    MMM-MovieListings
    29 Posts 12 Posters 23.2k Views 12 Watching
      Radu_Stancu
      Hi, I have tried the code you provided, and it partially does what I want.
      It changes the font size and color of the actors but not of the description.
      I want to enlarge the module as a whole, image, description and any text while also making them white, as my mirror is a bit darker than I was expecting.
      Any further help is greatly appreciated.
        Mykle1 Project Sponsor Module Developer @Radu_Stancu
        @radu_stancu
        I don’t have an API key for this module so I can’t run it or test it. Looking through the module.js file to see the className of the description text but it’s not immediately apparent. You could try:
        .MMM-MovieListings .dimmed {
          font-size: 18px;
          color: #FFFFFF;   /* white */
          Radu_Stancu @Mykle1
          @mykle1 Thanks, it`s getting closer to what I want. I will check the module you are mentioning. I am not that familiar with js so I did not recognize the things I need to change to accomplish what I was looking for. I will try again and see if I can make the image a bit bigger and the title white. Thanks a lot for your patience.
            @radu_stancu
            No worries, mate. Good luck and have fun.
              Socrates
              Hopefully its ok to necro bump this topic instead of opening a new thread, as this is the official module page?
              The module was working fine until few days back since seeral years, but now it has stopped working. I have regenerated a new api key from tmdb, yet no luck.
                sdetweil @Socrates
                @Socrates the Official page is the github repo, id check its issues list
                do you see any errors listed in the output of npm start?
                  DarkV
                  I have tried the script to update itScreenshot 2024-12-19 143617.png and failed. How do I update this module?
                    sdetweil @DarkV
                    @DarkV all modules update the same way
                    cd to the module folder
                    cd ~/MagicMirror/modules/{modulename}
                    git pull
                    #if that fails, fix before continuing
                    #if that succeeds, then IF there is a package.json file
                    do
                    npm install  (or npm run update if the module documents it this way)
                    restart MagicMirror
                    you can disable the updatenotifcations module to avoid having this display
                    you can also configure it to exclude some modules and also autoupdate some modules
                      DarkV @sdetweil
                      This is the results
                      junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-MovieListings $ git pull
                      hint: Pulling without specifying how to reconcile divergent branches is
                      hint: discouraged. You can squelch this message by running one of the following
                      hint: commands sometime before your next pull:
                      hint:
                      hint: git config pull.rebase false # merge (the default strategy)
                      hint: git config pull.rebase true # rebase
                      hint: git config pull.ff only # fast-forward only
                      hint:
                      hint: You can replace “git config” with “git config --global” to set a default
                      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                      hint: or --ff-only on the command line to override the configured default per
                      hint: invocation.
                      Updating e095eb5…b4f37fc
                      error: Your local changes to the following files would be overwritten by merge:
                      package-lock.json
                      Please commit your changes or stash them before you merge.
                      Aborting
