    MMM-Remote-Control
    55 Posts 9 Posters 2.4k Views 8 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @KristjanESPERANTO
      @meikelrix Please check new release 4.1.1 🙂
        meikelrix @KristjanESPERANTO
        @KristjanESPERANTO said in MMM-Remote-Control:
        Thank you very much, that has fixed my custom menu!
        On the other hand I still don’t see the content of “Modules Controls” menu, although “showModuleApiMenu: true” is set in config.js?
          KristjanESPERANTO Module Developer @meikelrix
          @meikelrix Did you set showModuleApiMenu like this?
                module: "MMM-Remote-Control",
                position: "bottom_right",
                  showModuleApiMenu: true,
          Do you also have modules with recognizable notifications? Newsfeed is quite good for testing, for example.
          If it doesn’t work, show me your config (without secrets of course).
            @KristjanESPERANTO I did set the showModuleApiMenu: true,
            I do get the “Module Controls” menu entry, but it has no content AND other notification based modules are working.
            I noticed as well that the “Updates” doesn’t show modules, anymore. The only one shown is “MagicMirror”, below the message “!No module loaded.”
            Ok, I renamed MMM-Remote-Contol directory and re-installed following the github instructions. All is working now!
            Thank you for your help and a great module!
            • SnilleS Offline
              Snille Module Developer @KristjanESPERANTO
              @KristjanESPERANTO
              I have this problem that has been bugging me for a while…
              Check this clip: https://photos.app.goo.gl/Zahc5xqttn33frbKA < From API
              My mirror have lot’s of modules many are multi instances (like MMM-MotionEye in this example).
              I see the same behavior (or similar) with other modules, mainly my “MMM-homeassistant-sensors”…
              I often makes API-calls from Node Red in Home Assistant, like this clip: https://photos.app.goo.gl/K9ktuXGKawoyHEez5
              Errors from the log:
              0|mmdev  | [2026-01-05 12:24:13.812] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
              0|mmdev  |     at ServerResponse.setHeader (node:_http_outgoing:700:11)
              0|mmdev  |     at ServerResponse.header (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:686:10)
              0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:249:10)
              0|mmdev  |     at Class.sendResponse (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:687:28)
              0|mmdev  |     at Class.handleSimpleSocketNotification (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:965:10)
              0|mmdev  |     at SHOW (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1024:28)
              0|mmdev  |     at Class.executeQuery (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1049:7)
              0|mmdev  |     at Class.answerModuleApi (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:442:14)
              0|mmdev  |     at /var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:299:14
              0|mmdev  |     at Layer.handleRequest (/var/www/html/magicmirror/m/node_modules/router/lib/layer.js:152:17)
              0|mmdev  |     at next (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:157:13)
              0|mmdev  |     at Route.dispatch (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:117:3)
              0|mmdev  |     at handle (/var/www/html/magicmirror/m/node_modules/router/index.js:435:11)
              0|mmdev  |     at /var/www/html/magicmirror/m/node_modules/router/index.js:295:15
              0|mmdev  |     at param (/var/www/html/magicmirror/m/node_modules/router/index.js:600:14)
              0|mmdev  | [2026-01-05 12:24:28.662] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
              0|mmdev  |     at ServerResponse.send (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:163:12)
              0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:252:15)
              0|mmdev  |     at HIDE (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1023:28)
              I also experience that when calling a specific module to show with “module_number_modulename”, it often shows the “wrong” module-instance (of that type of module, like MMM-homeassistant-sensors, but the wrong one)… I don’t know if it’s related to this.
              Let me know if you need anything more…
              Thank you for this great module! :)
              If you cant find it, make it and share it!
              Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                KristjanESPERANTO Module Developer @Snille
                @Snille Thanks for the detailed report. I think I’ve fixed it. Please update to the new release v4.1.4 and give me some feedback 🙂
                SnilleS 1 Reply Last reply Reply Quote 0
                • SnilleS Offline
                  @KristjanESPERANTO You are welcome, It’s me who should thank you for all the great stuff! :) It’s almost working…
                  The error messages are gone, but it still shows and hides “both” modules (MMM-MotionEye in my example clip)… :)
                  Let me know if you want anything else? There is nothing in the “logs” now… :)
                    @Snille That was tricky, but I think I’ve solved that too. Please take a look at the new release v4.1.5 🙂
                    SnilleS 1 Reply Last reply Reply Quote 1
                    • SnilleS Offline
                      @KristjanESPERANTO It is working!! Awesome! Thanks you very much! :)
                        @Snille Cool. I’m glad it works 🎉
                        • 6
                        • 4 / 6
