    Home Assistant Sensor
    17 Posts 2 Posters 1.9k Views 2 Watching
    • C Offline
      ChrisKelley
      Re: MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
      Hello all
      looking for some help with Home assistant sensor
      I’m getting “Error Fetching Stats” on the Magic Mirror
      My Config is below
                              module: 'MMM-homeassistant-sensors',
                              position: 'bottom_left',
                                      host: "10.10.28.134",
                                      port: "8123",
                                      https: false,
                                      token: "My Token"
                                      values: [
                                              sensor: "status.14928_acurite_00275rm_14928_t1",
                                              sensor: "status.14928_acurite_00275rm_14928_b",
      I have tried using a host name instead of the IP address same issue
      If anyone has any thoughts please let me know
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @ChrisKelley
        @ChrisKelley can you look at the output where you start MM
        if that is pm2, then
        pm2 logs --lines=xxxx
        xxxx is the number of most recent lines, default 15
        on another module to my HA
        [2025-12-03 08:29:00.425] [INFO]  [MMM-HomeAssistantDisplay] [
          'Conected to Home Assistant for module_20_MMM-HomeAssistantDisplay after 0 retries'
        one other thing, for config and logs, please use a code wrapper around the content
        paste into editor, blank line above and below
        select the text you just pasted, hit the </> button on the editor toolbar above
        or manually
        add a tripple backtic (left of the 1 key on the US keyboard) as the only chars on the line (the blank line above and below)
        • C Offline
          ChrisKelley @ChrisKelley
          Thanks for the fast response… here is the log file
          0|MagicMir | [2025-12-03 13:22:44.738] [LOG]   MMM-homeassistant-sensors - Connection Failed: undefined
          0|MagicMir | [2025-12-03 13:23:11.668] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:23:35.496] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:23:38.618] [LOG]   MMM-homeassistant-sensors - Connection Failed: undefined
          0|MagicMir | [2025-12-03 13:23:41.668] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:23:44.748] [LOG]   MMM-homeassistant-sensors - Connection Failed: undefined
          0|MagicMir | [2025-12-03 13:24:11.668] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:24:35.713] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:24:38.845] [LOG]   MMM-homeassistant-sensors - Connection Failed: undefined
          0|MagicMir | [2025-12-03 13:24:41.668] [LOG]   SONOS_UPDATE
          0|MagicMir | [2025-12-03 13:24:44.818] [LOG]   MMM-homeassistant-sensors - Connection Failed: undefined
          0|MagicMir | [2025-12-03 13:24:59.257] [INFO]  Newsfeed-Fetcher: Broadcasting 60 items.
          0|MagicMir | [2025-12-03 13:24:59.258] [INFO]  Newsfeed-Fetcher: Broadcasting 60 items.
          0|MagicMir | [2025-12-03 13:25:03.630] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
          0|MagicMir | [2025-12-03 13:25:11.669] [LOG]   SONOS_UPDATE
            @ChrisKelley based on that error which I can’t see in the code
            I think its one of two things
            ipaddress of HA wrong
            token to HA wrong
            can you set this config option for the module
            debuglogging:true,
            and recapture the log…
            • C Offline
              Ok… So i added the logging line as well as added .local to the url… this changed things see below… Still not working but error on screen is gone
              chris@MagicMirror:~ $ pm2 logs
              [TAILING] Tailing last 15 lines for [all] processes (change the value with --lin        es option)
              /home/chris/.pm2/pm2.log last 15 lines:
              PM2        | 2025-12-03T08:14:38: PM2 log: pid=4758 msg=process killed
              PM2        | 2025-12-03T08:14:38: PM2 log: App [MagicMirror:0] starting in -fork        mode-
              PM2        | 2025-12-03T08:14:38: PM2 log: App [MagicMirror:0] online
              PM2        | 2025-12-03T14:27:30: PM2 log: Change detected on path MagicMirror/c        onfig/config.js for app MagicMirror - restarting
              PM2        | 2025-12-03T14:27:30: PM2 log: Stopping app:MagicMirror id:0
              PM2        | 2025-12-03T14:27:30: PM2 log: App [MagicMirror:0] exited with code        [0] via signal [SIGINT]
              PM2        | 2025-12-03T14:27:30: PM2 log: pid=5225 msg=process killed
              PM2        | 2025-12-03T14:27:30: PM2 log: App [MagicMirror:0] starting in -fork        mode-
              PM2        | 2025-12-03T14:27:30: PM2 log: App [MagicMirror:0] online
              PM2        | 2025-12-03T15:00:50: PM2 log: Change detected on path MagicMirror/c        onfig/config.js for app MagicMirror - restarting
              PM2        | 2025-12-03T15:00:50: PM2 log: Stopping app:MagicMirror id:0
              PM2        | 2025-12-03T15:00:50: PM2 log: App [MagicMirror:0] exited with code        [0] via signal [SIGINT]
              PM2        | 2025-12-03T15:00:50: PM2 log: pid=9835 msg=process killed
              PM2        | 2025-12-03T15:00:50: PM2 log: App [MagicMirror:0] starting in -fork        mode-
              PM2        | 2025-12-03T15:00:50: PM2 log: App [MagicMirror:0] online
              /home/chris/.pm2/logs/sonos-out.log last 15 lines:
              1|sonos    | 2025-12-03T12:51:12.492Z INFO Could not find file /home/chris/node-        sonos-http-api/settings.json
              1|sonos    | 2025-12-03T12:51:12.696Z INFO Presets loaded: {
              1|sonos    |   example: {
              1|sonos    |     players: [
              1|sonos    |       { roomName: 'Bathroom', volume: 10 },
              1|sonos    |       { roomName: 'Kitchen', volume: 10 },
              1|sonos    |       { roomName: 'Office', volume: 10 },
              1|sonos    |       { roomName: 'Bedroom', volume: 10 },
              1|sonos    |       { roomName: 'TV Room', volume: 15 }
              1|sonos    |     ],
              1|sonos    |     playMode: { shuffle: true, repeat: 'all', crossfade: false },
              1|sonos    |     pauseOthers: false
              1|sonos    |   }
              1|sonos    | }
              1|sonos    | 2025-12-03T12:51:13.727Z INFO http server listening on 0.0.0.0 port        5005
              /home/chris/.pm2/logs/sonos-error.log last 15 lines:
              1|sonos    | Please migrate your code to use AWS SDK for JavaScript (v3).
              1|sonos    | For more information, check the blog post at https://a.co/cUPnyil
              1|sonos    | (Use `node --trace-warnings ...` to show where the warning was crea        ted)
              1|sonos    | (node:985) NOTE: The AWS SDK for JavaScript (v2) is in maintenance        mode.
              1|sonos    |  SDK releases are limited to address critical bug fixes and securit        y issues only.
              1|sonos    |
              1|sonos    | (node:1035) NOTE: The AWS SDK for JavaScript (v2) is in maintenance        mode.
              1|sonos    |
              /home/chris/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir | [2025-12-03 14:56:32.970] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:56:35.439] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:57:32.971] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:57:35.435] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:58:32.971] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:58:35.456] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:59:32.970] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 14:59:35.446] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 15:00:32.970] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 15:00:35.444] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | /home/chris/MagicMirror/node_modules/electron/dist/electron exited        with signal SIGINT
              0|MagicMir | [2025-12-03 15:00:52.085] [WARN]  You're using a full whitelist con        figuration to allow for all IPs
              0|MagicMir | [2025-12-03 15:00:55.458] [ERROR] [MMM-Remote-Control] Could not fi        nd main module js file for MMM-homeassistant-sensors-old
              0|MagicMir | [2025-12-03 15:01:35.732] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
              0|MagicMir | [2025-12-03 15:02:35.439] [ERROR] MMM-homeassistant-sensors - build        Url: http://homeassistant.local:8123/api/states
                @ChrisKelley can you show the end of the error—- build lines
                • C Offline
                  ChrisKelley @sdetweil
                  Lets see if this is better… When I hit the </> button it moves half the code hard right…
                  @sde/home/chris/.pm2/logs/MagicMirror-error.log last 15 lines:
                  0|MagicMir | [2025-12-03 15:00:52.085] [WARN] You’re using a full whitelist con figuration to allow for all IPs
                  0|MagicMir | [2025-12-03 15:03:35.542] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:04:35.450] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:05:35.449] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:06:35.564] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:07:35.437] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:08:35.680] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:09:35.585] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:10:35.488] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  0|MagicMir | [2025-12-03 15:11:36.010] [ERROR] MMM-homeassistant-sensors - build Url: http://homeassistant.local:8123/api/states
                  tweil
                    @ChrisKelley did you change the config to .local??
                    Can you ping that from the MagicMirror system
                    i have grandson duty for 2 hours now
                    Then I will install that module
                    • C Offline
                      Yep that works…
                      chris@MagicMirror:~ $ ping 10.10.28.134
                      PING 10.10.28.134 (10.10.28.134) 56(84) bytes of data.
                      64 bytes from 10.10.28.134: icmp_seq=1 ttl=64 time=0.027 ms
                      64 bytes from 10.10.28.134: icmp_seq=2 ttl=64 time=0.032 ms
                      64 bytes from 10.10.28.134: icmp_seq=3 ttl=64 time=0.029 ms
                      64 bytes from 10.10.28.134: icmp_seq=4 ttl=64 time=0.062 ms
                      64 bytes from 10.10.28.134: icmp_seq=5 ttl=64 time=0.036 ms
                      64 bytes from 10.10.28.134: icmp_seq=6 ttl=64 time=0.035 ms
                      64 bytes from 10.10.28.134: icmp_seq=7 ttl=64 time=0.022 ms
                      64 bytes from 10.10.28.134: icmp_seq=8 ttl=64 time=0.022 ms
                      64 bytes from 10.10.28.134: icmp_seq=9 ttl=64 time=0.025 ms
                      64 bytes from 10.10.28.134: icmp_seq=10 ttl=64 time=0.025 ms
                      code_text
                        @ChrisKelley ping by name?
                        • C Offline
                          Yep sorry that makes more sense
                          chris@MagicMirror:~ $ ping homeassistant.local
                          PING homeassistant.local (10.10.28.211) 56(84) bytes of data.
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=1 ttl=64 time=2.91 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=2 ttl=64 time=3.81 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=3 ttl=64 time=4.07 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=4 ttl=64 time=3.88 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=5 ttl=64 time=1.18 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=6 ttl=64 time=3.95 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=7 ttl=64 time=4.10 ms
                          64 bytes from 10.10.28.211 (10.10.28.211): icmp_seq=8 ttl=64 time=1.52 ms
                            @ChrisKelley no issue, it’s useful as we know it generates the same address
                              @ChrisKelley so I installed, did npm install in the module folder
                              here is my config , two sensors from my entities list in HA
                              so now all I can think is your token string is bad…
                                        position: 'top_left',
                                        classes: "page4",
                                          host: "homeassistant.local",
                                          port: "8123",
                                          https: false,
                                          token: " my fresh token ",
                                          values: [
                                              sensor: "binary_sensor.athom_garage_door_status",
                                              sensor: "sensor.foo_battery_percentage",
                              • C Offline
                                Thank you for all the help… I tried deleting the token. I made a new token in HA and used that one still nothing… I deleted the module from MM and I will try again this afternoon. Which fork did you use for your test? There are at least two just want to make sure I use the same one as you did…
                                Chris
                                  @ChrisKelley I used this one
                                  https://github.com/Snille/MMM-homeassistant-sensors.git
                                  • C Offline
                                    SAM!!!
                                    Thank You!! It works… I was using a different fork then the one you used… plus I think my sensor strings were malformed. but all good now!
                                    Thank You Again!
                                      @ChrisKelley woohoo… great news… thanks for the feedback!!
