    Cant use showEnd icloud cal
    30 Posts 3 Posters 3.8k Views 3 Watching
      blvk @sdetweil
      @sdetweil said in Cant use showEnd icloud cal:
      @blvk turn off showOnlyWithDuration
      set to false, no changes, do you need some more informations i can share?
        sdetweil @blvk
        @blvk sorry, didn’t think it thru
        because your events are full day (no time)
        DTSTART;VALUE=DATE:20241216
        there is no duration
        we do not show end for full day events
        we could, but don’t
        if (this.config.showEnd) {
        	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
        	    // no duration here, don't display end
        	} else {
        //----- we do this
        		timeWrapper.innerHTML += "-";
        			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
        	// For full day events we use the fullDayEventDateFormat
        	if (event.fullDayEvent) {
                	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
        	       event.endDate -= ONE_SECOND;
        /// then change the display of both to just the start
                       timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
          sdetweil @blvk
          @blvk I just added this to the next release calendar
          you can get my test version and try it out
          see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
          if showEnd:true, and start date is different then end date, then
          add end date on using dateEndFormat
          — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
          evroomE 1 Reply Last reply Reply Quote 0
          • evroomE Offline
            evroom @sdetweil
            At first sight I do not like it too much.
            Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
            And that makes it pretty crowded in the date/time column.
            IMHO :-)
            timeFormat: "absolute",
            showEnd: true,
            showEndsOnlyWithDuration: true,
            //dateEndFormat: "HH:mm",
            dateEndFormat: "dddd MMM D - HH:mm",
            I currently have
            but
            showEndsOnlyWithDuration: false,
            does not seem to do anything.
            showEnd: false,
            //dateEndFormat: "dddd MMM D - HH:mm",
            Regards,
            E.J.
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
              sdetweil @evroom
              @evroom thanks… that was what I was afraid of
              can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
              							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
              • evroomE Offline
                evroom @sdetweil
                calendar.js
                ~/MagicMirror/modules/default/calendar/calendar.js
                showEnd: true,
                showEnd: false,
                Test environment:
                  sdetweil @evroom
                  @evroom that looks better , is it better?
                  only w duration only applies to date-time events
                  but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
                  its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
                    @evroom
                    so try this , new line 437. only show end if the end date is different than the start date
                    if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
                    • evroomE Offline
                      evroom @sdetweil
                      In short, I think it is looking better now.
                      To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
                      The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
                      In my examples I only see a change when I toggle ‘showEnd’.
                      urgency: 0,
                      dateFormat: "dddd MMM D - HH:mm",
                      fullDayEventDateFormat: "dddd MMM D",
                      showEnd: true,
                      getRelative: 0,
                      showEnd: true,
                      showEnd: false,
                      showEnd: false,
                      Test environment:
                        sdetweil @evroom
                        @evroom
                        you don’t have a full day event across multiple days NOT repeating
                        example
                              vacation mon-friday allday 1 NON-repeating event
                        repeating are handled differently
                        show start, but not repeating end
                        with sliceMultiDayEvents:true, // for REPEATING only (1 day event 5 times)
                           see each day of repeating
                               1/5
                               2/5
                               3/5
                               5/5
                        then next day
                               2/5
                               etc
                        @evroom said in Cant use showEnd icloud cal:
                        sorry, don’t understand this, I thought prior note said TIME display on fullday events was wrong… endFormat is for events with time (IMHO)
                        ok, the code here is
                        					// Add end time if showEnd
                        						} else {
                        BUT,
                        immediately AFTER this is the test for fullday events, which changes the timeWrapper
                        So, this would ONLY apply
                        not-fullday
                        not repeating
                        event start on Monday:20:00:end on Tuesday:6:00 sleep over at Bobs
                        I see the bug… testing 2 things to together
                        • 3 / 3
