    MMM-Remote-Control
    57 Posts 9 Posters 14.1k Views 10 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @bloodknot
      @bloodknot Thanks for the quick feedback. Okay, that was still progress. Now please try v4.2.2.
      B 2 Replies Last reply
        bloodknot @KristjanESPERANTO
        @KristjanESPERANTO
        That seems to have fixed my specific problem. Thank you!!!
        I have tested:
        http://magicmirror2:8080/api/monitor/on
          @KristjanESPERANTO
          Sorry for the split message.
          I have successfully tested:
          http://magicmirrorip:8080/api/monitor/on
          http://magicmirrorip:8080/api/monitor/off
          http://magicmirrorip:8080/api/refresh
          http://magicmirrorip:8080/api/reboot
          http://magicmirrorip:8080/api/alert/showalert
          KristjanESPERANTOK 1 Reply Last reply
            @bloodknot Perfect, thank you for testing! 😃
            • V
              vtek
              hey guys…
              having some issues using the shutdown/reboot commands…they throw this error, even though I have the API key in the config
              {“success”:false,“message”:“Forbidden: API Key Not Provided!”}
              here’s the config
                                  module: 'MMM-Remote-Control',
                                  // position: 'bottom_left', // Required to show URL/QR code on mirror
                                          showModuleApiMenu: true,
                                          secureEndpoints: true,
                                          apiKey: "111111111-2222-3333-4444-555555555555",
                                          customCommand: {
                                                          monitorOnCommand: 'loginctl unlock-session 1',
                                                          monitorOffCommand: 'loginctl lock-session 1',
                                                          shutdownCommand: 'systemctl poweroff',
                                                          rebootCommand: 'systemctl reboot',  // Optional, See "Using Custom Commands" below
              V 1 Reply Last reply
              • V
                vtek @vtek
                said in MMM-Remote-Control:
                hey guys…
                here’s the config
                                            customCommand: {
                i figure it out…had to append the apiKey at the end of the url for all commands
                http://192.168.1.5:8888/api/command/rebootCommand?apiKey=111111111-2222-33333-4444
                Reply Quote 2
                  rkorell Module Developer @KristjanESPERANTO
                  @KristjanESPERANTO Dear Kristijan,
                  after a long time I finally managed to see your “new” modul.
                  First of all: Thanks a lot for your effort, again - nice piece!
                  In the past few days I’ve completely rebuilt my mirror and migrated it to trixie as well as to the actual mirror and node versions.
                  I ran into a reproducible issue with the restart functionality when MagicMirror is managed by pm2 (which is the recommended setup per the official MagicMirror documentation).
                  The Problem
                  When triggering a restart via the Remote-Control UI (or the /api/restart endpoint), MagicMirror enters an endless crash-loop with EADDRINUSE: address already in use :::8080.
                  Root Cause
                  The handleRestart function in node_helper.js (lines 717-741) uses the Electron-native restart mechanism:
                  const {app} = require("electron");
                  app.relaunch();
                  app.quit();
                  This works fine in standalone mode, but creates a race condition with pm2:
                  1. app.relaunch() spawns a new Electron instance (child of the current process)
                  2. app.quit() terminates the current Electron instance
                  3. pm2 detects the termination as a crash and spawns another Electron instance
                  4. Now two Electron instances compete for port 8080 → EADDRINUSE → both crash → pm2 keeps restarting → infinite loop
                  The only way to recover is to manually identify and kill the orphaned Electron process, then trigger a clean restart via touch config.js (which pm2’s file-watch picks up).
                  Interestingly, the catch-block fallback for server mode (lines 726-739) already does it correctly — it calls process.exit(0) and lets the process manager handle the restart. The Electron code path just doesn’t account for the pm2 scenario.
                  Possible Fix
                  When running under pm2, the Electron-native app.relaunch() should be skipped entirely.
                  pm2 can be detected via environment variables like PM2_HOME, pm_id, or PM2_USAGE:
                  handleRestart (query, res) {
                    try {
                      if (!app) { throw "Could not get Electron app instance."; }
                      // When running under pm2, don't use app.relaunch() — pm2 handles restart
                      if (process.env.PM2_HOME || process.env.pm_id !== undefined) {
                        Log.log("Running under pm2, exiting cleanly for process manager restart...");
                        this.sendResponse(res, undefined, {action: "RESTART", info: "Exiting for pm2 restart..."});
                        setTimeout(() => app.quit(), 1000);
                        return;
                      this.sendResponse(res, undefined, {action: "RESTART", info: "Restarting Electron..."});
                      app.relaunch();
                      app.quit();
                    } catch (error) {
                      // ... existing server mode fallback ...
                  Environment
                  • MagicMirror 2.34.0
                  • MMM-Remote-Control 4.2.2 (commit b854832)
                  • Node.js v22, Electron 39.5.2
                  • Raspberry Pi 5, Debian 13 (Trixie)
                  • Process manager: pm2 with file-watch on config.js
                  Workaround
                  For now, I’ve documented this for my setup: never use the restart button in Remote-Control. Monitor ON/OFF works fine, only the restart is
                  affected.
                  Thanks for considering this — happy to test any fix if needed!
                  Warmest regards,
                  Ralf
                    KristjanESPERANTO Module Developer @vtek
                    Hi @vtek, glad you figured it out! Just for reference: when secureEndpoints: true is set, the API key can be passed in two ways:
                    1. URL parameter: ?apiKey=YOUR_KEY
                    2. HTTP header: Authorization: apiKey YOUR_KEY
                    Also, starting with v4.2.4 the error message now directly hints at the solution, so the next person running into this should find it faster 🙂
                      KristjanESPERANTO Module Developer @rkorell
                      Hi @rkorell, thank you for the detailed bug report — the root cause analysis was spot on and made it straightforward to fix!
                      The fix is included in v4.2.4: when MMM-Remote-Control detects it’s running under pm2 (via PM2_HOME or pm_id environment variables), it now skips app.relaunch() and only calls app.quit(), letting pm2 handle the restart cleanly.
                      Would be great if you could confirm it works on your setup!
                      R 1 Reply Last reply
                        just tested v4.2.4 — works perfectly! Restart via the Remote-Control UI now completes cleanly
                        under pm2, no orphaned Electron process, no port conflict. Exactly the behavior you’d expect.
                        I also noticed you added a dedicated handleRestart.test.js with 210 lines of unit tests covering
                        both the pm2 and standalone code paths — that’s really impressive and goes well beyond just a
                        quick fix. Having proper test coverage for this kind of dual-mode behavior is exactly the right
                        thing to do. Much appreciated!
                        Thanks for the incredibly fast turnaround and the quality of the fix. Consider this confirmed
                        working on:
                        • MMM-Remote-Control 4.2.4
                        • pm2 with file-watch
                        Warmest regards,
                        Ralf
                          @rkorell Thank you very much for this feedback and appreciation 🙂 It’s interesting that you took a deeper look at the changes.
                          • 3 / 3
