    [ERROR] _ is not defined
    36 Posts 3 Posters 9.6k Views 3 Watching
    • N Offline
      nowayto
      I have an issue, appeared after MMM-SolarPicture installation but I don’t think it’s related to it. Maybe an error on my configuration.
      pm2 logs is this one below
      0|mm | [2025-05-08 21:00:29.772] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:00:29.826] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:01:53.233] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:01:53.327] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:03:16.264] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:03:16.440] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:04:39.584] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:04:39.676] [ERROR] _ is not defined
      0|mm | sh: 1: ./node_modules/.bin/electron: not found
      0|mm | sh: 1: sh: 1: ./node_modules/.bin/electron: not found
      0|mm | ./node_modules/.bin/electron: not found
      0|mm | > magicmirror@2.31.0-develop start
      0|mm | > npm run start:x11
      0|mm | > magicmirror@2.31.0-develop start:x11
      0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      PM2 | App [mm:0] exited with code [0] via signal [SIGINT]
      PM2 | App [mm:0] starting in -fork mode-
      PM2 | App [mm:0] online
      npm run config:check gave me that result:
      magicmirror@2.31.0-develop config:check
      node js/check_config.js
      node:internal/modules/cjs/loader:1228
      throw err;
      Error: Cannot find module ‘eslint’
      Require stack:
      • /home/MYMIRRORNAME/MagicMirror/js/check_config.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        at Module._load (node:internal/modules/cjs/loader:1051:27)
        at Module.require (node:internal/modules/cjs/loader:1311:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home/MYMIRRNAME/MagicMirror/js/check_config.js:6:20)
        at Module._compile (node:internal/modules/cjs/loader:1469:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1548:10)
        at Module.load (node:internal/modules/cjs/loader:1288:32)
        at Module._load (node:internal/modules/cjs/loader:1104:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [ ‘/home/MYMIRRORNAME/MagicMirror/js/check_config.js’ ]
      Node.js v20.18.1
      thank you for your help
      • N Offline
        nowayto @sdetweil
        Sam… I don’t know how to saying it.
        I figure out the issue.
        After your last message I tried what you suggest.
        With the default cfg I had no errors, with mine I had errors.
        So I checked again and again the config…
        and I find an underscore _ right at the start of the config
        npm config:check told me “no syntax errors” and that confusing me.
        When I edit it I use nano editor
        I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
        Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
        In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
        I’m really sorry for bothering you with that.
        How can I buy you a coffee ?
          sdetweil @nowayto
          @nowayto >Node.js v20.18.1
          2.31.0 requires node 22.14 or above
          how did you get here?
          also you are on 2.31.0-develop
          so you had a temp fix
          and didn’t read the post i put out
          https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
          N 2 Replies Last reply Reply Quote 0
          • N Offline
            nowayto @sdetweil
            @sdetweil I didn’t update MM since I’ve installed it months ago, so I suppose it wasn’t that. Might be it updated automatically?
            I remember you told me to use a “temp fix” to solve a problem.
            Now I’ll follow your guide in the post to update it.
            • N Offline
              nowayto @sdetweil
              @sdetweil Do you suggest to update manually or auto? Thanks
                sdetweil @nowayto
                @nowayto i never suggest update automatically.
                use my script
                • N Offline
                  nowayto @sdetweil
                  @sdetweil I’m sorry for the question: that script?
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                    sdetweil @nowayto
                    @nowayto yes, but its two steps
                    one time without any parameters (test mode)
                    and one time with apply
                    all you have to do is click/copy the first time and run it
                    then do the same on the second if the first ends successfully
                    • N Offline
                      nowayto @sdetweil
                      @sdetweil MM doesn’t work.
                      I tried a config check but I have this error now.
                      I tried to “npm install eslint -g” but the error persist
                      magicmirror@2.31.0 config:check
                      node:internal/modules/cjs/loader:1404
                      throw err;
                      Require stack:
                      • /home/MYMIRR/MagicMirror/js/check_config.js
                        at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
                        at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
                        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
                        at Module._load (node:internal/modules/cjs/loader:1211:37)
                        at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                        at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                        at Module.require (node:internal/modules/cjs/loader:1487:12)
                        at require (node:internal/modules/helpers:135:16)
                        at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
                        at Module._compile (node:internal/modules/cjs/loader:1730:14) {
                        requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
                      Node.js v22.15.0
                        sdetweil @nowayto
                        @nowayto show me the ~/MagicMirror/installers/upgrade.log
                        note: I had a typo in log filename
                        and then do
                        cd ~/MagicMirror
                        npm install
                        • N Offline
                          nowayto @sdetweil
                          Upgrade started - Sat May 10 00:06:51 CEST 2025
                          system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                          doing test run = true, NO updates will be applied!
                          the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
                          architecture from dpkg is armhf
                          ^[[96mCheck current Node installation …^[[0m
                          ^[[0mNode currently installed. Checking version number.
                          ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
                          ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
                          ^[[92mNo Node.js upgrade necessary.^[[0m
                          ^[[96mCheck current NPM installation …^[[0m
                          ^[[0mNPM currently installed. Checking version number.
                          ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
                          ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
                          ^[[92mNo npm upgrade necessary.^[[0m
                          saving custom.css
                          remote name = origin
                          upgrading from version 2.31.0 to 2.31.0
                          fetching latest revisions
                          git fetch rc=0
                          current branch = master
                          On branch master
                          Your branch is up to date with ‘origin/master’.
                          Untracked files:
                          (use “git add …” to include in what will be committed)
                          core
                          errorcal.txt
                          errorcal2.txt
                          errorcal3.txt
                          errorcal4.txt
                          errorcal5.txt
                          nohup.out
                          run-start.sh
                          splashscreen/
                          nothing added to commit but untracked files present (use “git add” to track)
                          no files different from github version
                          • N Offline
                            nowayto @sdetweil
                            @sdetweil npm install results
                            ~/MagicMirror $ npm install
                            npm error code ENOTEMPTY
                            npm error syscall rename
                            npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
                            npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
                            npm error errno -39
                            npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
                            npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
                            Tried with sudo
                            ~/MagicMirror $ sudo npm install
                            npm error code EBADENGINE
                            npm error engine Unsupported engine
                            npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
                            npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
                            npm error notsup Required: {“node”:“>=22.14.0”}
                            npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
                            npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
                            npm seems to see an old version of nodejs but:
                            ~/MagicMirror $ node -v
                            v22.15.0
                            I don’t know what happened.
                            If it can help I had first problem after the MMM-SolarPicture
                            but I’ve just installed it and configured it through config.js… nothing more than usual…
                            but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
                            │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                            │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
                              sdetweil @nowayto
                              @nowayto two things
                              doing test run changes nothing, its a safety check
                              and i wont let you upgrade over the same release accidentally
                              so you need to rerun the command and add
                              force
                              to the end
                                @nowayto NEVER use sudo with any npm command
                                the number in the pm2 status 4311 is the number of restarts
                                youve got a mess
                                now we HAVE to use sudo to undo it
                                cd ~/MagicMirror
                                sudo rm -rf node_modules
                                cd fonts
                                cd ..\vendor
                                sudo rm-rf node_modules
                                cd ..
                                lets see about node
                                which node
                                n
                                q to quit
                                nvm
                                dont do anything else til we figure out the nodejs problem
                                • N Offline
                                  nowayto @sdetweil
                                  @sdetweil I’m sorry :(
                                  I did it what you suggest and config:check gave me a module error again. Different than one before
                                  throw err;
                                  Error: Cannot find module ‘ajv’
                                  Require stack:
                                  After “require stack” there are other lines, if you need it, tell me.
                                    sdetweil @nowayto
                                    @nowayto
                                    i said stop
                                    we need to fix nodejs so npm install will work
                                    node -v
                                    says something
                                    and npm install says node is different
                                    i am trying to figure out where node is installed and by who
                                    system, nvm or n
                                    you didn’t give me answers to the commands i provided
                                    • N Offline
                                      nowayto @sdetweil
                                      which node gave me
                                      /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
                                      n gave me
                                      node/20.18.1
                                      Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                                      nvm gave me
                                      Node Version Manager (v0.39.5)
                                      Note: refers to any version-like string nvm understands. This includes :
                                      • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
                                      • default (built-in) aliases: node, stable, unstable, iojs, system
                                      • custom aliases you define with nvm alias foo
                                      followed by a lot of options
                                        sdetweil @nowayto
                                        @nowayto ok nvm and n do the same function but differently
                                        i use n in my scripts because it runs everywhere
                                        so lets turn off nvm
                                        nvm deactivate
                                        nvm unload
                                        cd ~
                                        rm -rf  .nvm
                                        now which node
                                        should find /usr/local/bin/node
                                        now we need n to get to node 22.14.0
                                        sudo n 22.14.0
                                        now node -v
                                        should return 22.14.0
                                        if so, do
                                        cd  ~/MagicMirror
                                        npm install
                                        now MagicMirror should run
                                        • N Offline
                                          nowayto @sdetweil
                                          @sdetweil Thank you a lot Sam.
                                          I did everything but
                                          I have an [ERROR] _ is not defined
                                          magicmirror@2.31.0 start:x11
                                          [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                                          [2025-05-11 15:39:26.527] [LOG] Loading config …
                                          [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                                          [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                                          [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                                          [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                                          [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                                            sdetweil @nowayto
                                            @nowayto so that sounds like the npm install failed again
                                            do it again and show the output
                                            • N Offline
                                              nowayto @sdetweil
                                              installer didn’t failed, but this is the result now
                                              npm install
                                              magicmirror@2.31.0 postinstall
                                              npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                              magicmirror@2.31.0 install-vendor
                                              echo "Installing vendor files …
                                              " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                              up to date in 7s
                                              magicmirror@2.31.0 install-fonts
                                              echo "Installing fonts …
                                              " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                              Installing fonts …
                                              up to date in 3s
                                              magicmirror@2.31.0 prepare
                                              [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                              up to date in 45s
                                              285 packages are looking for funding
                                              run npm fund for details
