Dennys1
      hi,
      I have Magic Mirror on a raspberry pi4, I’m trying to use the MMM-Remote-Control module but it conflicts with MMM-GoogleAssistant, I tried everything but I couldn’t make it work, my main purpose is to send commands from Home Assistant, there is an alternative to Remote Control ?
      thanks everyone
      S D BKeyportB 3 Replies Last reply Reply Quote 0
        sdetweil @Dennys1
        @Dennys1 what is the conflict? shouldn’t be any
          Dennys1 @Dennys1
          this is the error when remote control is enabled in config.js,If I remove it everything works fine
            sdetweil @Dennys1
            @bugsounet whats the deal here ?
              Dennys1
              the problem is that GoogleAssistant does not load if Remote Control is present and magic mirror is stopped, I have tried different versions of Remote Control but without success,
              the operating system is Debian version: 11 (bullseye) Kernel version: 6.1 on Raspberry
              Thank you
                sdetweil @Dennys1
                @Dennys1 I understand what is happening. I asked the GoogleAssistant author to explain why
                  Dennys1
                  ok, thanks for your cooperation
                    sdetweil @Dennys1
                    @Dennys1 I’m the moderator here
                    • BKeyportB Offline
                      BKeyport Module Developer @Dennys1
                      @Dennys1 What are you trying to do? I’m running most of my automation stuff outside of the MM ecosystem for sanity reasons. MMM-RemoteControl never did anything right for me.
                      1 Reply Last reply Reply Quote -1
                        Dennys1
                        hi,
                        I would like to make Home Assistant installed on a second Raspberry send a command to RemoteControl to go to a specific page (e.g. Page3) of MM,
                        maybe there are other ways but I don’t know them
                        S BKeyportB 3 Replies Last reply Reply Quote 0
                          sdetweil @Dennys1
                          @Dennys1 as you have home assistant, and probably use mqtt for other devices
                          use this
                          https://github.com/Tom-Hirschberger/MMM-MQTTbridge
                          and on the HA side see this, for example
                          https://community.home-assistant.io/t/publish-mqtt-from-an-automation/58967
                            sdetweil @Dennys1
                            @Dennys1 I have another mirror project I support, and added code to auto register a device as a switch with HA . then I can turn on/off in automation.
                            I use a nodered registered alexa device to trigger my ‘good night’ automation which locks the doors, turns off the lights and turns off the screen of the mirror in the hall (over mqtt)
                            • BKeyportB Offline
                              @Dennys1 Sam’s got the best idea for you. There’s other ways to do it, but that by far is the easiest.
                                atwist
                                I’ve actually run into the same initial issue as the author. When mmm-googleassistant and mmm-remote-control are both installed it automcially closes magicmirror.
                                Any ideas?
                                  sdetweil @atwist
                                  @atwist the googleassistant author has coded it that way don’t know why.
