    MMM-Remote-Control
    57 Posts 9 Posters 10.5k Views 10 Watching
      sdetweil @rkorell
      @rkorell said in MMM-Remote-Control:
      npm ci
      be careful… the package.json was built and tested on a cloud based virtual machine.
      pi and other hardware types MAY need a different version of a dependency, i’ve only seen it myself twice in 6 years, but
      npm ci uses the exact package.json
      npm install will get the appropriate for this platform, even if the version changes.
      anyhow… I use npm install --omit=dev when I do the installs script or MMM-Config
        OK; thanks for this hint.
        May npm install has avoided the resulting error which I had to solve…
        Anyway: Thanks a LOT!
        Regards,
        Ralf
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @rkorell
          Thanks for the feedback!
          Since Sam has already addressed some of the issues, I won’t go into them again.
          A few problems were mentioned, some of which I have just addressed with v4.1.0. E.g.:
          • Restart/Shutdown: Should now also work on systems without PM2.
          • Minimize: Now says “restart to restore” so you know how to undo it.
          About the monitor control issue:
          This would be tricky to get running by default everywhere because every system uses different commands (X11/Wayland/etc). You have to check the Monitor Control docs and configure the right commands for your specific setup - the defaults won’t work everywhere.
          About the “npm install/npm ci” topic:
          Yes, npm ci can be problematic for modules with native dependencies that need platform-specific builds. However, MMM-Remote-Control only uses pure JavaScript dependencies (marked, qrcode, simple-git, swagger-ui-dist, uuid) - no native modules that require compilation.
          For this module, npm ci is actually the better choice because:
          • Guarantees exact tested versions which the developers released
          • Faster installation (no dependency resolution)
          • Same behavior in CI and production
          • No change on the package-lock.json
          So the warning about npm ci is valid in general, but doesn’t apply here.
          About the microupdates. Since the test suite does not a lot parts yet, some details simply go unnoticed after major changes. If you are not experiencing any problems with the module, you do not need to install every update.
          About node update: I recommend using nvm for node updates. This is also what is offered as default for Linux on the official download page. This makes many things easier - like if something does not work after an update, you can easily switch back to the previous node version. So you don’t need to be so afraid of updates.
          S R 2 Replies Last reply Reply Quote 0
            KristjanESPERANTO Module Developer @S374n
            @S374n said in MMM-Remote-Control:
            First update changes my main.css - took me a while to figure it out and redo all my customizations.
            You should not change main.css. All customizations should be made in custom.css: https://docs.magicmirror.builders/modules/customcss.html#custom-css
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO n also allows you to change version on the fly.
              One nvm ‘benefit’, it stores the node versions in the users home folder at .nvm
              So, on a multi-user system each user could have different node versions.
              As MagicMirror is deployed as only user, it’s functionally the same.
              One n benefit, it stores the version in the /usr/ local folder
              So it requires sudo to make the change, cannot be accidental
              KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                KristjanESPERANTO Module Developer @sdetweil
                @sdetweil said in MMM-Remote-Control:
                So it requires sudo to make the change, …
                This can also be seen as a disadvantage 🙂
                  @KristjanESPERANTO maybe, if you never use sudo, but we use it very often
                    meikelrix @KristjanESPERANTO
                    @KristjanESPERANTO Hi, I very much like MMM-Remote-Control!
                    The last update has possibly introduced an error with respect to the “Custom Menu Items” => I have a menu item which still shows, but the sub menu items don’t show anymore?
                    Else wise please let me repeat: excellent job on MMM-Remote-Control!
                      meikelrix @meikelrix
                      FWIW: I’m using the showModuleApiMenu: true setting in config.js as well and the submenus there don’t show either, any more?
                        KristjanESPERANTO Module Developer @meikelrix
                        @meikelrix I’ll take a look asap :-)
                          KristjanESPERANTO Module Developer @KristjanESPERANTO
                          @meikelrix Please check new release 4.1.1 🙂
                            @KristjanESPERANTO said in MMM-Remote-Control:
                            Thank you very much, that has fixed my custom menu!
                            On the other hand I still don’t see the content of “Modules Controls” menu, although “showModuleApiMenu: true” is set in config.js?
                              @meikelrix Did you set showModuleApiMenu like this?
                                    module: "MMM-Remote-Control",
                                    position: "bottom_right",
                                      showModuleApiMenu: true,
                              Do you also have modules with recognizable notifications? Newsfeed is quite good for testing, for example.
                              If it doesn’t work, show me your config (without secrets of course).
                                @KristjanESPERANTO I did set the showModuleApiMenu: true,
                                I do get the “Module Controls” menu entry, but it has no content AND other notification based modules are working.
                                I noticed as well that the “Updates” doesn’t show modules, anymore. The only one shown is “MagicMirror”, below the message “!No module loaded.”
                                Ok, I renamed MMM-Remote-Contol directory and re-installed following the github instructions. All is working now!
                                Thank you for your help and a great module!
                                • SnilleS Offline
                                  Snille Module Developer @KristjanESPERANTO
                                  @KristjanESPERANTO
                                  I have this problem that has been bugging me for a while…
                                  Check this clip: https://photos.app.goo.gl/Zahc5xqttn33frbKA < From API
                                  My mirror have lot’s of modules many are multi instances (like MMM-MotionEye in this example).
                                  I see the same behavior (or similar) with other modules, mainly my “MMM-homeassistant-sensors”…
                                  I often makes API-calls from Node Red in Home Assistant, like this clip: https://photos.app.goo.gl/K9ktuXGKawoyHEez5
                                  Errors from the log:
                                  0|mmdev  | [2026-01-05 12:24:13.812] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                                  0|mmdev  |     at ServerResponse.setHeader (node:_http_outgoing:700:11)
                                  0|mmdev  |     at ServerResponse.header (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:686:10)
                                  0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:249:10)
                                  0|mmdev  |     at Class.sendResponse (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:687:28)
                                  0|mmdev  |     at Class.handleSimpleSocketNotification (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:965:10)
                                  0|mmdev  |     at SHOW (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1024:28)
                                  0|mmdev  |     at Class.executeQuery (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1049:7)
                                  0|mmdev  |     at Class.answerModuleApi (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:442:14)
                                  0|mmdev  |     at /var/www/html/magicmirror/m/modules/MMM-Remote-Control/API/api.js:299:14
                                  0|mmdev  |     at Layer.handleRequest (/var/www/html/magicmirror/m/node_modules/router/lib/layer.js:152:17)
                                  0|mmdev  |     at next (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:157:13)
                                  0|mmdev  |     at Route.dispatch (/var/www/html/magicmirror/m/node_modules/router/lib/route.js:117:3)
                                  0|mmdev  |     at handle (/var/www/html/magicmirror/m/node_modules/router/index.js:435:11)
                                  0|mmdev  |     at /var/www/html/magicmirror/m/node_modules/router/index.js:295:15
                                  0|mmdev  |     at param (/var/www/html/magicmirror/m/node_modules/router/index.js:600:14)
                                  0|mmdev  | [2026-01-05 12:24:28.662] [ERROR] undefined Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
                                  0|mmdev  |     at ServerResponse.send (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:163:12)
                                  0|mmdev  |     at ServerResponse.json (/var/www/html/magicmirror/m/node_modules/express/lib/response.js:252:15)
                                  0|mmdev  |     at HIDE (/var/www/html/magicmirror/m/modules/MMM-Remote-Control/node_helper.js:1023:28)
                                  I also experience that when calling a specific module to show with “module_number_modulename”, it often shows the “wrong” module-instance (of that type of module, like MMM-homeassistant-sensors, but the wrong one)… I don’t know if it’s related to this.
                                  Let me know if you need anything more…
                                  Thank you for this great module! :)
                                  If you cant find it, make it and share it
                                  MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                                    KristjanESPERANTO Module Developer @Snille
                                    @Snille Thanks for the detailed report. I think I’ve fixed it. Please update to the new release v4.1.4 and give me some feedback 🙂
                                    SnilleS 1 Reply Last reply Reply Quote 0
                                    • SnilleS Offline
                                      @KristjanESPERANTO You are welcome, It’s me who should thank you for all the great stuff! :) It’s almost working…
                                      The error messages are gone, but it still shows and hides “both” modules (MMM-MotionEye in my example clip)… :)
                                      Let me know if you want anything else? There is nothing in the “logs” now… :)
                                        @Snille That was tricky, but I think I’ve solved that too. Please take a look at the new release v4.1.5 🙂
                                        SnilleS 1 Reply Last reply Reply Quote 1
                                        • SnilleS Offline
                                          @KristjanESPERANTO It is working!! Awesome! Thanks you very much! :)
                                            @Snille Cool. I’m glad it works 🎉
                                            • 2 / 3
