    Cant use showEnd icloud cal
    30 Posts 3 Posters 3.8k Views 3 Watching
      sdetweil @evroom
      @evroom that looks better , is it better?
      only w duration only applies to date-time events
      but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
      its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
        @evroom
        so try this , new line 437. only show end if the end date is different than the start date
        if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
        evroomE 1 Reply Last reply Reply Quote 0
        • evroomE Offline
          evroom @sdetweil
          In short, I think it is looking better now.
          To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
          The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
          In my examples I only see a change when I toggle ‘showEnd’.
          urgency: 0,
          timeFormat: "absolute",
          dateFormat: "dddd MMM D - HH:mm",
          dateEndFormat: "HH:mm",
          fullDayEventDateFormat: "dddd MMM D",
          showEnd: true,
          showEndsOnlyWithDuration: true,
          getRelative: 0,
          showEnd: true,
          showEndsOnlyWithDuration: false,
          showEnd: false,
          showEnd: false,
          MagicMirror version: 2.33.0
          Test environment:
          MagicMirror version: v2.33.0
            sdetweil @evroom
            @evroom
            you don’t have a full day event across multiple days NOT repeating
            example
                  vacation mon-friday allday 1 NON-repeating event
            repeating are handled differently
            show start, but not repeating end
            with sliceMultiDayEvents:true, // for REPEATING only (1 day event 5 times)
               see each day of repeating
                   1/5
                   2/5
                   3/5
                   5/5
            then next day
                   2/5
                   etc
            @evroom said in Cant use showEnd icloud cal:
            sorry, don’t understand this, I thought prior note said TIME display on fullday events was wrong… endFormat is for events with time (IMHO)
            ok, the code here is
            					// Add end time if showEnd
            					if (this.config.showEnd) {
            						if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
            							// no duration here, don't display end
            						} else {
            							timeWrapper.innerHTML += "-";
            							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
            BUT,
            immediately AFTER this is the test for fullday events, which changes the timeWrapper
            So, this would ONLY apply
            not-fullday
            not repeating
            event start on Monday:20:00:end on Tuesday:6:00 sleep over at Bobs
            I see the bug… testing 2 things to together
              @evroom
              change lines 415 —
              				if (this.config.timeFormat === "absolute") {
              					// Use dateFormat
              					timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
              						if (event.startDate !== event.endDate) {
              							//  duration here, display end if requested
              						  if(this.config.showEndsOnlyWithDuration){
              					// For full day events we use the fullDayEventDateFormat
              					if (event.fullDayEvent) {
              • evroomE Offline
                evroom @sdetweil
                Sorry, do not want to cause confusion.
                One should probably not do a quick test right after a full working day:-)
                The number of test cases seems endless.
                Do I remove the earlier changes ((lines 437 and 439) before changing line 415 ?
                Test environment:
                  sdetweil @evroom
                  indeed… calendar is a tricky beast
                  no… the end of this change is just before the prior , match up that last line
                  working on getting this into the update now, creating testcases!
                    sdetweil
                    I have posted an updated fixcaldates2
                    this also resolves the showEndsOnlyWithDuration
                    and adds support for showEnd:true with full day events (non-repeating)
                    like vacation mon-fri, all day
                    just
                    git pull
                    to update…
                    this is my fork, not the official pull request at this time
                    if you are just getting this for the 1st time. do
                    git clone https://github.com/sdetweil/MagicMirror.git newmm
                    cd newmm
                    git checkout fixcaldates2
                    npm run install-mm
                    • evroomE Offline
                      evroom @sdetweil
                      Sam,
                      The option showEndsOnlyWithDuration is not described yet on https://docs.magicmirror.builders/modules/calendar.html.
                      The interaction / dependancy with showEnd also needs to be documented.
                      I do not know if documentation issues also can / should be done on https://github.com/MagicMirrorOrg/MagicMirror.
                      Test environment:
                      evroomE S 2 Replies Last reply Reply Quote 0
                      • evroomE Offline
                        evroom @evroom
                        Sam,
                        Whilst testing your last changes, I sort of see a need for a new date format parameter.
                        For an event with duration, spanning multiple days.
                        E.g. spanningDayEventDateFormat.
                        [TestCal: TIMESPAN_HOLIDAY]
                        BEGIN:VEVENT
                        DTSTART:20241125T110000Z
                        DTEND:20241127T160000Z
                        DTSTAMP:20241026T091719Z
                        UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
                        CREATED:20241026T090035Z
                        LAST-MODIFIED:20241026T090035Z
                        SEQUENCE:0
                        STATUS:CONFIRMED
                        SUMMARY:TestCal: TIMESPAN_HOLIDAY
                        TRANSP:OPAQUE
                        END:VEVENT
                        For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
                        [TestCal: OVERNIGHT_FLIGH]
                        BEGIN:VEVENT
                        DTSTART:20241202T190000Z
                        DTEND:20241203T030000Z
                        UID:0s4flhmaf7p6q5atemshns4upp@google.com
                        CREATED:20241026T090148Z
                        LAST-MODIFIED:20241026T090215Z
                        SEQUENCE:0
                        STATUS:CONFIRMED
                        SUMMARY:TestCal: OVERNIGHT_FLIGHT
                        TRANSP:OPAQUE
                        END:VEVENT
                        The reasoning behind it is following:
                        For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
                        That is why I normally use dateEndFormat: "HH:mm".
                        But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
                        dateFormat: “ddd MMM D - HH:mm”
                        dateEndFormat: “HH:mm”
                        fullDayEventDateFormat: “ddd MMM D”
                        [good for normal events, ‘bad’ for spanning events]:
                        dateEndFormat: “ddd MMM D - HH:mm”
                        [‘bad’ for normal events, good for spanning events]:
                        I hope I could explain it well enough.
                        And that it makes sense. :-)
                        Best regards,
                        E.J.
                        Test environment:
                        • 2 / 3
