    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 19.7k Views 4 Watching
      sdetweil @emlowe
      @emlowe as you updated to the develop branch, did you also redo the npm run install-mm
      • emloweE Offline
        emlowe Module Developer
        I did yes - so the current test results are this
        The calendar did eventually appear - but it took quite some time - I wasn’t watching, so I don’t know when exactly - I’ll test again. But it was several minutes after the log output of “broadcasting 22 events”
          sdetweil @emlowe
          @emlowe the default for ext3 is 30 mins
          if missed at waitFetch
          only see the timing in
          pm2 log
          default calendar working, right?
          emloweE 1 Reply Last reply Reply Quote 0
          • emloweE Offline
            emlowe Module Developer @sdetweil
            @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
            it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
            [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
            [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
            [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
            [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
            [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
            [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
            [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
            [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
            still says Loading ... - if I refresh the browser page - then they all appear immediately
              sdetweil @emlowe
              @emlowe can you extract those events out to a file
              curl -sL theurl >somefile.txt
              and share the file and your calendar config in an email to me
              same userid at gmail
              so i can look at it
              one other thing is open the developers window console tab
              ctrl-shift-i, select the console tab
              or do
              npm run start:dev
              and see if there are any errors
              the browser side broadcasts so it GOT the events block
              then it processes for the ui
              • emloweE Offline
                @sdetweil No errors in the console log
                If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
                maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
                  sdetweil @emlowe
                  @emlowe yes, and new code takes longer than old with lots of events
                  what is the calendar refreshinterval
                  • emloweE Offline
                    @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                    the calendar module doesn’t have refreshinterval does it?
                      sdetweil @emlowe
                      @emlowe fetchInterval is same
                      • emloweE Offline
                        I added various log outputs to node_helper.js and calendar.js
                        node_helper is sending the socket notification for CALENDAR_EVENTS
                        this is not received by the front end code in calendar.js
                        I don’t know what happens to it, but I added logging to print out in calendar.js whenever the socketNotificationReceived handler is called and it doesn’t print.
                        (unless I refresh the page - at which point it does)
                        emloweE S 3 Replies Last reply Reply Quote 0
                        • emloweE Offline
                          emlowe Module Developer @emlowe
                          Something even stranger - if I immediately refresh the page it also works. Here I mean is:
                          npm run server
                          got to browser and bring up host:8080
                          calendar will say “Loading” for a very long time
                          (despite the events getting broadcast)
                          But if I :
                          npm run server
                          go to browser and bring up host:8080
                          calender says “Loading”
                          Refresh the page immediately
                          calendar says “Loading”
                          calendar will immediately show the events as soon as the events are broadcast
                            sdetweil @emlowe
                            @emlowe oh, “cool” ugh, i opened an issue about that last year
                            just reopened
                            https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
                            can you add the contents of your post in an comment
                            actually this one
                            https://forum.magicmirror.builders/topic/19345/mmm-calendarext3-only-one-calendar-not-updating/30?page=3#
                              MMRIZE
                              Hmmm… I was in our traditional ceremony with my family - a lunar new year, so I couldn’t catch this post. Sorry.
                              Anyway, this symptom is not my module’s fault, right? There were some reports similar to this, but not figured out.
                                sdetweil @emlowe
                                @emlowe can you try this , configure bigger socketio buffer
                                see the post in the issue
                                https://github.com/MagicMirrorOrg/MagicMirror/issues/3380#issuecomment-2645778523
                                  ok, that didnt help
