    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 11.0k Views 8 Watching
      sdetweil @JMac
      @JMac yes, the line before needs a trailing comma
        MaXi-XCeL Project Sponsor @Peter
        @Peter Found it in the documentation!
        Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
        https://docs.magicmirror.builders/modules/weather.html#configuration-options
        P P 2 Replies Last reply Reply Quote 1
        • P Offline
          Peter @MaXi-XCeL
          @MaXi-XCeL it works!
          Thanks,
          Peter
          • P Offline
            pritikin71 @MaXi-XCeL
            Hi I have a new problem now, using /onecall and the correct Lat /Long parameters shows my Time Zone Name omn top of Weather modules and a Crazy time… the Clock Module shows correct.
            What else I need to modify to have Weather working again like before the doomed update? ( “Xx” for privacy)
            		module: "weather",
            		CalendarClasses: "current",
            		header: "Weather Forecast",
                    disabled: false,
            			weatherEndpoint: "/onecall",
            			//updateInterval: "20",
            			type: "current",
            			tempUnits: "imperial",
            			degreeLabel: "false",
            			locationID: "XXxXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            			apiKey: "XxXXXXxxXXXXxXXxXXxX",
                        showFeelsLike: "false",
            			lat: "2XXXX350",
                        lon: "-8X.3XXxX915"
            S S 2 Replies Last reply Reply Quote 0
              sdetweil @pritikin71
              @pritikin71
              see
              https://forum.magicmirror.builders/topic/19043/location-title-in-default-module-weather-openweather
              • P Offline
                pritikin71 @sdetweil
                @sdetweil Thank you a lot.
                I was able to fix the header problem but not the time problem. I looked to a lot of /js files looking for the TimeZone Parameter but I didnt get it.
                Also is really weird the 18:48… the different minutes tells that maybe isn’t a timezone problem.
                S karsten13K 2 Replies Last reply Reply Quote 0
                  @pritikin71 weather with openweather 3 uses lat/lon for location
                  and time is local system time . make sure you have timezone set correctly
                  corrected below… sunrise/sunset time is shown (whichever is next)
                  not current wall clock time
                  • karsten13K Offline
                    karsten13 @pritikin71
                    @pritikin71 said in Default weather module stuck loading after latest MM update:
                    this is not an actual time, but sunrise or sunset (depending on what comes next)
                      sdetweil @karsten13
                      @karsten13 dang I get that wrong EVERY time!
                        karsten13 @sdetweil
                        @sdetweil said in Default weather module stuck loading after latest MM update:
                        one of the reasons I wrote my own njk …
                        • 3 / 4
