    Electron quit periodically
    26 Posts 3 Posters 6.1k Views 4 Watching
      sdetweil @jefftse
      @jefftse please use code marker around logs and config
      paste the text into the forum editor, blank line above and below
      select the text you pasted
      push the </> button
      as I said, I don’t SEE anything causing this…
      but…
      only way is to disable one module at a time to see if we can find it
      add
      disabled:true,
      after the module: line
      J 1 Reply Last reply
      • J
        jefftse @sdetweil
        @sdetweil I might have found the problem. it’s the backgroundslideshow. I disabled resizing and it hasn’t crashed yet. we will report again!
        S karsten13K 2 Replies Last reply
          sdetweil @jefftse
          @jefftse cool…
          • karsten13K
            karsten13 @jefftse
            @jefftse
            I deleted your config posted above because you published all your secrets in it …
            Reply Quote 1
            • J
              jefftse @karsten13
              @karsten13 Ha! thank you!!! i totally overlooked it!! appreciated it!
              • J
                jefftse @sdetweil
                my setup is pretty simple.
