    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 15.8k Views 8 Watching
    • I Offline
      inteeraymee
      Please help!
      I just updated my MM to the new version and right after doing that my calendar would not load any events. Prior to the update it was working fine. Is there anything in the config I need to tweak? Everything else seems to be working fine.
      Thanks in advance!
        angeliKITTYx @sdetweil
        @sdetweil @kristjanesperanto we are up and running!! even fixed the issue of one of my calendars loading slowly (: thank you both so so so much!
        S 1 Reply Last reply Reply Quote 2
          sdetweil @inteeraymee
          @inteeraymee can you tell us more?
          Where is your calendar sourced? Google, Apple, caldav,
          How did you update to latest MagicMirror
          How do you start MagicMirror? Pm2, or some other way
          H I 2 Replies Last reply Reply Quote 0
          • H Offline
            HeikoGr @sdetweil
            @sdetweil @inteeraymee
            I have the same issue after updating from MagicMirror 2.34.0 to 2.35.0.
            In my case this is not a general calendar config problem and not an auth/fetch problem either. Some calendars still load fine, others fail right after the update, which pointed me to a parser regression.
            What I found:
            MagicMirror 2.34.0 used node-ical 0.22.1
            MagicMirror 2.35.0 uses node-ical 0.25.6
            The affected calendars are fetched successfully with HTTP 200
            The failure happens during ICS parsing
            These are the two of the log lines I get:
            [ERROR] [calendar] https://<server>/remote.php/dav/calendars/xx1/?export - iCal parsing failed: Cannot parse: 1-01-15T12:00:00Z
            [DEBUG] [calendar] Parsed iCal data from https://<server>/remote.php/dav/calendars/xx2/?export with 130 entries.
            The important detail in the broken ICS files is this VTIMEZONE block:
            BEGIN:VTIMEZONE
            TZID:W. Europe Standard Time
            BEGIN:DAYLIGHT
            DTSTART:00010325T020000
            TZOFFSETFROM:+0100
            TZOFFSETTO:+0200
            RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=3
            END:DAYLIGHT
            BEGIN:STANDARD
            DTSTART:00011028T030000
            TZOFFSETFROM:+0200
            TZOFFSETTO:+0100
            RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=10
            END:STANDARD
            END:VTIMEZONE
            I tested the exact same ICS file with both node-ical versions:
            node-ical 0.22.1: parses successfully
            node-ical 0.25.6: fails with Cannot parse: 1-01-15T12:00:00Z
            I also verified that if I remove only that W. Europe Standard Time VTIMEZONE block from the failing ICS, the file parses again with node-ical 0.25.6.
            So the problem seems to be a regression in node-ical 0.25.x when resolving VTIMEZONE definitions with year 0001 in DTSTART. The calendar fetch itself succeeds; the crash happens while parsing timezone metadata.
            This may especially affect calendars coming from Outlook/Exchange/Nextcloud imports, because W. Europe Standard Time looks like a Microsoft-style timezone definition.
            • H Offline
              HeikoGr
              i filed an issue: https://github.com/jens-maus/node-ical/issues/495
              it could be an edge case on my side.
              @inteeraymee by any chance: did you use emClient anytime in the past?
              only workaround for my setup is to pin to v2.34.0 .
              Updating the calendars might be the best solution for me…
                sdetweil @HeikoGr
                @HeikoGr we originally never parsed the vtimezone sections
                • I Offline
                  inteeraymee @sdetweil
                  @sdetweil I have about 5 that are sourced in Google and another 2 or so that are subscription-based (i.e. sports teams).
                  The way that I am starting MM is via ssh since my monitor is inside a frame up on a wall, making it a challenge to connect directly. The script I use is:
                  sudo -u rudin-fam
                  DISPLAY=:0
                  XAUTHORITY=/home/rudin-fam/.Xauthority
                  nohup chromium --kiosk http://localhost:8080
                  –noerrdialogs
                  –disable-infobars
                  –disable-session-crashed-bubble
                  –disable-restore-session-state
                  >/dev/null 2>&1 &
                    @inteeraymee that’s the display side, where is the server side?
                    • H Offline
                      hrt13 @sdetweil
                      @sdetweil Hi, I am having the same problem since upgrading this morning (MM v2.35)
                      5 calendars, all from Google
                      Platform: Raspberry Pi3 B
                      OS: Debian GNU/Linux 11 (bullseye)
                      I haven’t tried regenerating the calendar links, should I?
                        sdetweil @hrt13
                        @hrt13 shouldn’t need to
                        Are there any errors reported in the console log where you start MagicMirror?
                        If using pm2, then
                        pm2 logs —lines=xxx
                        Xxx is the number of latest lines to display, default 15
                        You might need 100
                        • H Offline
                          hrt13 @sdetweil
                          @sdetweil Using pm2, I see a lot of “could not expand event” errors. Here’s one:
                          " [2026-04-02 12:29:21.274] [ERROR] [calendar] Could not expand event “Hockey vs. C”: ical.expandRecurringEvent is not a function"
                            sdetweil @hrt13
                            @hrt13 awesome to help could you find that event
                            curl -sL the_url_for_calendar >somefile.txt
                            Then edit somefile.txt and search for that title
                            Copy
                            Begin:vevent
                            End:vevent
                            And paste here. In code block
                            Edit Any info that might identify you, just dont delete any lines
                            • H Offline
                              hrt13 @sdetweil
                              I think this is it, it may be in the past (I’ll look for a more current one, I didn’t think I was getting events from the past), also, sorry about the ^M’s:
                              BEGIN:VEVENT
                              DTSTART:20150228T005000Z
                              DTEND:20150228T022000Z
                              DTSTAMP:20260402T201324Z
                              UID:somenumber@google.com
                              CREATED:20150130T132500Z
                              LAST-MODIFIED:20150130T132500Z
                              SEQUENCE:0
                              STATUS:CONFIRMED
                              SUMMARY:Hockey vs. C
                              TRANSP:OPAQUE
                              END:VEVENT
                                sdetweil @hrt13
                                @hrt13 is there one on a repeating schedule?
                                We shouldn’t expand one if it doesn’t have an rrule
                                H 2 Replies Last reply Reply Quote 0
                                • H Offline
                                  hrt13 @sdetweil
                                  @sdetweil said:
                                  There are some recent repeating events though I’m not sure any show in the logs. I’ll see if I can find some new events. Looking at the logs again, it seems it’s retrieving lots of past events which, of course, wouldn’t show on the calendar. The latest I’ve seen so far is an event from Jan 2026.
                                  • H Offline
                                    hrt13 @sdetweil
                                    @sdetweil this is definitely a repeating schedule
                                    Log file error:
                                    [2026-04-02 19:59:16.671] [ERROR] [calendar] Could not expand event “Tax Day”: ical.expandRecurringEvent is not a function
                                    curl -sL output
                                    BEGIN:VCALENDAR
                                    PRODID:-//Google Inc//Google Calendar 70.9054//EN
                                    VERSION:2.0
                                    CALSCALE:GREGORIAN
                                    METHOD:PUBLISH
                                    X-WR-CALNAME:Holidays in United States
                                    X-WR-TIMEZONE:UTC
                                    X-WR-CALDESC:Holidays and Observances in United States
                                    BEGIN:VEVENT
                                    DTSTART;VALUE=DATE:20220418
                                    DTEND;VALUE=DATE:20220419
                                    DTSTAMP:20260403T003912Z
                                    UID:20220418_clveaq2fmqp95elk3vma4ifhcs@google.com
                                    CLASS:PUBLIC
                                    CREATED:20240603T101345Z
                                    DESCRIPTION:Observance\nTo hide observances\, go to Google Calendar Setting
                                     s > Holidays in United States
                                    LAST-MODIFIED:20240603T101345Z
                                    SEQUENCE:0
                                    STATUS:CONFIRMED
                                    SUMMARY:Tax Day
                                    TRANSP:TRANSPARENT
                                    END:VEVENT
                                    BEGIN:VEVENT
                                    DTSTART;VALUE=DATE:20260415
                                    DTEND;VALUE=DATE:20260416
                                    UID:20260415_fkehtfbgrr6j65q23flu2k5vu0@google.com
                                    CLASS:PUBLIC
                                    CREATED:20240603T101355Z
                                    LAST-MODIFIED:20240603T101355Z
                                    SEQUENCE:0
                                    STATUS:CONFIRMED
                                    SUMMARY:Tax Day
                                    TRANSP:TRANSPARENT
                                    END:VEVENT
                                    S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                      sdetweil @hrt13
                                      @hrt13 hmm. A repeating event has one vevent, with an rrule line that describes how it repeats
                                      • KristjanESPERANTOK Offline
                                        KristjanESPERANTO Module Developer @hrt13
                                        Looks like you didn’t update the dependencies after you pulled the new MM version.
                                        Please run node --run install-mm and check again.
                                        • H Offline
                                          hrt13 @KristjanESPERANTO
                                          trying it now, it is taking a while. Will let you know.
                                          I used mmpm to update, I guess it doesn’t update the dependencies.
                                            A workaround for users still having issues with the calendar. There was a problem with the node-ical package for some events. This has just been fixed with a new node-ical release (v0.26.0).
                                            To use the new version, run this command in the MagicMirror directory:
                                            npm install node-ical@latest.
                                            Note that this will change your package.json and package-lock.json files, which would cause conflicts during the next MagicMirror update. Therefore, also run the following to restore them:
                                            git restore package*.json
                                            You will then have v0.26.0 installed - the package.json file say otherwise, but that doesn’t matter.
                                            Please give some feedback if that helps :-)
                                              doogy_rev
                                              I have just updated to the latest version and have the same issue of the Calendar not loading.
                                              I have tried the above suggestions but still not able to load gmail calendars
                                              I did use the script to update MM and all dependancies
                                              Any help appreciated
                                              DoogyRev
                                              • 1 / 4
