    MMM-Remote-Control
    57 Posts 9 Posters 13.0k Views 10 Watching
    • KristjanESPERANTOK Online
      KristjanESPERANTO Module Developer @Snille
      @Snille Cool. I’m glad it works 🎉
        bloodknot @KristjanESPERANTO
        @KristjanESPERANTO - Cannot GET /api/refresh (or any API call)
        MMM-Remote-Control is working fine on the same computer that the API is not found. This occurred in the last couple of updates. Nothing else changed in the configuration and/or modules.
        magicmirror2 = 192.168.4.21
        http://magicmirror2:8080/remote.html#main-menu WORKS from 192.168.4.210
        http://magicmirror2:8080/api/refresh Does NOT Work from 192.168.4.210
        MM Config:
        address: "0.0.0.0",
        port: 8080
        basePath: "/",
        ipWhitelist:[],
        module: 'MMM-Remote-Control',
        	customCommand: {}
             	showModuleApiMenu: true,
             	secureEndpoints: true,
             	apiKey: '********-****-****-****-************'
             	showQRCode: false
        GET http://magicmirror2:8080/api/refresh?apiKey=********-****-****-****-************ 404 (Not Found)
        What has changed? Did I miss an update? Any assistance will be great
          KristjanESPERANTO Module Developer @bloodknot
          @bloodknot I think I solved it, please update to v4.2.0 and check 🙂
            @KristjanESPERANTO
            Update to 4.2.0 fixed the issue. Thanks for the quick response!!
              bloodknot @bloodknot
              @kristjanesperanto
              It looks like something also happened to showalert:
              http://magicmirrorip:8080/api/module/alert/showalert?message=Hello&timer=2000&apiKey=********-****-****-****-**********
              TypeError: Cannot read properties of undefined (reading 'showalert')
                  at Class.answerModuleApi (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:457:35)
                  at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:296:14
                  at Layer.handleRequest (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/layer.js:152:17)
                  at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:157:13)
                  at Route.dispatch (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:117:3)
                  at handle (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:435:11)
                  at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:295:15
                  at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:600:14)
                  at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:610:14)
                  at processParams (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:664:3)
                  at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:291:5)
                  at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:148:7
                  at trimPrefix (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:342:13)
                @bloodknot Thanks for reporting. Release v4.2.1 should fix it. Please check 🙂
                  @KristjanESPERANTO
                  I don’t get a failure, however the alert/showalert function does not work:
                  {"success":false,"message":"Module alert does not have any actions defined."}
                    @bloodknot Thanks for the quick feedback. Okay, that was still progress. Now please try v4.2.2.
                      @KristjanESPERANTO
                      That seems to have fixed my specific problem. Thank you!!!
                      I have tested:
                      http://magicmirror2:8080/api/monitor/on
                        @KristjanESPERANTO
                        Sorry for the split message.
                        I have successfully tested:
                        http://magicmirrorip:8080/api/monitor/on
                        http://magicmirrorip:8080/api/monitor/off
                        http://magicmirrorip:8080/api/refresh
                        http://magicmirrorip:8080/api/reboot
                        http://magicmirrorip:8080/api/alert/showalert
                          @bloodknot Perfect, thank you for testing! 😃
                          • V Offline
                            vtek
                            hey guys…
                            having some issues using the shutdown/reboot commands…they throw this error, even though I have the API key in the config
                            {“success”:false,“message”:“Forbidden: API Key Not Provided!”}
                            here’s the config
                                                // position: 'bottom_left', // Required to show URL/QR code on mirror
                                                        apiKey: "111111111-2222-3333-4444-555555555555",
                                                        customCommand: {
        monitorOnCommand: 'loginctl unlock-session 1',
        monitorOffCommand: 'loginctl lock-session 1',
        shutdownCommand: 'systemctl poweroff',
        rebootCommand: 'systemctl reboot',  // Optional, See "Using Custom Commands" below
                            • V Offline
                              vtek @vtek
                              said in MMM-Remote-Control:
                              hey guys…
                              here’s the config
                                                          customCommand: {
                              i figure it out…had to append the apiKey at the end of the url for all commands
                              http://192.168.1.5:8888/api/command/rebootCommand?apiKey=111111111-2222-33333-4444
                              KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
                                rkorell Module Developer @KristjanESPERANTO
                                @KristjanESPERANTO Dear Kristijan,
                                after a long time I finally managed to see your “new” modul.
                                First of all: Thanks a lot for your effort, again - nice piece!
                                In the past few days I’ve completely rebuilt my mirror and migrated it to trixie as well as to the actual mirror and node versions.
                                I ran into a reproducible issue with the restart functionality when MagicMirror is managed by pm2 (which is the recommended setup per the official MagicMirror documentation).
                                The Problem
                                When triggering a restart via the Remote-Control UI (or the /api/restart endpoint), MagicMirror enters an endless crash-loop with EADDRINUSE: address already in use :::8080.
                                Root Cause
                                The handleRestart function in node_helper.js (lines 717-741) uses the Electron-native restart mechanism:
                                const {app} = require("electron");
                                app.relaunch();
                                app.quit();
                                This works fine in standalone mode, but creates a race condition with pm2:
                                1. app.relaunch() spawns a new Electron instance (child of the current process)
                                2. app.quit() terminates the current Electron instance
                                3. pm2 detects the termination as a crash and spawns another Electron instance
                                4. Now two Electron instances compete for port 8080 → EADDRINUSE → both crash → pm2 keeps restarting → infinite loop
                                The only way to recover is to manually identify and kill the orphaned Electron process, then trigger a clean restart via touch config.js (which pm2’s file-watch picks up).
                                Interestingly, the catch-block fallback for server mode (lines 726-739) already does it correctly — it calls process.exit(0) and lets the process manager handle the restart. The Electron code path just doesn’t account for the pm2 scenario.
                                Possible Fix
                                When running under pm2, the Electron-native app.relaunch() should be skipped entirely.
                                pm2 can be detected via environment variables like PM2_HOME, pm_id, or PM2_USAGE:
                                handleRestart (query, res) {
                                  try {
                                    if (!app) { throw "Could not get Electron app instance."; }
                                    // When running under pm2, don't use app.relaunch() — pm2 handles restart
                                    if (process.env.PM2_HOME || process.env.pm_id !== undefined) {
                                      Log.log("Running under pm2, exiting cleanly for process manager restart...");
                                      this.sendResponse(res, undefined, {action: "RESTART", info: "Exiting for pm2 restart..."});
                                      setTimeout(() => app.quit(), 1000);
                                      return;
                                    this.sendResponse(res, undefined, {action: "RESTART", info: "Restarting Electron..."});
                                    app.relaunch();
                                    app.quit();
                                  } catch (error) {
                                    // ... existing server mode fallback ...
                                Environment
                                • MagicMirror 2.34.0
                                • MMM-Remote-Control 4.2.2 (commit b854832)
                                • Node.js v22, Electron 39.5.2
                                • Raspberry Pi 5, Debian 13 (Trixie)
                                • Process manager: pm2 with file-watch on config.js
                                Workaround
                                For now, I’ve documented this for my setup: never use the restart button in Remote-Control. Monitor ON/OFF works fine, only the restart is
                                affected.
                                Thanks for considering this — happy to test any fix if needed!
                                Warmest regards,
                                Ralf
                                KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                                  KristjanESPERANTO Module Developer @vtek
                                  Hi @vtek, glad you figured it out! Just for reference: when secureEndpoints: true is set, the API key can be passed in two ways:
                                  1. URL parameter: ?apiKey=YOUR_KEY
                                  2. HTTP header: Authorization: apiKey YOUR_KEY
                                  Also, starting with v4.2.4 the error message now directly hints at the solution, so the next person running into this should find it faster 🙂
                                    KristjanESPERANTO Module Developer @rkorell
                                    Hi @rkorell, thank you for the detailed bug report — the root cause analysis was spot on and made it straightforward to fix!
                                    The fix is included in v4.2.4: when MMM-Remote-Control detects it’s running under pm2 (via PM2_HOME or pm_id environment variables), it now skips app.relaunch() and only calls app.quit(), letting pm2 handle the restart cleanly.
                                    Would be great if you could confirm it works on your setup!
                                      just tested v4.2.4 — works perfectly! Restart via the Remote-Control UI now completes cleanly
                                      under pm2, no orphaned Electron process, no port conflict. Exactly the behavior you’d expect.
                                      I also noticed you added a dedicated handleRestart.test.js with 210 lines of unit tests covering
                                      both the pm2 and standalone code paths — that’s really impressive and goes well beyond just a
                                      quick fix. Having proper test coverage for this kind of dual-mode behavior is exactly the right
                                      thing to do. Much appreciated!
                                      Thanks for the incredibly fast turnaround and the quality of the fix. Consider this confirmed
                                      working on:
                                      • MMM-Remote-Control 4.2.4
                                      • pm2 with file-watch
                                      Warmest regards,
                                      Ralf
                                        @rkorell Thank you very much for this feedback and appreciation 🙂 It’s interesting that you took a deeper look at the changes.
                                        • 3 / 3
