    MagicMirror not working after upgrade
    17 Posts 4 Posters 3.9k Views 4 Watching
    • P Offline
      pat59
      hello after launching this link here is the message I get what should I do thank you.
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      atrick@raspberrypi:~ $ cd ~/MagicMirror
      patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
      $$$$$$ $$ | _
      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
      _
      | _
      | _
      | _
      $$ |_| _
      |_| _|_|_| __| _
      / _| _______|
      _
      ____/
      install log being saved to /home/patrick/install.log
      Updating packages …
      Installing helper tools …
      Check current Node installation …
      Node currently installed. Checking version number.
      Minimum Node version: v20.18.1
      Installed Node version: v20.9.0
      Node should be upgraded.
      A Node process is currently running. Can’t upgrade.
      Please quit all Node processes and restart the installer.
      patrick 1341 1206 0 14:31 ? 00:00:00 sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js patrick 1342 1341 49 14:31 ? 00:02:35 node ./node_modules/.bin/electron js/electron.js patrick 1361 1342 32 14:31 ? 00:01:40 /home/patrick/MagicMirror/node_modules/electron/dist/electron js/electron.js patrick 1366 1361 0 14:31 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox patrick 1367 1361 0 14:31 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 1369 1367 0 14:31 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 1398 1366 0 14:32 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --field-trial-handle=0,i,6854488977601974808,15412565450821572008,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 1402 1361 0 14:32 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,6854488977601974808,15412565450821572008,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 1409 1398 0 14:32 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=broker
        sdetweil @pat59
        @pat59 said in electron:
        yes, that is MagicMirror
        from package.json, for npm start (as seen on 2.30.0)
        "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
        you have to shutdown MagicMirror before upgrading
        I don’t know what it is in the script, I just know that something is using nodejs and I have to upgrade it,
        so it/they all have to stop
        • P Offline
          pat59
          patrick@raspberrypi:~ $ cd ~/MagicMirror
          patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
          the log will be saved in /home/patrick/MagicMirror/installers/pm2_setup.log
          [PM2][WARN] Applications MagicMirror not running, starting…
          [PM2] App [MagicMirror] launched (1 instances)
          │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
          │ 0 │ MagicMirror │ default │ 2.30.0 │ fork │ 2906 │ 0s │ 0 │ online │ 0% │ 2.5mb │ patrick │ enabled │
          [PM2] Saving current process list…
          [PM2] Successfully saved in /home/patrick/.pm2/dump.pm2
          patrick@raspberrypi:~/MagicMirror $ npm start
          magicmirror@2.30.0 start
          npm run start:x11
          magicmirror@2.30.0 start:x11
          [2025-01-22 15:57:16.896] [ERROR] App threw an error during load
          [2025-01-22 15:57:16.904] [ERROR] Error: Cannot find module ‘undici’
          Require stack:
          • /home/patrick/MagicMirror/js/app.js
          • /home/patrick/MagicMirror/js/electron.js
            at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
            at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
            at Module._resolveFilename (/home/patrick/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module._load (node:internal/modules/cjs/loader:908:27)
            at c._load (node:electron/js2c/node_init:2:13672)
            at Module.require (node:internal/modules/cjs/loader:1122:19)
            at require (node:internal/modules/helpers:130:18)
            at Object. (/home/patrick/MagicMirror/js/app.js:15:40)
            at Module._compile (node:internal/modules/cjs/loader:1256:14)
            at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
            at Module.load (node:internal/modules/cjs/loader:1098:32)
            at Module._load (node:internal/modules/cjs/loader:945:12)
            at Object. (/home/patrick/MagicMirror/js/electron.js:4:14)
            A JavaScript error occurred in the main process
            Uncaught Exception:
            Require stack:
            sdetweil @pat59
            @pat59 in the 1st above
            you are already running MM
            so you should use the upgrade script… not install
            this is install
            install should have aborted, cause you already have MM
            can you show me ~/install.log
            then you run the two upgrade scripts, one test and (if all is ok with test) then execute, two different copy/paste
            can you show me ~/MagicMirror/installers/upgrade.log
            the error means your nodejs did NOT get updated.
            but somehow the new MM code was installed…
            • P Offline
              pat59
              patrick@raspberrypi:~ $ cd ~/install.log
              bash: cd: /home/patrick/install.log: N’est pas un dossier
              • P Offline
                pat59
                patrick@raspberrypi:~ $ cd ~/MagicMirror/installers/upgrade.log
                bash: cd: /home/patrick/MagicMirror/installers/upgrade.log: N’est pas un dossier
                • P Offline
                  pat59
                  patrick@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                  $$$$$$ $$ | _
                  _
                  | _
                  | _
                  | _
                  $$ |_| _
                  |_| _|_|_| __| _
                  / _| _______|
                  _
                  ____/
                  Updating packages …
                  patrick 1987 1972 0 16:19 ? 00:00:00 sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js patrick 1988 1987 0 16:19 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js patrick 1998 1988 0 16:19 ? 00:00:04 /home/patrick/MagicMirror/node_modules/electron/dist/electron js/electron.js patrick 2001 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox patrick 2002 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2004 2002 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2040 2001 0 16:19 ? 00:00:01 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --field-trial-handle=0,i,12195679081471275551,8574617561069742386,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2046 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,12195679081471275551,8574617561069742386,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2070 2040 0 16:20 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=broker patrick 2082 2060 0 16:20 pts/0 00:00:00 sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js patrick 2083 2082 0 16:20 pts/0 00:00:00 node ./node_modules/.bin/electron js/electron.js patrick 2093 2083 0 16:20 pts/0 00:00:03 /home/patrick/MagicMirror/node_modules/electron/dist/electron js/electron.js patrick 2096 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox patrick 2097 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2099 2097 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2129 2096 0 16:20 pts/0 00:00:01 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --field-trial-handle=0,i,3246569436277859428,16865193471212064356,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2131 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,3246569436277859428,16865193471212064356,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2138 2129 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=broker
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                  update log will be in /home/patrick/MagicMirror/installers/upgrade.log
                  doing test run = true, NO updates will be applied!
                  MagicMirror running under control of PM2, stopping
                    sdetweil @pat59
                    ok, you have install.log (not cd, cat to dump out contents, or nano to edit and view contents)
                    you DIDN’T have upgrade.log as you hadn’t run upgrade yet
                    things to know
                    1. install WILL NOT install OVER an existing MM system… you do NOT need me to screw up your setup
                    2. upgrade is dangerous, so I provide TWO paths
                      a . test for anything dangerous, lose files, lose changes, whatever … BUT DO NOT CHANGE ANYTHING
                      b. EXECUTE the upgrade, make changes,
                      the script for 2 (upgrade) is the same for and and b, but no parameters for test, and apply parameter for execute
                      (I provide 2 links so you don’t have to remember)
                    but, I still don’t know how you got the code installed…
                    did you do the manual upgrade attempt first
                       git pull && npm run install-mm
                    and it failed (cause you don’t have the right version of nodejs installed…)
                    SO, there is ONE more step
                    copy/paste the execute link
                    BUT change the word
                    apply
                    to
                    force
                    I don’t document this one as I don’t want people using it accidentally
                    now, please excuse my rudeness here… I see french is your native language…, you DO know you can TRANSLATE my module readme page, in the browser, right?
                    and if you do so and still don’t understand what I wrote, I am happy to make corrections that would make things more clear. I appreciate your input, I want to make this safe and reliable and easy to use
                    we can take that discussion offline. If you write to me in french I will translate and return my response in french
                    • P Offline
                      pat59
                      merci pour votre gentillesse je suis novice désolé de prendrez de votre temps encore merci
                      voila ce que je viens de faire pour la mise a niveau.
                      patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                      Node.js upgrade defered, doing test run
                      Check current NPM installation …
                      NPM currently installed. Checking version number.
                      Minimum npm version: V10.8.2
                      Installed npm version: V10.1.0
                      npm should be upgraded.
                      npm upgrade defered, doing test run …
                      saving custom.css
                      (23) Failed writing body
                      upgrading from version 2.30.0 to 2.30.0
                      fetching latest revisions
                      Checking for modules with removed libraries
                      updating dependencies for active modules with package.json files
                      processing for module MMM-Remote-Control please wait
                      skipped processing for MMM-Remote-Control, doing test run
                      processing complete for module MMM-Remote-Control
                      processing for module MMM-Saint please wait
                      skipped processing for MMM-Saint, doing test run
                      processing complete for module MMM-Saint
                      processing for module MMM-network-signal please wait
                      skipped processing for MMM-network-signal, doing test run
                      processing complete for module MMM-network-signal
                      processing for module MMM-FlipClock please wait
                      skipped processing for MMM-FlipClock, doing test run
                      processing complete for module MMM-FlipClock
                      processing for module MMM-BME280 please wait
                      skipped processing for MMM-BME280, doing test run
                      processing complete for module MMM-BME280
                      processing for module MMM-PrixCarburants please wait
                      skipped processing for MMM-PrixCarburants, doing test run
                      processing complete for module MMM-PrixCarburants
                      processing for module MMM-MeteoFrance please wait
                      skipped processing for MMM-MeteoFrance, doing test run
                      processing complete for module MMM-MeteoFrance
                      processing for module MMM-FranceInfo please wait
                      skipped processing for MMM-FranceInfo, doing test run
                      processing complete for module MMM-FranceInfo
                      processing for module MMM-SnowEffect please wait
                      skipped processing for MMM-SnowEffect, doing test run
                      processing complete for module MMM-SnowEffect
                      restoring custom.css
                        sdetweil @pat59
                        @pat59 c’est à nouveau le test.
                        — faire un test = true, AUCUNE mise à jour ne sera appliquée !—
                        vous avez besoin de la deuxième URL avec le mot « postuler » à la fin
                        et tu dois changer le mot
                        ‘appliquer’
                        à
                        ‘forcer’
                        veuillez utiliser les mots anglais ici, le traducteur ne m’a pas donné la possibilité de désactiver cela
                        nous sommes tous novices dans beaucoup de choses dans notre vie, nous apprenons tous à notre rythme. J’espère que mes outils nous faciliteront la tâche.
                        • P Offline
                          pat59
                          j ai fait la mise a niveau par smartphone RemoteControl.
                          patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” forcer
                          doing test run = false
                          installing correct version of node and npm, please wait
                          Installed Node version: v20.18.1
                          No Node.js upgrade necessary.
                          Installed npm version: V10.8.2
                          No npm upgrade necessary.
                          saving custom.css
                          updating MagicMirror runtime, please wait
                          magicmirror@2.30.0 postinstall
                          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                          magicmirror@2.30.0 install-vendor
                          echo "Installing vendor files …
                          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          added 1 package, and changed 2 packages in 12s
                          magicmirror@2.30.0 install-fonts
                          echo "Installing fonts …
                          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          Installing fonts …
                          changed 2 packages in 7s
                          magicmirror@2.30.0 prepare
                          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                          no husky installed.
                          added 479 packages in 3m
                          126 packages are looking for funding
                          run npm fund for details
                          added 49 packages, and audited 50 packages in 9s
                          13 packages are looking for funding
                          found 0 vulnerabilities
                          astuce: Tirer sans spécifier comment réconcilier les branches divergentes
                          astuce: est découragé. Vous pouvez éliminer ce message en lançant une des
                          astuce: commandes suivantes avant votre prochain tirage :
                          astuce:
                          astuce: git config pull.rebase false # fusion (stratégie par défaut)
                          astuce: git config pull.rebase true # rebasage
                          astuce: git config pull.ff only # avance rapide seulement
                          astuce:
                          astuce: Vous pouvez remplacer “git config” par “git config --global” pour que
                          astuce: ce soit l’option par défaut pour tous les dépôts. Vous pouvez aussi
                          astuce: passer --rebase, --no-rebase ou --ff-only sur la ligne de commande pour
                          astuce: remplacer à l’invocation la valeur par défaut configurée.
                          added 1 package, and audited 2 packages in 3s
                          added 1 package, and audited 2 packages in 4s
                          added 1 package, and audited 2 packages in 7s
                          astuce:
                          astuce:
                          astuce:
                          astuce:
                          astuce:
                          astuce:
                          up to date, audited 1 package in 2s
                            sdetweil @pat59
                            @pat59 bien … vous devriez pouvoir redémarrer MagicMirror maintenant
                            cela aurait dû apparaître lors du test
                            traitement pour le module MMM-Saint veuillez patienter
                            astuce : Tirer sans comment réconcilier les branches divergentes
                            Je ne sais pas pourquoi ils ne l’ont pas fait. je vais regarder ça
                            Je ne « mets pas à jour » les modules, seulement le MM de base
                              @pat59 ok, ces erreurs viennent du processus de mise à jour du module, il faudra que l’auteur les regarde
                              @bugsounet
                              pouvez-vous examiner pourquoi il a eu ces erreurs même si vous avez effectué la réinitialisation matérielle de git ?
                              ma mise à niveau appelée npm run update
                              bugsounetB 1 Reply Last reply Reply Quote 0
                              • P Offline
                                pat59
                                Wahoou je ne sais comment vous remercier cela fonctionne super content encore merci pour votre patience et gentillesse.
                                je sais faire la mise a jour d’ un module grace a votre contribution
                                mais ne sais pas faire quand il me demande la mise a jour de MagicMirror ?
                                je fait par Remote-Control mais je plante toujours le systeme
                                en vous remerciant encore pour tout
                                  sdetweil @pat59
                                  @pat59 >mais je ne sais pas quoi faire quand il me demande de mettre à jour MagicMirror ?
                                  Je le fais par télécommande mais je plante toujours le système
                                  exécutez toujours mon script.
                                  Heureusement que la télécommande vous permet de faire ça.
                                  sinon vous devrez vous connecter au système MM (ssh ou vnc) pour obtenir une fenêtre de terminal permettant de faire le même copier/coller de ma commande de script de mise à niveau
                                  vous sauvegardez votre système, n’est-ce pas ?
                                  sinon voir mes scripts de sauvegarde/restauration
                                  nous mettons à jour MagicMirror tous les 3 mois. vous n’êtes PAS obligé de prendre ces mises à jour.
                                  mais il semble que le message disparaisse, vous devez désactiver le module de notification de mise à jour
                                  ajouter
                                  désactivé : vrai,
                                  après l’entrée du nom de son module dans config.js
                                  • bugsounetB Offline
                                    bugsounet Banned @sdetweil
                                    @sdetweil said in MagicMirror not working after upgrade:
                                    @bugsounet
                                    Tous mes modules ont été retiré de la liste des modules tiers, et vont être supprimé de mon compte github.
                                    Je suis désolé @pat59, il donc faudra trouver un/des modules équivalent.
                                    Comme vous venez de comprendre, je me retire donc du projet MagicMirror² complètement.
                                    Bonne continuation,
                                    @bugsounet
                                      margouya @bugsounet
                                      @bugsounet said in MagicMirror not working after upgrade:
                                      @bugsounet
                                      Bonne continuation,
                                      @bugsounet
                                      C’est avec regret que j’apprends l’arrêt de votre projet
                                      J’avais quasi terminé ( tous était installé et presque terminé il me restait juste le token de Google assistant et tout était parfait)a une semaine près sa aurais été fini.
                                      Pourquoi ne pas avoir laissé les liens github sur le site ?
                                      C’est bien dommage mais vous avez fait un travail extraordinaire
                                      Merci encore
