calendar_monthly header still showing
This is from the config directions of the module
showHeader
This allows you to turn on or off the header on the calendar. The header consists of the month and year.
true
- Other option isfalse
.{ module: 'calendar_monthly', position: 'top_left', config: { showHeader: 'false', cssStyle: 'block', // block, clean, custom, (slate is for no mirror) updateDelay: 5 // 5 secs default } },
However, even with the showHeader set to false, I still have a one with the month and year showing.
Any ideas?
@Mykle1 when handling false/true I don’t think you are supposed to use ’ ’ around it.
Should be handled like numbers.
@broberg said in calendar_monthly header still showing:
Should be handled like numbers.Well, I’m an idiot! Thanks bro. I’ll change that right now.
That did the trick.
Yes true and false in that case are used as a boolean so you don’t use ’ ’ or " "
Very often, in programming, you will need a data type that can only have one of two values, like YES / NO ON / OFF TRUE / FALSE For this, JavaScript has a Boolean data type. It can only take the values true or false.
I had to learn that too
@Mykle1 In case you want to know why:
'false'
is a string and astring
always represents theboolean
true
, so'test'
,'true'
and'false'
all become true it doesn’t matter what the content of the string is.
@strawberry-3.141 said in calendar_monthly header still showing:
‘false’ is a string and a string always represents the boolean true, so ‘test’, ‘true’ and ‘false’ all become true it doesn’t matter what the content of the string is.So, the single quotes
are what make it a string? Meaning, whatever is inside single quotes is considered a string?
And if that is so, then what is the wordtrue
orfalse
without the quotes called? A value? A parameter?Obviously, I’m still confused, but thank you for the lesson.
@Mykle1 everything in single or double quotes is a string, string is a type for text.
There are multiple types:
- object
- array
- number
and3.14
- string
"I am a string"
and'me too'
- boolean
true
orfalse
- object
Ok, thank you. I do appreciate the information. Some of it is starting to make sense. I’ve learned quite a bit in the short time that I’ve been here.
