    TeamViewer for PI
    5 Posts 5 Posters 3.3k Views 4 Watching
    • mpiresM Offline
      mpires
      I have been running teamviewer on my PI, and is works very well, i was afraid that TeamViewer would consume a lot of resources, but for what i see almost non, so until now is ok, the only problem i have is that TeamViewer will pop-up a window on every PI reboot, and the problem is that will appear over my MM.
      I have try few solution by googling, to minimize teamviewer window, but non did work…
      Any suggestion?
      I usually do everything by SSH, but i would like to have this option enable just in case, i know i can use VNC, but i prefer teamviewer.
      R S 2 Replies Last reply Reply Quote 0
        roramirez Core Contributors @mpires
        @mpires Ngrok
        Easy module development with MagicMirror Module Template
          shashank @mpires
          @mpires hi, follow the below steps to install TV
          copy Teamviewer using below url on your PC then transfer the file to Raspi Desktop
          1. http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb
          2. sudo apt-get -f install
          3. sudo dpkg -i teamviewer-host_11.0.63329_armhf.deb
            Messel
            @mpires Did you try any of the suggestions in this thread? I’m having the same issue as you with Teamviewer. And I really need to have it running on my mirror, because SSH is still kind of new to me and I find it easier when I can see what’s going on :-)
              DoctorNoob @Messel
              @Messel @mpires Bump. Any luck with this?
