calendar_monthly header still showing
8 Posts 4 Posters 3.1k Views 3 Watching
    This is from the config directions of the module
    showHeader This allows you to turn on or off the header on the calendar. The header consists of the month and year.
    true - Other option is false.
                    	module: 'calendar_monthly',
                    	position: 'top_left',
                            showHeader: 'false',
    			cssStyle: 'block', // block, clean, custom, (slate is for no mirror)
    			updateDelay: 5 // 5 secs default
    However, even with the showHeader set to false, I still have a one with the month and year showing.
    Any ideas?
    B 1 Reply Last reply Feb 26, 2017, 4:13 PM Reply Quote 0
      broberg Project Sponsor @Mykle1
      @Mykle1 when handling false/true I don’t think you are supposed to use ’ ’ around it.
      Should be handled like numbers.
      M 1 Reply Last reply Feb 26, 2017, 4:16 PM Reply Quote 2
        Mykle1 Project Sponsor Module Developer @broberg
        @broberg said in calendar_monthly header still showing:
        Well, I’m an idiot! Thanks bro. I’ll change that right now.
        That did the trick. :clap_tone2:
        C S 2 Replies Last reply Feb 26, 2017, 4:43 PM Reply Quote 0
          @Mykle1
          Yes true and false in that case are used as a boolean so you don’t use ’ ’ or " " :)
          Very often, in programming, you will need a data type that can only have one of two values, like
          YES / NO
          ON / OFF
          TRUE / FALSE
          For this, JavaScript has a Boolean data type. It can only take the values true or false.
          I had to learn that too :)
            strawberry 3.141 Project Sponsor Module Developer @Mykle1
            @Mykle1 In case you want to know why:
            'false' is a string and a string always represents the boolean true, so 'test', 'true' and 'false' all become true it doesn’t matter what the content of the string is.
            M 1 Reply Last reply Feb 26, 2017, 10:32 PM Reply Quote 1
              Mykle1 Project Sponsor Module Developer @strawberry 3.141
              @strawberry-3.141 said in calendar_monthly header still showing:
              ‘false’ is a string and a string always represents the boolean true, so ‘test’, ‘true’ and ‘false’ all become true it doesn’t matter what the content of the string is.
              So, the single quotes ' are what make it a string? Meaning, whatever is inside single quotes is considered a string?
              And if that is so, then what is the word true or false without the quotes called? A value? A parameter?
              Obviously, I’m still confused, but thank you for the lesson.
              S 1 Reply Last reply Feb 26, 2017, 10:36 PM Reply Quote 0
                @Mykle1 everything in single or double quotes is a string, string is a type for text.
                There are multiple types:
                • object {}
                • array []
                • number 2, -17 and 3.14
                • string "I am a string" and 'me too'
                • boolean true or false
                M 1 Reply Last reply Feb 27, 2017, 12:31 AM Reply Quote 1
                  Ok, thank you. I do appreciate the information. Some of it is starting to make sense. I’ve learned quite a bit in the short time that I’ve been here.
