    MMM-Remote-Control
    57 Posts 9 Posters 14.1k Views 10 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO n also allows you to change version on the fly.
      One nvm ‘benefit’, it stores the node versions in the users home folder at .nvm
      So, on a multi-user system each user could have different node versions.
      As MagicMirror is deployed as only user, it’s functionally the same.
      One n benefit, it stores the version in the /usr/ local folder
      So it requires sudo to make the change, cannot be accidental
      KristjanESPERANTOK 1 Reply Last reply
      • KristjanESPERANTOK
        @sdetweil said in MMM-Remote-Control:
        So it requires sudo to make the change, …
        This can also be seen as a disadvantage 🙂
          @KristjanESPERANTO maybe, if you never use sudo, but we use it very often
            meikelrix @KristjanESPERANTO
            @KristjanESPERANTO Hi, I very much like MMM-Remote-Control!
            The last update has possibly introduced an error with respect to the “Custom Menu Items” => I have a menu item which still shows, but the sub menu items don’t show anymore?
            Else wise please let me repeat: excellent job on MMM-Remote-Control!
            M 1 Reply Last reply
              meikelrix @meikelrix
              FWIW: I’m using the showModuleApiMenu: true setting in config.js as well and the submenus there don’t show either, any more?
                KristjanESPERANTO Module Developer @meikelrix
                @meikelrix I’ll take a look asap :-)
                  KristjanESPERANTO Module Developer @KristjanESPERANTO
                  @meikelrix Please check new release 4.1.1 🙂
                    @KristjanESPERANTO said in MMM-Remote-Control:
                    Thank you very much, that has fixed my custom menu!
                    On the other hand I still don’t see the content of “Modules Controls” menu, although “showModuleApiMenu: true” is set in config.js?
                      @meikelrix Did you set showModuleApiMenu like this?
                            module: "MMM-Remote-Control",
                            position: "bottom_right",
                              showModuleApiMenu: true,
                      Do you also have modules with recognizable notifications? Newsfeed is quite good for testing, for example.
                      If it doesn’t work, show me your config (without secrets of course).
                        @KristjanESPERANTO I did set the showModuleApiMenu: true,
                        I do get the “Module Controls” menu entry, but it has no content AND other notification based modules are working.
                        I noticed as well that the “Updates” doesn’t show modules, anymore. The only one shown is “MagicMirror”, below the message “!No module loaded.”
                        Ok, I renamed MMM-Remote-Contol directory and re-installed following the github instructions. All is working now!
                        Thank you for your help and a great module!
                        • SnilleS
                          Snille Module Developer @KristjanESPERANTO
                          @KristjanESPERANTO
                          I have this problem that has been bugging me for a while…
                          Check this clip: https://photos.app.goo.gl/Zahc5xqttn33frbKA < From API
                          My mirror have lot’s of modules many are multi instances (like MMM-MotionEye in this example).
                          I see the same behavior (or similar) with other modules, mainly my “MMM-homeassistant-sensors”…
                          I often makes API-calls from Node Red in Home Assistant, like this clip: https://photos.app.goo.gl/K9ktuXGKawoyHEez5
                          Errors from the log:
                          0|mmdev  | [2026-01-05 12:24:13.812] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                          0|mmdev  |     at ServerResponse.setHeader (node:_http_outgoing:700:11)
                          0|mmdev  |     at ServerResponse.header (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:686:10)
                          0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:249:10)
                          0|mmdev  |     at Class.sendResponse (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:687:28)
                          0|mmdev  |     at Class.handleSimpleSocketNotification (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:965:10)
                          0|mmdev  |     at SHOW (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1024:28)
                          0|mmdev  |     at Class.executeQuery (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1049:7)
                          0|mmdev  |     at Class.answerModuleApi (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:442:14)
                          0|mmdev  |     at /var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:299:14
                          0|mmdev  |     at Layer.handleRequest (/var/www/html/magicmirror/m/node_modules/router/lib/layer.js:152:17)
                          0|mmdev  |     at next (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:157:13)
                          0|mmdev  |     at Route.dispatch (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:117:3)
                          0|mmdev  |     at handle (/var/www/html/magicmirror/m/node_modules/router/index.js:435:11)
                          0|mmdev  |     at /var/www/html/magicmirror/m/node_modules/router/index.js:295:15
                          0|mmdev  |     at param (/var/www/html/magicmirror/m/node_modules/router/index.js:600:14)
                          0|mmdev  | [2026-01-05 12:24:28.662] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                          0|mmdev  |     at ServerResponse.send (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:163:12)
                          0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:252:15)
                          0|mmdev  |     at HIDE (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1023:28)
                          I also experience that when calling a specific module to show with “module_number_modulename”, it often shows the “wrong” module-instance (of that type of module, like MMM-homeassistant-sensors, but the wrong one)… I don’t know if it’s related to this.
                          Let me know if you need anything more…
                          Thank you for this great module! :)
                            KristjanESPERANTO Module Developer @Snille
                            @Snille Thanks for the detailed report. I think I’ve fixed it. Please update to the new release v4.1.4 and give me some feedback 🙂
                            SnilleS 1 Reply Last reply
                            • SnilleS
                              @KristjanESPERANTO You are welcome, It’s me who should thank you for all the great stuff! :) It’s almost working…
                              The error messages are gone, but it still shows and hides “both” modules (MMM-MotionEye in my example clip)… :)
                              Let me know if you want anything else? There is nothing in the “logs” now… :)
                                @Snille That was tricky, but I think I’ve solved that too. Please take a look at the new release v4.1.5 🙂
                                • SnilleS
                                  @KristjanESPERANTO It is working!! Awesome! Thanks you very much! :)
                                    @Snille Cool. I’m glad it works 🎉
                                    B 1 Reply Last reply
                                      bloodknot @KristjanESPERANTO
                                      @KristjanESPERANTO - Cannot GET /api/refresh (or any API call)
                                      MMM-Remote-Control is working fine on the same computer that the API is not found. This occurred in the last couple of updates. Nothing else changed in the configuration and/or modules.
                                      magicmirror2 = 192.168.4.21
                                      http://magicmirror2:8080/remote.html#main-menu WORKS from 192.168.4.210
                                      http://magicmirror2:8080/api/refresh Does NOT Work from 192.168.4.210
                                      MM Config:
                                      address: "0.0.0.0",
                                      port: 8080
                                      basePath: "/",
                                      ipWhitelist:[],
                                      module: 'MMM-Remote-Control',
                                      	customCommand: {}
                                           	secureEndpoints: true,
                                           	apiKey: '********-****-****-****-************'
                                           	showQRCode: false
                                      GET http://magicmirror2:8080/api/refresh?apiKey=********-****-****-****-************ 404 (Not Found)
                                      What has changed? Did I miss an update? Any assistance will be great
                                        KristjanESPERANTO Module Developer @bloodknot
                                        @bloodknot I think I solved it, please update to v4.2.0 and check 🙂
                                          @KristjanESPERANTO
                                          Update to 4.2.0 fixed the issue. Thanks for the quick response!!
                                            bloodknot @bloodknot
                                            @kristjanesperanto
                                            It looks like something also happened to showalert:
                                            http://magicmirrorip:8080/api/module/alert/showalert?message=Hello&timer=2000&apiKey=********-****-****-****-**********
                                            TypeError: Cannot read properties of undefined (reading 'showalert')
                                                at Class.answerModuleApi (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:457:35)
                                                at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:296:14
                                                at Layer.handleRequest (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/layer.js:152:17)
                                                at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:157:13)
                                                at Route.dispatch (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/lib/route.js:117:3)
                                                at handle (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:435:11)
                                                at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:295:15
                                                at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:600:14)
                                                at param (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:610:14)
                                                at processParams (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:664:3)
                                                at next (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:291:5)
                                                at /home/bloodknot/MagicMirror/modules/MMM-Remote-Control/API/api.js:148:7
                                                at trimPrefix (/home/bloodknot/MagicMirror/modules/MMM-Remote-Control/node_modules/router/index.js:342:13)
                                            • 2 / 3
