    Cannot get MMM-EmbedURL to show any sites
    14 Posts 3 Posters 3.0k Views 3 Watching
    • U Offline
      unaccomplished
      Rapsberry Pi 4, MagicMirror v2.29.0
      I have a week-old install working for all modules except MMM-EmbedURL. I am trying to get two, local ip cams to display a feed over http. These feeds work fine in the Chromium desktop browser. Here’s an example of a URL:
      http://10.0.0.51:50081/ui3.htm?t=live&cam=Doorbell&maximize=1
      I have tried other URLs, including the examples, but nothing shows up, not even an error. This is the last module to load for me, and no errors are present for any module. There are not any other broadcasts or messages related to this module afterwards. The header used does appear, confirming the module is loaded.
      [LOG]   Connecting socket for: MMM-EmbedURL
      In case there are any known issues with other modules, here’s a list of what’s installed and working, across 4 different pages with MMM-pages:
      WallberryTheme
      WB-clock
      WB-weather
      MMM-CalendarExt3Journal
      alert
      updatenotification
      clock
      MMM-homeassistant-sensors
      MMM-CalDAV
      Pinfo
      calendar
      MMM-Pir
      MMM-MoonPhase
      MMM-NHL
      MMM-MyStandings
      MMM-EasyPix.
      MMM-BGSS_1 (copy/tweak of MMM-BackgroundSlideshow)
      MMM-GroveGestures
      MMM-NotificationTrigger
      MMM-EmbedURL
      Here’s the top of my config.js, as well as the relevant module configuration:
      let config = {
              electronOptions: {
                      webPreferences: {
                              webSecurity: false,
                              webviewTag: true,
                      fullscreen: true,
                      alwaysOnTop: true,
      and
                             module: "MMM-EmbedURL",
                             position: "upper_third",
                             header: "Embed-URL",
                                     updateInterval: 120,
                                     embedElementType: "webview",
                                     attributes: [
                                             "frameborder=0",
                                     embed: [
                                             "http://10.0.0.51:50081/ui3.htm?t=live&cam=Doorbell&maximize=1",
                                             "https://www.youtube.com/embed/dIHr96KqfDI",
      I’d appreciate any help on this, and let me know if there’s something else I can add or provide to resolve.
      S wishmaster270W 2 Replies Last reply Reply Quote 0
      • U Offline
        unaccomplished @unaccomplished
        @wishmaster270
        Just went back in and realized these were commented out in my config.
        ignoreXOriginHeader: true,
        ignoreContentSecurityPolicy: true,
        I added them back in, and success! Now to find a way to config the page to not need a login, but its huge progress. Thanks!
          sdetweil @unaccomplished
          @unaccomplished can you look at the messages where you start MagicMirror
          if you are using pm2, then
          pm2 logs --lines=50
          may show them
          typically I recommend NOT using pm2 when adding and changing modules as it makes access to the logs harder…
          I see
          [2024-12-03 16:48:09.041] [ERROR] (node:2137989) electron: Failed to load URL: https://www.cnn.com/?timestamp=1733266088 with error: ERR_BLOCKED_BY_RESPONSE
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [2024-12-03 16:48:09.482] [ERROR] (node:2137989) electron: Failed to load URL: https://magicmirror.builders/?timestamp=1733266088 with error: ERR_BLOCKED_BY_RESPONSE
          S U 2 Replies Last reply Reply Quote 0
            @unaccomplished
            I put one of my MM web pages in the embed list and it also doesn’t show… altho the embed content is in the MM elements page view
            and the page works correctly when viewed in a browser (the page is hosted by MM)
            never tried the module before
            • wishmaster270W Offline
              wishmaster270 Module Developer @unaccomplished
              @unaccomplished
              just tried your config in my setup and everything worked as expected.
              The question is…where are the differences in your and mine setup.
              As a first try you can replace embedElementType: "webview," with embedElementType: "iframe,".
              If the embeded pages does not block embedding iframe should work and you do not weaken any security settings of the electron browser.
              Additionally you can replace "frameborder=0", with "frameborder=1",. You should see two boxes at least then. Even if the sites could not be embedded.
              @sdetweil Are you sure you set the security settings of electron? Without them electron will not support webview and will not display anything.
              S U 2 Replies Last reply Reply Quote 1
                sdetweil @wishmaster270
                @wishmaster270 said in Cannot get MMM-EmbedURL to show any sites:
                no… I viewed that as optional if doing webview…(electron javascript content) but I am viewing an html page. (altho hosted by MM)
                If do use the build in electron browser to view the mirror you can use Webview instead
                my config
                    attributes: [
                        "frameborder=0",
                    embed: [
                        "http://localhost:8090/modules/MMM-Config/review/",
                        "https://cnn.com"
                • U Offline
                  unaccomplished @sdetweil
                  @sdetweil said in Cannot get MMM-EmbedURL to show any sites:
                  pm2 logs --lines=50
                  It seems this is the most relevant error in the log:
                  /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  Here are my error logs:
                  /home/MagicMirrorPi/.pm2/logs/MagicMirror-error.log last 50 lines:
                  0|MagicMir | [2100:1204/174503.791282:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.791659:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.791914:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.792304:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.792571:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.794953:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.795270:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.797663:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.799569:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.801781:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.805922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.809880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.810094:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.810464:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.810645:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.810893:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.811059:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.811276:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2100:1204/174503.811427:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  0|MagicMir | [2024-12-04 17:52:52.959] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-clock/WallberryTheme/WB-clock.js found for module: WB-clock.
                  0|MagicMir | [2024-12-04 17:52:52.966] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-weather/WallberryTheme/WB-weather.js found for module: WB-weather.
                  0|MagicMir | [2061:1204/175303.171404:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.171830:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.172059:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.173512:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.173776:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.173859:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174003:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174110:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174246:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174329:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174452:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174522:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174643:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.174716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.175789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.177938:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.178289:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.178399:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.178547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.178626:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.182442:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.183828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184177:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184326:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184401:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184533:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  0|MagicMir | [2061:1204/175303.184607:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  The two wrapper errors and the two Wallberry warnings have been perpetual, but don’t seem to affect anything. If you have any insight on these, I’d appreciate it.
                  I also noted this from the out-put log:
                  0|MagicMir | ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                  0|MagicMir | [2024-12-04 17:53:26.965] [LOG]   Electron's cache successfully cleared.
                  and later in the same log:
                  0|MagicMir | [2024-12-04 17:53:34.199] [INFO]  Checking git for module: MMM-EmbedURL
                  0|MagicMir | [2024-12-04 17:53:34.289] [LOG]   resizing done!
                  I don’t think these are errors, at least not in the context provided.
                  • U Offline
                    unaccomplished @wishmaster270
                    @unaccomplished
                    I updated the config as requested, once without, and then with “iframe”.
                                                   embedElementType: "iframe",
                                                   attributes: [
                                                           "frameborder=1",
                                                   embed: [
                    Without switching to iframe, the frameborder made no difference. Now with iframe, I have two blank boxes appearing.
                      @unaccomplished I agree, not the errors I was seeing…
                      so @wishmaster270 will have to help more
                        @unaccomplished your code markers MUST start in column 1.
                        U 1 Reply Last reply Reply Quote 0
                        • U Offline
                          Sorry, is it a formatting error in my comments, or in my config file?
                            @wishmaster270 Mine was a user error
                            I had MMM-Pages enabled, and EmbedURL was not on any page… oops…
                            the MM page embedded and cnn did not…
                            • U Offline
                              @wishmaster270
                                @unaccomplished its where the cursor is when you click the </> button
                                must be on the start of the line
                                U 1 Reply Last reply Reply Quote 1
                                • U Offline
                                  Got it. Thank you for your continued help!
