    MMM-ioBroker - it will not show
    34 Posts 3 Posters 6.9k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hello everyone, I have had the MMM-ioBroker module installed for some time and it has always worked and displayed my Aquara temperature gauges…recently it has stopped displaying anything :-( the module is up to date.
      what can I do? what is wrong?
      mm@MagicMirror-live:~/MagicMirror$ git pull && npm run install-mm
      Already up to date.
      > magicmirror@2.31.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
      npm error notsup Required: {"node":">=22.14.0"}
      npm error notsup Actual:   {"npm":"10.8.2","node":"v20.18.1"}
      npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-09T19_49_38_299Z-debug-0.log
      what must i do? Im not the expert…how is the befehl for update npm?
      mm@MagicMirror-live:~/MagicMirror$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      update log will be in /home/mm/MagicMirror/installers/upgrade.log
      doing test run = true, NO updates will be applied!
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v22.14.0
      Installed Node version: v20.18.1
      Node should be upgraded.
      A Node process is currently running. Can't upgrade.
      Please quit all Node processes and restart the update.
      running process(s) are
      mm           304     271  0 Feb03 ?        00:00:00 sh -c node ./serveronly
      mm           305     304  0 Feb03 ?        01:28:58 node ./serveronly
        sdetweil @kusselin
        @kusselin you need to be at a different node js level
        22.14.0
        if you had used my upgrade script it would have handled that
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil is this o.k. so?
          Already up to date.
          > magicmirror@2.31.0 postinstall
          > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          > magicmirror@2.31.0 install-vendor
          > echo "Installing vendor files ...
          > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 1 package in 1s
          > magicmirror@2.31.0 install-fonts
          > echo "Installing fonts ...
          > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 2 packages in 4s
          > magicmirror@2.31.0 prepare
          > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          added 6 packages, removed 7 packages, and changed 193 packages in 34s
          Installed Node version: v22.14.0
          No Node.js upgrade necessary.
          Check current NPM installation ...
          NPM currently installed. Checking version number.
          Minimum npm version: V10.9.2
          Installed npm version: V10.9.2
          No npm upgrade necessary.
          saving custom.css
          upgrading from version 2.31.0 to 2.31.0
          MagicMirror running under control of PM2, stopping
          [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0  │ MagicMirror    │ default     │ 2.31.0  │ fork    │ 0        │ 0      │ 437  │ stopped   │ 0%       │ 0b       │ mm       │ disabled │
          fetching latest revisions
          Checking for modules with removed libraries
          updating dependencies for active modules with package.json files
                  processing for module MMM-Fuel please wait
                  skipped processing for MMM-Fuel, doing test run
                  processing complete for module MMM-Fuel
                  processing for module MMM-RNV please wait
                  skipped processing for MMM-RNV, doing test run
                  processing complete for module MMM-RNV
                  processing for module MMM-PublicTransportHafas please wait
                  skipped processing for MMM-PublicTransportHafas, doing test run
                  processing complete for module MMM-PublicTransportHafas
                  processing for module MMM-ioBroker please wait
                  skipped processing for MMM-ioBroker, doing test run
                  processing complete for module MMM-ioBroker
                  processing for module MMM-COVID19-AMPEL please wait
                  skipped processing for MMM-COVID19-AMPEL, doing test run
                  processing complete for module MMM-COVID19-AMPEL
                  processing for module MMM-soccer please wait
                  skipped processing for MMM-soccer, doing test run
                  processing complete for module MMM-soccer
                  processing for module MMM-Carousel please wait
                  skipped processing for MMM-Carousel, doing test run
                  processing complete for module MMM-Carousel
                  processing for module MMM-Remote-Control please wait
                  skipped processing for MMM-Remote-Control, doing test run
                  processing complete for module MMM-Remote-Control
          restoring custom.css
            sdetweil @kusselin
            @kusselin
            no
            • kusselinK Offline
              kusselin @sdetweil
              @sdetweil Sorry, but I don’t understand what you mean by test run?
              Suddenly the temperature is no longer displayed and I don’t know where the error lies?
              What do I have to do to get it working again?
              thank you thank you thank you
                sdetweil @kusselin
                @kusselin my upgrade script is 2 steps
                test, do nothing
                do
                same script, no parms is test
                add apply to the end does
                BUT, it will NOT install upgrades AGAIN if the version matches
                and you loaded the new code
                so you have to use the word
                force
                instead of
                apply
                please translate the page, instead of having trouble with my english
                • kusselinK Offline
                  kusselin @sdetweil
                  Hi sdetweil, thanks for your help. Since I am not a Linux expert I do everything with copy&paste…means also the installation of MM everything made by commands…
                  Can you please tell me the Linux commands I need to use to get it working again. thank you!
                  Or does it have something to do with Iobroker why the temp values are no longer displayed?
                  But in iobroker everything works with the Zigbee adapter.
                  I have not changed anything else in the config or anywhere else in MM
                  Please help me.
                    rkorell Module Developer @kusselin
                    Hi @kusselin , Sam is talking about parameters you can - and should - overhand to his update-script.
                    If you call the script - as is - without parameter the script only do a “test-run” and did not change anything.
                    The “normal” parameter to DO the upgrade is “apyly” for this the unix command is:
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -apply
                    Sam is assuming that you already HAVE done some upgrades - for this reason he states “and you loaded the new code” . IF you had already loaded some new versions the above command will “fail” also because you already HAVE the new version.
                    So for this case you have to use the “force” parameter.
                    The unix command for this is:
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" -force
                    Good luck!
                    Ralf
                      sdetweil @rkorell
                      @rkorell right, but the web page has the copy/paste commands already set up. so you just have to click copy on the correct line, you dont have to type anything
                      the ‘problem’ is that you tried the manual update way, which downloaded (git pull) the new MagicMirror version .
                      so when my upgrade script checks the version agsinst the github repo they match. oops
                      upgrade is so previous because you have a running system. iIdont want to destroy that. so i wont let upgrade run if you are slready at the same level.
                      you have to force it
                      in this case you take the do copy/paste, which has
                      apply
                      at the end
                      and change the to
                      force
                      i dont supply a copy/paste for that because i dont want people using it if its not needed,
                      iobroker is broken cause MagicMirror is in a weird state
                        @sdetweil said in MMM-ioBroker - it will not show:
                        valid point, but @kusselin seems to struggle :-)
                        Regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell i understand.
                          this is exactly why ive added the upgrade script.
                          the base requires system changes. not knowing or understanding can lead to this exact mess
                          but ive made install/upgrade a copy paste so there is no typo problems
                          using force is dangerous,
                          if you use my upgrade script EVERY time, then there will not be problems.
                            @sdetweil :-) For me this is pretty clear and obvious - in addition I do NOT perform every update/upgrade (“never touch a running system”) because I’m checking upfront if a new release brings in anything I potentially need.
                            But the thread opener is at least irritated and asks for commandlines to copy.
                            I assume the thread opener is aware that everything herein is “enter at your own risk”.
                            That you - as the script creator and owner - are even more cautious is appropriate and highly welcome and appreciated!
                            Ralf
                            • kusselinK Offline
                              kusselin @rkorell
                              @rkorell
                              Sorry everyone, I still don’t get it…when I run the upgrade command with -force then node and npm is up to date and I don’t get an error message.
                              Why does Iobroker with the Zigbee adapter suddenly stop displaying anything? Iobroker and the Zigbee adapter are running perfectly.
                                sdetweil @kusselin
                                @kusselin can you show the output of npm start , or if using pm2
                                pm2 logs --lines=100
                                • kusselinK Offline
                                  kusselin @sdetweil
                                  is the pm2 log located at
                                  /home/mm/.pm2
                                  and how do I create the output of npm start?
                                  mm@MagicMirror-live:~$ npm start
                                  npm error code ENOENT
                                  npm error syscall open
                                  npm error path /home/mm/package.json
                                  npm error errno -2
                                  npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/mm/package.json'
                                  npm error enoent This is related to npm not being able to find a file.
                                  npm error enoent
                                  npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_02_15_732Z-debug-0.log
                                  mm@MagicMirror-live:~$ cd MagicMirror
                                  mm@MagicMirror-live:~/MagicMirror$ npm start
                                  > magicmirror@2.31.0 start
                                  > npm run start:x11
                                  > magicmirror@2.31.0 start:x11
                                  sh: 1: ./node_modules/.bin/electron: not found
                                    sdetweil @kusselin
                                    @kusselin weird
                                    cd ~/MagicMirror
                                    npm install electron@35.1.2
                                    • kusselinK Offline
                                      kusselin @sdetweil
                                      sorry, please forget me :-(
                                      and now?
                                      cd ~/MagicMirror
                                      mm@MagicMirror-live:~/MagicMirror$ npm install electron@35.1.2
                                      added 654 packages in 20s
                                      285 packages are looking for funding
                                        run `npm fund` for details
                                        sdetweil @kusselin
                                        @kusselin npm start
                                        • kusselinK Offline
                                          kusselin @sdetweil
                                          look :-(
                                          npm error code ENOSPC
                                          npm error syscall write
                                          npm error errno -28
                                          npm error nospc ENOSPC: no space left on device, write
                                          npm error nospc There appears to be insufficient space on your system to finish.
                                          npm error nospc Clear up some disk space and try again.
                                          npm error A complete log of this run can be found in: /home/mm/.npm/_logs/2025-04-10T19_51_54_629Z-debug-0.log
                                          and
                                           verbose cli /usr/local/bin/node /usr/local/bin/npm
                                          1 info using npm@10.9.2
                                          2 info using node@v22.14.0
                                          3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
                                          4 silly config load:file:/home/mm/MagicMirror/.npmrc
                                          5 silly config load:file:/home/mm/.npmrc
                                          6 silly config load:file:/usr/local/etc/npmrc
                                          7 verbose title npm run start:x11
                                          8 verbose argv "run" "start:x11"
                                          9 verbose logfile logs-max:10 dir:/home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-
                                          10 verbose logfile /home/mm/.npm/_logs/2025-04-10T19_51_37_854Z-debug-0.log
                                          11 silly logfile start cleaning logs, removing 1 files
                                          12 silly logfile done cleaning log files
                                          13 verbose cwd /home/mm/MagicMirror
                                          14 verbose os Linux 6.8.12-8-pve
                                          15 verbose node v22.14.0
                                          16 verbose npm  v10.9.2
                                          17 verbose exit 1
                                          18 verbose code 1
                                            sdetweil @kusselin
                                            @kusselin ok, this typically indicates a failing sd card, happens too often
                                            backup now , but my backup wont work w no disk space
                                            copy config.js and custom.css to a someplace, network , usb stick, email
                                            get a list of all the modules
                                            cd ~/MagicMirror/modules
                                            ls -laF
                                            add that output to the place u saved
                                            make a new sd card, boot, install MagicMirror
                                            copy back config and css
                                            reinstall the modules
