    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 36.5k Views 10 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx on weather see this
      https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
        angeliKITTYx @sdetweil
        @sdetweil so I decided to do a clean install of my MM, and the timezone thing fixed itself. However, it’s still not displaying all of my calendars. Two show up immediately, one shows up after the refreshinterval, and the rest don’t show up at all. I tried re-entering all of the private ical URLs, but those didn’t change anything. The log still shows it’s pulling x events from each URL, but they’re not displaying. Did you still want me to email you the logs?
          @angeliKITTYx no you fixed the event date problem
          so another test is to add a position to the default cal module and see if you see the events there
          you did npm install in the ext3 module folder right?
          he has a sub module that needs to be installed
            @angeliKITTYx and another question. how did you upgrade?
            you on pi or windows or?
              @sdetweil It’s on pi.
              I used these instructions, and I also did the “Not Working?” section.
                @angeliKITTYx no, i meant upgrade MagicMirror
                A 2 Replies Last reply Reply Quote 0
                  @sdetweil I deleted it off my Pi and then followed the Manual Install. Then I reinstalled all of my modules. It was a fresh install - I didn’t upgrade it.
                      @angeliKITTYx i meant before, when you had the troubles
                        @sdetweil I used the command on the MM documents page
                        git pull && npm run install-mm
                        But I always had to remove the package-lock.json and package.json too
                        S A 2 Replies Last reply Reply Quote 0
                          @angeliKITTYx ok… I wish more would use my upgrade script…
                          it fixes problems you all report as we go along…
                          C A 2 Replies Last reply Reply Quote 0
                            angeliKITTYx @angeliKITTYx
                            @angeliKITTYx said in Version 2.30.0 Calendar fix for clipping broadcast events:
                            I just tried it now and it’s not working since I’m in the fix clipping branch. It’s asking me to confirm branch.
                              @angeliKITTYx yes,
                              there are new steps if on a non-master branch
                              rm package-lock.json
                              git checkout master
                              but you have lost the clipping fix (or develop branch)
                              my upgrade script will put you back on master (seen as how thats where next release will land you)
                              in the meantime, you should not need to pull again on current version, nothing changed
                              if u want to npm install MM again (altho nothing has changed)
                              do
                              npm run install-mm
                              • C Offline
                                cheminge @sdetweil
                                @sdetweil Where is the new script? I can’t find it in your posts…
                                  sdetweil @cheminge
                                  @cheminge all my stuff is here
                                  https://github.com/sdetweil
                                  install/upgrade ( referenced in the MagicMirror install doc , alternatives)
                                  backup/restore
                                    @sdetweil not sure what happened, but I added events to the calendars that weren’t showing up to try and troubleshoot, and now they’re all populated properly… Thanks for all your help with this. Now it’s on to fixing the weather widget.
                                      Dexter1088 @sdetweil
                                      Patch works perfect on Raspberry pi 3 B+, TYSM.
                                      • T Offline
                                        Tiller
                                        the Ext3 module is showing events but only on 7 days including today. All following events are missing, although they show up in the default calendar module.
                                        I installed the fix, but the error is still there.
                                        Does anyone have an idea?
        module: "MMM-CalendarExt3",
        position: "bottom_bar",
        title: "",
        waitFetch: 5000,
        mode: "week",
        weekIndex: 0,
        weeksInView: 3,
        instanceId: "basicCalendar",
        locale: "de-DE",
        maxEventLines: 5,
        firstDayOfWeek: 1,
        calendarSet: ['Family'],
                                        Best
                                        Till
                                          sdetweil @Tiller
                                          @Tiller
                                          Can you show the calendar config, xxx out the url
                                          • T Offline
                                            Tiller
                                            This is my config of the default calendar module:
        header: "Calendar",
        url: "xxx"
        auth: {
        user: 'user',
        pass: 'password'
                                            • 3 / 4
