    MMM-OpenWeatherForecast
    92 Posts 14 Posters 56.7k Views 14 Watching
      Ray @wishmaster270
      @wishmaster270
      so I found out what was going on with the calls being counted when my magic mirror wasn’t even up and running
      so here’s what I found out
      I have MMM-OpenWeatherForecast checking the temperature in two time zones
      and one of the time zone I have set requestDelay: 250
      this was done before the upgrade to 3.0 call abb
      since then I have deleted one of the time zones
      but forgot to delete requestDelay: 250 an error in my part
      it turns out that the One Call API 3.0 was counting all the calls in that 250
      in version 2.5 we didn’t have to worry about that
        sdetweil @Ray
        @Ray yes, a call is a call. 250 is WAY TOO OFTEN for weather that doesn’t changed but every 10-15 minutes
          Ray @sdetweil
          I just thought I’d throw it out there in case someone else runs into the same problem
            JohnGalt @Ray
            @Ray – Just for the sake of completeness for you or others I will mention here that the provider will count ALL calls, from ALL modules.
            As an example I can have this module running for a comprehensive look at my local weather, plus an instance of the default weather module telling me what’s happening with a friend or relatives, plus I’m running MMM-DynamicWeather.
            The API will count all the calls from all sources. It would be great if the MM system could pull the data and broadcast it to modules as needed, but that’s not how it works.
            S butchkemperB 2 Replies Last reply Reply Quote 0
              sdetweil @JohnGalt
              @JohnGalt the default weather broadcasts it’s data just like calendar does
              So the othermodules could use it
              • wishmaster270W Offline
                wishmaster270 Module Developer @sdetweil
                Just to make clear.
                The requestDelay is only used for the time between the start of the mirror and the first fetch of the data.
                For all following the updateInterval in seconds is used.
                The module sends is weather info, too. But I think both modules are not capable of use the info provided by notification at the moment
                • butchkemperB Offline
                  butchkemper @JohnGalt
                  @JohnGalt
                  The api call daily threshold for billing is 1,000. The default setting is to update every 10 minutes and that equals to 144 daily calls.
                  Butch
                  Resistance is not Futile!
                  It is voltage divided by current.
                  • H Offline
                    hrjmsh @OldGuyBerlin
                    @OldGuyBerlin Worked for me, thanks.
                    • C Offline
                      chris1971 @hrjmsh
                      I had the same problem with my weather forecast. I made a subscription for an API 3.0 key and modified the config in this way:
                      		module: "MMM-OpenWeatherForecast",
                      		header: "Wetter in Mülheim",
                              apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
                              apikey: "xxxxxxxxxxxxxxxxxxxxxxxx", //only string here
                            latitude: 51.xxxxxxxx,            //number works here
                            longitude: 6.9xxxxxxxx,          //so does a string
                            updateInterval: 45,
                      	iconset: "3c",
                      	maxDailiesToShow: 4,
                      	maxHourliesToShow: 4,
                      	label_hourlyTimeFormat: "k[ Uhr]",
                      	label_sunriseTimeFormat: "k:mm",  // change the format for this one
                      	label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                      In addition I added “https://api.openweathermap.org/data/3.0/onecall?” as mentioned by @Ray in the node_helper.js in the weather module. The update intervall is 45 minutes - which means below 1000 calls per month
                      The module is running again!!!
                      Thx to this community and forum,
                      Chris
                      htilburgsH 1 Reply Last reply Reply Quote 0
                      • htilburgsH Offline
                        htilburgs @chris1971
                        What if you don’t have a creditcard like me??
                        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                          sdetweil @htilburgs
                          @htilburgs use pirateweather provider, on the default weather
                            htilburgs @sdetweil
                            Thanks, now it looks a bit like OpenWeather again ;-)
                            • 5 / 5
