    OpenWeatherForcast - AggregateError?
    18 Posts 2 Posters 2.8k Views 2 Watching
    • C Offline
      cricket
      New 1st time MM setup today. trying to use the jclarke MMM-OpenWeatherForecast module. I keep getting “MMM-OpenWeatherForecast] 5-May-25 18:28 ** ERROR ** AggregateError”. I have purchased the correct Open Call API and I can make web querry with success. Here is my simple module. Any help?
                        module: "MMM-OpenWeatherForecast",
                        header: "Forecast",
                          apikey: "XXXXXX", //SUPER SECRET
                          latitude: "23.073051",
                          longitude: "-41.401230"
        sdetweil @cricket
        @cricket you should use the updated version from Tom
        https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
        C 2 Replies Last reply Reply Quote 1
        • C Offline
          cricket @sdetweil
          @sdetweil Thank you for this - I may give that a go tomorrow.
            sdetweil @cricket
            @cricket always look thru the 3rd party list (linked above, got good search), take the newest of same name
              sdetweil @cricket
              @cricket should be rename the old, install the new.
              no required change in config
              • C Offline
                cricket @sdetweil
                @sdetweil Thanks for all your help. Installed this today - Still stuck at loading - this is the error I got.
                0|MagicMirror  | [2025-05-06 09:08:47.933] [ERROR] [MMM-OpenWeatherForecast] 6-May-25 09:08 ** ERROR ** TypeError: fetch failed
                0|MagicMirror  | TypeError: fetch failed
                0|MagicMirror  |     at node:internal/deps/undici/undici:13502:13
                0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
                I renamed the old MMM module prior to installation. I can make direct API calls in a browser using the API key provided. Not sure what to try now. Any help welcomed.
                  sdetweil @cricket
                  @cricket hmm… can you shown the startup info
                  like this from MM startup
                  ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                  ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-138-generic
                  ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                  ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
                  • C Offline
                    cricket @sdetweil
                    @sdetweil Thanks for all your help - here is what I have -
                    0|MagicMir | [2025-05-06 10:28:53.242] [INFO]  System information:
                    0|MagicMir | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
                    0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.25+rpt-rpi-v8
                    0|MagicMir | ### VERSIONS: electron: 35.2.2; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                    0|MagicMir | ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                      sdetweil @cricket
                      @cricket @wishmaster270 will have to reply
                      (I know he has been busy, so may take some time)
                      can you post your module config,
                      xxx out the apikey
                      and I can try it
                      • C Offline
                        cricket @sdetweil
                        @sdetweil Copy that - I have also tried the API web call on the pi browser - it works fine. I tried a couple of options.
                        Are you asking me to post the entire conifg.js?
                        Thanks.
                          sdetweil @cricket
                          @cricket no, only for this module…
                          I can recreate here with my apikey and location and see the working direct url
                          did take quite a while…
                          we have the fetch timeout set to 30 seconds, so that shouldn’t be it
                          • C Offline
                            cricket @sdetweil
                            I am going to reinstall the module as well to see if that works. Update: No change - still loading.
                                                    header: "Forecast",
                                                      apikey: "mykey", //only string here
                                                      latitude: 43.030099,            //number works here
                                                      longitude: -89.449056          //so does a string
                              sdetweil @cricket
                              @cricket the ‘Loading’ error means the front end (displaying data) is waiting for the data to arrive from the backend (node_helper.js)
                              almost NO module reports and handles critical failures like this.
                              so we asked for data, and nothing… still wating…
                              I upgraded nodejs, electron and still fails in same place.
                              • C Offline
                                cricket @sdetweil
                                I follow some of what you have said. Thanks for your help. Hopefully it is something that can be corrected.
                                • C Offline
                                  cricket @sdetweil
                                  @sdetweil said in OpenWeatherForcast - AggregateError?:
                                  Does this mean you are having the same issue I am?
                                    sdetweil @cricket
                                    @cricket yes, I said I could recreate your problem.
                                    https://forum.magicmirror.builders/post/126268
                                    C 1 Reply Last reply Reply Quote 1
                                    • C Offline
                                      cricket @sdetweil
                                      @sdetweil Not sure what happened, but it just started working for me… Now on to some configuration. Many thanks for all your help.
                                        sdetweil @cricket
                                        @cricket awesome!!
