    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 25.0k Views 8 Watching
    • M
      Mathes75 @karsten13
      @karsten13
      pi@magicmirrorMB:/opt/mm/run $ docker ps -a
      CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
      1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
      What? There must be something completely wrong…
      • M
        Mathes75 @karsten13
        @karsten13
        Is there a way to reload the images from scratch, delete them from the RPi without losing the customization?
        • karsten13K
          karsten13 @Mathes75
          @Mathes75
          really strange, the 1b1... is still there …
          try docker system prune -f and check after this again docker ps -a
          • M
            Mathes75 @karsten13
            @karsten13
            After docker compose down, prune resulted in Total reclaimed space: 0B .
            When trying to start the containers and running the commands:
            pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
            WARN[0000] No services to build
            [+] up 2/2
             ✔ Network magicmirror_default Created        0.2s
             ✔ Container mm                Created        0.5s
            Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b
            pi@magicmirrorMB:/opt/mm/run $ docker system prune -f
            Deleted Containers:
            b04e79ead19ae7e42b7c7899f8e9b4b2d4f870770362c684bfadbfdaae6725aa
            Deleted Networks:
            magicmirror_default
            Total reclaimed space: 4.096kB
            1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   9 days ago   Exited (128) 2 days ago
            I think the easiest way is to start from scratch. Save the config.js, remember the modules and just reinstall. Switch to fat image again and fiddle around with FRITZ stuff. Sorry for keeping you busy and thanks a lot for your help and patience!
            Let me know if you want to finish troubleshooting ;-)
            • karsten13K
              karsten13 @Mathes75
              @Mathes75
              one thing (if not already done) would be a reboot and then again the prune command.
              Otherwise start from scratch …
              • M
                Mathes75 @karsten13
                @karsten13
                To make it short - same. Will start from scratch and let you know.
                • M
                  Mathes75 @Mathes75
                  Short and final update on this - I give up.
                  Reimaged the card, edited the .env file before first start, so directly pulled the fat image. Set up my standard Modules, everything up and running - except MMM-FRITZ-BoxCallmonitor - and started to test mounts to map the fritzconnection Python scripts… as again, a strange container showed up:
                  pi@magicmirroros:/opt/mm/run $ docker compose up -d
                  [+] up 2/2
                   ✘ Container b053acabeef9 Error response from daemon: No such container: b053acabeef9f142eb3382656732bee6b75d549c10ec2ef80da27ec2c60946d6                                          2.2s
                   ✔ Container labwc        Recreated        2.2s
                  Now I am sure my trusty SDcard is corrupt. Thanks @karsten13 for all the troubleshooting and help! I have learned a lot around Docker last days.
                  Will get a new card and see some time. Other projects requiring my attention.
                  • M
                    MiPraSo @rkorell
                    @rkorell
                    Thank you for the adjustment. Now the pop-up window no longer freezes when calls are blocked. The installation worked as described here.
                    Regards,
                    Michael
                    • R
                      rkorell Module Developer @MiPraSo
                      @MiPraSo cool! thanks for this confirmation.
                      Glad to hear it works for you!
                      Regards,
                      Ralf
                      • 4 / 4
