    MMM-Remote-Control
    57 Posts 9 Posters 14.1k Views 10 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @meikelrix
      @meikelrix I’ll take a look asap :-)
      KristjanESPERANTOK 1 Reply Last reply
        KristjanESPERANTO Module Developer @KristjanESPERANTO
        @meikelrix Please check new release 4.1.1 🙂
        M 1 Reply Last reply
          meikelrix @KristjanESPERANTO
          @KristjanESPERANTO said in MMM-Remote-Control:
          Thank you very much, that has fixed my custom menu!
          On the other hand I still don’t see the content of “Modules Controls” menu, although “showModuleApiMenu: true” is set in config.js?
            @meikelrix Did you set showModuleApiMenu like this?
                  module: "MMM-Remote-Control",
                  position: "bottom_right",
                    showModuleApiMenu: true,
            Do you also have modules with recognizable notifications? Newsfeed is quite good for testing, for example.
            If it doesn’t work, show me your config (without secrets of course).
              @KristjanESPERANTO I did set the showModuleApiMenu: true,
              I do get the “Module Controls” menu entry, but it has no content AND other notification based modules are working.
              I noticed as well that the “Updates” doesn’t show modules, anymore. The only one shown is “MagicMirror”, below the message “!No module loaded.”
              Ok, I renamed MMM-Remote-Contol directory and re-installed following the github instructions. All is working now!
              Thank you for your help and a great module!
              • SnilleS
                Snille Module Developer @KristjanESPERANTO
                @KristjanESPERANTO
                I have this problem that has been bugging me for a while…
                Check this clip: https://photos.app.goo.gl/Zahc5xqttn33frbKA < From API
                My mirror have lot’s of modules many are multi instances (like MMM-MotionEye in this example).
                I see the same behavior (or similar) with other modules, mainly my “MMM-homeassistant-sensors”…
                I often makes API-calls from Node Red in Home Assistant, like this clip: https://photos.app.goo.gl/K9ktuXGKawoyHEez5
                Errors from the log:
                0|mmdev  | [2026-01-05 12:24:13.812] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                0|mmdev  |     at ServerResponse.setHeader (node:_http_outgoing:700:11)
                0|mmdev  |     at ServerResponse.header (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:686:10)
                0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:249:10)
                0|mmdev  |     at Class.sendResponse (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:687:28)
                0|mmdev  |     at Class.handleSimpleSocketNotification (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:965:10)
                0|mmdev  |     at SHOW (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1024:28)
                0|mmdev  |     at Class.executeQuery (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1049:7)
                0|mmdev  |     at Class.answerModuleApi (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:442:14)
                0|mmdev  |     at /var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:299:14
                0|mmdev  |     at Layer.handleRequest (/var/www/html/magicmirror/m/node_modules/router/lib/layer.js:152:17)
                0|mmdev  |     at next (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:157:13)
                0|mmdev  |     at Route.dispatch (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:117:3)
                0|mmdev  |     at handle (/var/www/html/magicmirror/m/node_modules/router/index.js:435:11)
                0|mmdev  |     at /var/www/html/magicmirror/m/node_modules/router/index.js:295:15
                0|mmdev  |     at param (/var/www/html/magicmirror/m/node_modules/router/index.js:600:14)
                0|mmdev  | [2026-01-05 12:24:28.662] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                0|mmdev  |     at ServerResponse.send (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:163:12)
                0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:252:15)
                0|mmdev  |     at HIDE (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1023:28)
                I also experience that when calling a specific module to show with “module_number_modulename”, it often shows the “wrong” module-instance (of that type of module, like MMM-homeassistant-sensors, but the wrong one)… I don’t know if it’s related to this.
                Let me know if you need anything more…
                Thank you for this great module! :)
                  KristjanESPERANTO Module Developer @Snille
                  @Snille Thanks for the detailed report. I think I’ve fixed it. Please update to the new release v4.1.4 and give me some feedback 🙂
                  SnilleS 1 Reply Last reply
                  • SnilleS
                    @KristjanESPERANTO You are welcome, It’s me who should thank you for all the great stuff! :) It’s almost working…
                    The error messages are gone, but it still shows and hides “both” modules (MMM-MotionEye in my example clip)… :)
                    Let me know if you want anything else? There is nothing in the “logs” now… :)
                      @Snille That was tricky, but I think I’ve solved that too. Please take a look at the new release v4.1.5 🙂
                      • SnilleS
                        @KristjanESPERANTO It is working!! Awesome! Thanks you very much! :)
                          @Snille Cool. I’m glad it works 🎉
                          B 1 Reply Last reply
                            bloodknot @KristjanESPERANTO
                            @KristjanESPERANTO - Cannot GET /api/refresh (or any API call)
                            MMM-Remote-Control is working fine on the same computer that the API is not found. This occurred in the last couple of updates. Nothing else changed in the configuration and/or modules.
                            magicmirror2 = 192.168.4.21
                            http://magicmirror2:8080/remote.html#main-menu WORKS from 192.168.4.210
                            http://magicmirror2:8080/api/refresh Does NOT Work from 192.168.4.210
                            MM Config:
                            address: "0.0.0.0",
                            port: 8080
                            basePath: "/",
                            ipWhitelist:[],
                            module: 'MMM-Remote-Control',
                            	customCommand: {}
                                 	secureEndpoints: true,
                                 	apiKey: '********-****-****-****-************'
                                 	showQRCode: false
                            GET http://magicmirror2:8080/api/refresh?apiKey=********-****-****-****-************ 404 (Not Found)
                            What has changed? Did I miss an update? Any assistance will be great
                              KristjanESPERANTO Module Developer @bloodknot
                              @bloodknot I think I solved it, please update to v4.2.0 and check 🙂
                                @KristjanESPERANTO
                                Update to 4.2.0 fixed the issue. Thanks for the quick response!!
                                  bloodknot @bloodknot
                                  @kristjanesperanto
                                  It looks like something also happened to showalert:
                                  http://magicmirrorip:8080/api/module/alert/showalert?message=Hello&timer=2000&apiKey=********-****-****-****-**********
                                  TypeError: Cannot read properties of undefined (reading 'showalert')
                                      at Class.answerModuleApi (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:457:35)
                                      at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:296:14
                                      at Layer.handleRequest (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/layer.js:152:17)
                                      at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:157:13)
                                      at Route.dispatch (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:117:3)
                                      at handle (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:435:11)
                                      at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:295:15
                                      at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:600:14)
                                      at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:610:14)
                                      at processParams (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:664:3)
                                      at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:291:5)
                                      at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:148:7
                                      at trimPrefix (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:342:13)
                                    @bloodknot Thanks for reporting. Release v4.2.1 should fix it. Please check 🙂
                                      @KristjanESPERANTO
                                      I don’t get a failure, however the alert/showalert function does not work:
                                      {"success":false,"message":"Module alert does not have any actions defined."}
                                        @bloodknot Thanks for the quick feedback. Okay, that was still progress. Now please try v4.2.2.
                                        B 2 Replies Last reply
                                          @KristjanESPERANTO
                                          That seems to have fixed my specific problem. Thank you!!!
                                          I have tested:
                                          http://magicmirror2:8080/api/monitor/on
                                            @KristjanESPERANTO
                                            Sorry for the split message.
                                            I have successfully tested:
                                            http://magicmirrorip:8080/api/monitor/on
                                            http://magicmirrorip:8080/api/monitor/off
                                            http://magicmirrorip:8080/api/refresh
                                            http://magicmirrorip:8080/api/reboot
                                            http://magicmirrorip:8080/api/alert/showalert
                                            • 2 / 3
