    MMM-Remote-Control
    57 Posts 9 Posters 13.0k Views 10 Watching
    • KristjanESPERANTOK Online
      KristjanESPERANTO Module Developer @bloodknot
      @bloodknot Thanks for reporting. Release v4.2.1 should fix it. Please check 🙂
        bloodknot @KristjanESPERANTO
        @KristjanESPERANTO
        I don’t get a failure, however the alert/showalert function does not work:
        {"success":false,"message":"Module alert does not have any actions defined."}
          @bloodknot Thanks for the quick feedback. Okay, that was still progress. Now please try v4.2.2.
            @KristjanESPERANTO
            That seems to have fixed my specific problem. Thank you!!!
            I have tested:
            http://magicmirror2:8080/api/monitor/on
              @KristjanESPERANTO
              Sorry for the split message.
              I have successfully tested:
              http://magicmirrorip:8080/api/monitor/on
              http://magicmirrorip:8080/api/monitor/off
              http://magicmirrorip:8080/api/refresh
              http://magicmirrorip:8080/api/reboot
              http://magicmirrorip:8080/api/alert/showalert
                @bloodknot Perfect, thank you for testing! 😃
                • V Offline
                  vtek
                  hey guys…
                  having some issues using the shutdown/reboot commands…they throw this error, even though I have the API key in the config
                  {“success”:false,“message”:“Forbidden: API Key Not Provided!”}
                  here’s the config
                                      module: 'MMM-Remote-Control',
                                      // position: 'bottom_left', // Required to show URL/QR code on mirror
                                              showModuleApiMenu: true,
                                              secureEndpoints: true,
                                              apiKey: "111111111-2222-3333-4444-555555555555",
                                              customCommand: {
                                                              monitorOnCommand: 'loginctl unlock-session 1',
                                                              monitorOffCommand: 'loginctl lock-session 1',
                                                              shutdownCommand: 'systemctl poweroff',
                                                              rebootCommand: 'systemctl reboot',  // Optional, See "Using Custom Commands" below
                  • V Offline
                    vtek @vtek
                    said in MMM-Remote-Control:
                    hey guys…
                    here’s the config
                                                customCommand: {
                    i figure it out…had to append the apiKey at the end of the url for all commands
                    http://192.168.1.5:8888/api/command/rebootCommand?apiKey=111111111-2222-33333-4444
                    KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
                      rkorell Module Developer @KristjanESPERANTO
                      @KristjanESPERANTO Dear Kristijan,
                      after a long time I finally managed to see your “new” modul.
                      First of all: Thanks a lot for your effort, again - nice piece!
                      In the past few days I’ve completely rebuilt my mirror and migrated it to trixie as well as to the actual mirror and node versions.
                      I ran into a reproducible issue with the restart functionality when MagicMirror is managed by pm2 (which is the recommended setup per the official MagicMirror documentation).
                      The Problem
                      When triggering a restart via the Remote-Control UI (or the /api/restart endpoint), MagicMirror enters an endless crash-loop with EADDRINUSE: address already in use :::8080.
                      Root Cause
                      The handleRestart function in node_helper.js (lines 717-741) uses the Electron-native restart mechanism:
                      const {app} = require("electron");
                      app.relaunch();
                      app.quit();
                      This works fine in standalone mode, but creates a race condition with pm2:
                      1. app.relaunch() spawns a new Electron instance (child of the current process)
                      2. app.quit() terminates the current Electron instance
                      3. pm2 detects the termination as a crash and spawns another Electron instance
                      4. Now two Electron instances compete for port 8080 → EADDRINUSE → both crash → pm2 keeps restarting → infinite loop
                      The only way to recover is to manually identify and kill the orphaned Electron process, then trigger a clean restart via touch config.js (which pm2’s file-watch picks up).
                      Interestingly, the catch-block fallback for server mode (lines 726-739) already does it correctly — it calls process.exit(0) and lets the process manager handle the restart. The Electron code path just doesn’t account for the pm2 scenario.
                      Possible Fix
                      When running under pm2, the Electron-native app.relaunch() should be skipped entirely.
                      pm2 can be detected via environment variables like PM2_HOME, pm_id, or PM2_USAGE:
                      handleRestart (query, res) {
                        try {
                          if (!app) { throw "Could not get Electron app instance."; }
                          // When running under pm2, don't use app.relaunch() — pm2 handles restart
                          if (process.env.PM2_HOME || process.env.pm_id !== undefined) {
                            Log.log("Running under pm2, exiting cleanly for process manager restart...");
                            this.sendResponse(res, undefined, {action: "RESTART", info: "Exiting for pm2 restart..."});
                            setTimeout(() => app.quit(), 1000);
                            return;
                          this.sendResponse(res, undefined, {action: "RESTART", info: "Restarting Electron..."});
                          app.relaunch();
                          app.quit();
                        } catch (error) {
                          // ... existing server mode fallback ...
                      Environment
                      • MagicMirror 2.34.0
                      • MMM-Remote-Control 4.2.2 (commit b854832)
                      • Node.js v22, Electron 39.5.2
                      • Raspberry Pi 5, Debian 13 (Trixie)
                      • Process manager: pm2 with file-watch on config.js
                      Workaround
                      For now, I’ve documented this for my setup: never use the restart button in Remote-Control. Monitor ON/OFF works fine, only the restart is
                      affected.
                      Thanks for considering this — happy to test any fix if needed!
                      Warmest regards,
                      Ralf
                      KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                        KristjanESPERANTO Module Developer @vtek
                        Hi @vtek, glad you figured it out! Just for reference: when secureEndpoints: true is set, the API key can be passed in two ways:
                        1. URL parameter: ?apiKey=YOUR_KEY
                        2. HTTP header: Authorization: apiKey YOUR_KEY
                        Also, starting with v4.2.4 the error message now directly hints at the solution, so the next person running into this should find it faster 🙂
                          KristjanESPERANTO Module Developer @rkorell
                          Hi @rkorell, thank you for the detailed bug report — the root cause analysis was spot on and made it straightforward to fix!
                          The fix is included in v4.2.4: when MMM-Remote-Control detects it’s running under pm2 (via PM2_HOME or pm_id environment variables), it now skips app.relaunch() and only calls app.quit(), letting pm2 handle the restart cleanly.
                          Would be great if you could confirm it works on your setup!
                            just tested v4.2.4 — works perfectly! Restart via the Remote-Control UI now completes cleanly
                            under pm2, no orphaned Electron process, no port conflict. Exactly the behavior you’d expect.
                            I also noticed you added a dedicated handleRestart.test.js with 210 lines of unit tests covering
                            both the pm2 and standalone code paths — that’s really impressive and goes well beyond just a
                            quick fix. Having proper test coverage for this kind of dual-mode behavior is exactly the right
                            thing to do. Much appreciated!
                            Thanks for the incredibly fast turnaround and the quality of the fix. Consider this confirmed
                            working on:
                            • MMM-Remote-Control 4.2.4
                            • pm2 with file-watch
                            Warmest regards,
                            Ralf
                              @rkorell Thank you very much for this feedback and appreciation 🙂 It’s interesting that you took a deeper look at the changes.
                              • 3 / 3
