    MMM-Remote-Control
    57 Posts 9 Posters 13.0k Views 10 Watching
      Good point!
      Unfortunately I’ve already DONE the upgrade of remote-control - and now it doesn’t work anymore :-)
        just ran a testrun of your upgrade script:
        pi@MagicMirrorPi5:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        Minimum Node version: v22.18.0
        Installed Node version: v20.18.1
        Node should be upgraded.
        Node.js upgrade defered, doing test run
        Minimum npm version: V10.9.2
        Installed npm version: V10.8.2
        npm should be upgraded.
        npm upgrade defered, doing test run  ...
        saving custom.css
        reverting to master branch from _fix_clipping, saving changed files
        would restore file modules/default/weather/current.njk before switch back to master branch
        would restore file package-lock.json before switch back to master branch
        would restore file package.json before switch back to master branch
        error: Your local changes to the following files would be overwritten by checkout:
                package-lock.json
                package.json
        Please commit your changes or stash them before you switch branches.
        Aborting
        unable to change back to master branch, stopping execution
        What does the last message mean?
        “unable to change back to master branch, stopping execution”
        What have I to do?
          BTW: Do you know if it is possible to restore the “old” version from remote-control?
          May THIS is the better option for me?
            sdetweil @rkorell
            @rkorell can you tell me when old was? luckily this module uses tags for releases, so you could restore to one of the previous releases…
            in the module folder do
            git fetch --all --tags
            then when we figure out which release to try, we can
            git checkout <tag_name>
            Release 3.2.1 was about 5 months ago.
              @sdetweil I’ve found V3.3.2 and just try "git checkout 1f451ce "
                sdetweil @rkorell
                @rkorell if you pull the tags, you can use the tag name
                git checkout v3.3.2
                  For some really strange reasons, neither
                  pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ git fetch --all --tags
                  pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ git fetch --tags
                  currently give any feedback…
                  So I’ve worked with the found git-hash:
                  This at least worked and rolled back to V. 3.3.2.
                  Unfortunately some dependencies (package-lock.json ???) are not strict enough, so the rollback produces an error message:
                  [ERROR] Error when loading MMM-Remote-Control: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js not supported.
                  So I downgraded UUID:
                  cd ~/MagicMirror/modules/MMM-Remote-Control
                  npm install uuid@9.0.1
                  npm ci --omit=dev
                  With this module is running again.
                  From now on I’m in a in ‘detached HEAD’ state - but this seems OK.
                  Thanks for your time, effort and always great help!
                  Ralf
                    sdetweil @rkorell
                    @rkorell I was just about to add that you needed to redo the npm install for the module after deleting the node_modules folder
                    else you were trying to run the new dependencies with the old code
                    but you fixed it…
                      Yes :-)
                      In fact I’ve used
                      npm ci --omit=dev
                      this does the deletion of the node_modules folder inherently AFAIK …
                      Thanks again, dear Sam!
                      Ralf
                        sdetweil @rkorell
                        @rkorell said in MMM-Remote-Control:
                        npm ci
                        be careful… the package.json was built and tested on a cloud based virtual machine.
                        pi and other hardware types MAY need a different version of a dependency, i’ve only seen it myself twice in 6 years, but
                        npm ci uses the exact package.json
                        npm install will get the appropriate for this platform, even if the version changes.
                        anyhow… I use npm install --omit=dev when I do the installs script or MMM-Config
                          OK; thanks for this hint.
                          May npm install has avoided the resulting error which I had to solve…
                          Anyway: Thanks a LOT!
                          Regards,
                          Ralf
                          • KristjanESPERANTOK Offline
                            KristjanESPERANTO Module Developer @rkorell
                            Thanks for the feedback!
                            Since Sam has already addressed some of the issues, I won’t go into them again.
                            A few problems were mentioned, some of which I have just addressed with v4.1.0. E.g.:
                            • Restart/Shutdown: Should now also work on systems without PM2.
                            • Minimize: Now says “restart to restore” so you know how to undo it.
                            About the monitor control issue:
                            This would be tricky to get running by default everywhere because every system uses different commands (X11/Wayland/etc). You have to check the Monitor Control docs and configure the right commands for your specific setup - the defaults won’t work everywhere.
                            About the “npm install/npm ci” topic:
                            Yes, npm ci can be problematic for modules with native dependencies that need platform-specific builds. However, MMM-Remote-Control only uses pure JavaScript dependencies (marked, qrcode, simple-git, swagger-ui-dist, uuid) - no native modules that require compilation.
                            For this module, npm ci is actually the better choice because:
                            • Guarantees exact tested versions which the developers released
                            • Faster installation (no dependency resolution)
                            • Same behavior in CI and production
                            • No change on the package-lock.json
                            So the warning about npm ci is valid in general, but doesn’t apply here.
                            About the microupdates. Since the test suite does not a lot parts yet, some details simply go unnoticed after major changes. If you are not experiencing any problems with the module, you do not need to install every update.
                            About node update: I recommend using nvm for node updates. This is also what is offered as default for Linux on the official download page. This makes many things easier - like if something does not work after an update, you can easily switch back to the previous node version. So you don’t need to be so afraid of updates.
                            S R 2 Replies Last reply Reply Quote 0
                              KristjanESPERANTO Module Developer @S374n
                              @S374n said in MMM-Remote-Control:
                              First update changes my main.css - took me a while to figure it out and redo all my customizations.
                              You should not change main.css. All customizations should be made in custom.css: https://docs.magicmirror.builders/modules/customcss.html#custom-css
                                sdetweil @KristjanESPERANTO
                                @KristjanESPERANTO n also allows you to change version on the fly.
                                One nvm ‘benefit’, it stores the node versions in the users home folder at .nvm
                                So, on a multi-user system each user could have different node versions.
                                As MagicMirror is deployed as only user, it’s functionally the same.
                                One n benefit, it stores the version in the /usr/ local folder
                                So it requires sudo to make the change, cannot be accidental
                                KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                                  @sdetweil said in MMM-Remote-Control:
                                  So it requires sudo to make the change, …
                                  This can also be seen as a disadvantage 🙂
                                    @KristjanESPERANTO maybe, if you never use sudo, but we use it very often
                                      meikelrix @KristjanESPERANTO
                                      @KristjanESPERANTO Hi, I very much like MMM-Remote-Control!
                                      The last update has possibly introduced an error with respect to the “Custom Menu Items” => I have a menu item which still shows, but the sub menu items don’t show anymore?
                                      Else wise please let me repeat: excellent job on MMM-Remote-Control!
                                        meikelrix @meikelrix
                                        FWIW: I’m using the showModuleApiMenu: true setting in config.js as well and the submenus there don’t show either, any more?
                                          KristjanESPERANTO Module Developer @meikelrix
                                          @meikelrix I’ll take a look asap :-)
                                            KristjanESPERANTO Module Developer @KristjanESPERANTO
                                            @meikelrix Please check new release 4.1.1 🙂
                                            • 2 / 3
