    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 36.6k Views 20 Watching
      sdetweil @khayfer
      @khayfer address:“localhost”
      means ONLY apps INSIDE the same system can connect, means a browser started from the desktop
      if you want to use another system, set
      address:“0.0.0.0”,
      • K Offline
        khayfer @sdetweil
        @sdetweil I changed it to 0.0.0.0 and it still says it could not connect to the server :-/
          sdetweil @khayfer
          @khayfer can you open the MagicMirror page from that machine?
          many browsers have started to implement local network access security. i know on my mac, i cannot access my 3d print server w chrome anymore. i have to use safari
          • K Offline
            khayfer @sdetweil
            @sdetweil yes, I’m able to use the browser in the pi. I can navigate the internet no problem, but the moment I type the ip address, it still says could not connect to the server.
            I then tried it on multiple different devices/browsers on the same wifi and they all say the same thing.
              sdetweil @khayfer
              @khayfer and you are doing
              http://address:port
              for MagicMirror
              port from config.js
              on the same machine
              you can use localhost
              http://localhost:8080
              ip addr
              will give you the address of the pi
              from your laptop
              http://xxxxx:8080
              where xxxxx was the addr from ip addr
                mischag
                my MMM-Chores is playing up big time now…
                after the last update, not the most recent one, but the one before that, my chores list now is just a long list of everything coming up for ever…
                it’s not just displaying the next days chores, but every chore. and if you tick off a chore being completed, it then just add’s that next time the chore is due to the bottom of the list. and there’s no end in sight on my magic mirror, but also no end in sight for the admin page. I’ll ‘complete’ a job, but then it just adds it to the bottom of the page…
                anyone else having major issues with it? was working great before… and I worked out that the magic mirror needs to be running to get into the admin portal page. but now my mirror just looks like this…
                Any help much appreciated as the kids can’t tick off when completed anymore…
                PierreGodeP 2 Replies Last reply Reply Quote 0
                • PierreGodeP Offline
                  PierreGode Module Developer @mischag
                  @mischag Hi!
                  latest update a lot settings has being moved to the webpage.
                  It should work with the old config.js but might be acting up.
                  try with the new settings. enabling show past tasks will show only past tasks that are not completed.
                  make sure your config.js has
                    module: "MMM-Chores",
                    position: "bottom_right",
                    header: "Chores",
                      updateInterval: 60 * 1000,
                      adminPort: 5003,
                      openaiApiKey: "your-openApi-key here",
                      settings: "unlocked", // set a 6 digit pin like "000000" to lock settings popup with a personal pin, change 000000 to any 6 digit password you want, or comment this out to lock settings completely
                  // other options can be set in the admin portal
                      levelTitles: [
                      // titles for every 10 levels
                        "Junior",
                        "Apprentice",
                        "Journeyman",
                        "Experienced",
                        "Expert",
                        "Veteran",
                        "Master",
                        "Grandmaster",
                        "Legend",
                        "Mythic"
                    @mischag said in MMM-Chores - Manage and keep track of your household Chores:
                    PierreGodeP 1 Reply Last reply Reply Quote 0
                      PierreGode Module Developer @PierreGode
                      If you cant make the new settings work for you, you could jump back to an older version
                      git checkout uiimproovments and restart the module
                        JohnGalt @PierreGode
                        @PierreGode – What does the ‘Chores per Week Estimate’ do?
                        What is it estimating, and what does it do with the estimate?
                          PierreGode Module Developer @JohnGalt
                          @JohnGalt
                          It was supposed to show total completed chores per user per week, but it was bugging. Do you have the latest version?
                            @PierreGode – OK, thanks. I was just wondering what it is estimating, and what it is supposed to do with the estimates.
                              bossier17
                              Hi! How does MMM-Chores determine current date for tasks? I create a task in the Admin page for today, but it only shows if I have the “Show past tasks” option checked. The “created” and “assigned” date are correct in the data.json file. The raspberry pi looks like it is in correct location and time zone.
                                PierreGode Module Developer @bossier17
                                @bossier17
                                MMM‑Chores reads the current date from JavaScript’s built‑in Date object, which pulls time information directly from the host system’s clock. The display logic calls new Date() to obtain “today,”
                                Test it creating a clock.js with and run it with node clock.js this is what the app uses
                                const now = new Date();
                                console.log(new Date().toString());
                                  bossier17 @PierreGode
                                  @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
                                  hmmm I can’t figure it out. clock.js returns the correct date/time. But I cannot get today’s tasks to show on the mirror. Somehow the display Chores on the Mirror is showing tomorrow’s chores only. If I put a chore in the admin page for tomorrow it will display. But chores I put in with today’s date only show if I have “Show Past Tasks” checked. Any ideas?
                                    @bossier17
                                    I made an update that I hope resolves the issue.
                                    Update the module with git pull
                                    /Pierre
                                      @PierreGode Awesome! That worked. Thanks so much!
                                        Major update on its way coming days!
                                        • added optional login with possibility to add both write permission user and read only user.
                                        • added pushover notification possibility+ configuration to set daily reminders at specific time.
                                        • added background images " 4 seasons"
                                          -reworked task list, moved up user assignment to creation space
                                          -reworked edit option to be a form to be able to update task description, user and date
                                        see images below
                                          atwist
                                          Is it possible to have a recurring weekday only task? Just Monday-Friday?
                                            @johngalt @sdetweil @redbeardedninja @sarote @mischag @plainbroke @
                                            New big update out now.
                                            New reward system
                                            more recurring options
                                            Fixes and updates.
                                            • 6
                                            • 4 / 6
