    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 241.0k Views 13 Watching
      RedNax Module Developer @jagerpower
      @jagerpower try setting pws to ‘pws:IUTRECHT148’ in your config:
      pws: 'pws:IUTRECHT148',
        jagerpower @RedNax
        @RedNax Thank you for this module and help, it works now
          @jagerpower Thanks and enjoy!!
            jagerpower @RedNax
            @RedNax alt text
            is there a way to remove the time? and get more days (like weather forecast from sunday to saterday?)
            • P Offline
              pugsly
              Thanks for all the help, its working now with the correct directory and icons in the directory and icon settings in the config.js file.
              I didn’t realize that the bit temp was also part of this module so I don’t need to call the original weather module for that ether.
              Great work!!!
              • C Offline
                CommanderB
                Love this. Thanks. There are a couple of issues I’m working through, trying to help fix. The first is that beaufort icon isn’t showing because this isn’t defined in the CSS files. I would expect it to be in weather-icons-wind.css but its not.
                Adding the definitions -
                .wi-wind-beaufort-0:before {
                  content: "\f0b7";
                .wi-wind-beaufort-1:before {
                  content: "\f0b8";
                .wi-wind-beaufort-2:before {
                  content: "\f0b9";
                .wi-wind-beaufort-3:before {
                  content: "\f0ba";
                .wi-wind-beaufort-4:before {
                  content: "\f0bb";
                .wi-wind-beaufort-5:before {
                  content: "\f0bc";
                .wi-wind-beaufort-6:before {
                  content: "\f0bd";
                .wi-wind-beaufort-7:before {
                  content: "\f0be";
                .wi-wind-beaufort-8:before {
                  content: "\f0bf";
                .wi-wind-beaufort-9:before {
                  content: "\f0c0";
                .wi-wind-beaufort-10:before {
                  content: "\f0c1";
                .wi-wind-beaufort-11:before {
                  content: "\f0c2";
                .wi-wind-beaufort-12:before {
                  content: "\f0c3";
                to MMM-WunderGround.css fixes this.
                • C Offline
                  CommanderB
                  The next issue is that the config variable hourlyInterval gets ignored. This can be fixed by changing line 238 to
                  var forecast = this.hourlyforecast[f * this.config.hourlyinterval];
                    RedNax Module Developer @CommanderB
                    @CommanderB Thanks for cleaning up my messes! :)
                    The icons you seek are in the included weather-icons.css. I do agree you’d expect them in weather-icons-wind.css
                    However it’s entirely possible that MM uses the one weather-icons included in the vendor dir first. They’re not in that one.
                      content: "\f0b7";
                      content: "\f0b8";
                      content: "\f0b9";
                      content: "\f0ba";
                      content: "\f0bb";
                      content: "\f0bc";
                      content: "\f0bd";
                      content: "\f0be";
                      content: "\f0bf";
                      content: "\f0c0";
                      content: "\f0c1";
                      content: "\f0c2";
                      content: "\f0c3";
                    • P Offline
                      pugsly
                      if you put a copy of weather-icons-wind.css into the vendor/weather-icons folder that should fix it.
                        @jagerpower You can set hourly to 0 in the config. This will remove the hourly forecasts… You can also adjust fcdaycount to the number of days you want to be shown.
                          jagerpower @RedNax
                          @RedNax is it possible to remove the English translation in the alert?
                            Could be done by manipulating the string, however this might break things when other languages are selected. Could even be dependent on your pws… I’ll have a go at making it configurable…
                              It’s a bit of a hack, but after getting the new version from github you can define
                              alerttruncatestring: "english:"
                              in your config. The alerttext will hen be truncated at the defined word/string
                              • P Offline
                                paviro @pugsly
                                @pugsly you should not let users add stuff to the vendor folder! Plugin should be self containing :)
                                – The Doctor
                                • P Offline
                                  pugsly
                                  So I came home today and noticed that the weather had not refreshed in two days. When I did a pm2 mm restart it did refresh but now im wondering maybe its not refreshing on its own? is there a config setting for how often it does a refresh?
                                    RedNax Module Developer @pugsly
                                    @pugsly That’s strange! There is a setting, but it has a default 10 minute setting.
                                    Did you look at the log for clues?
                                    updateInterval: 10 * 60 * 1000, // every 10 minutes
                                      djsunrise19
                                      How can I find the locid? I try a few options but everytime I get an error in my console:
                                      http://***:8080/modules/MMM-Wunderground//MMM-Wunderground.js
                                      Failed to load resource: the server responded with a status of 404 (Not Found)
                                      Also with: pws: ‘pws:IUTRECHT148’, OR pws: ‘NY/New_York’ OR pws: ‘locid:NLXX8014;loctype:1’
                                        Could you post the relevant config.js section? Could you also check on your pi if /modules/MMM-Wunderground/MMM-Wunderground.js actually exists?
                                          djsunrise19
                                          File exists! Config output (actually uncomment):
                                          	//	module: 'MMM-Wunderground',
                                          	//	position: 'top_right',  // This can be any of the regions.
                                          	//								// Best results in left or right regions.
                                          	//	config: {
                                          	//		// See 'Configuration options' for more information.
                                          	//		apikey: 'c4fbdf2a7b44d2bd', // private; don't share!
                                          	//		pws: 'NY/New_York',
                                          	//		//lang: 'DE',
                                          	//		fctext: '1',
                                          	//			fcdaycount: "5",
                                          	//			fcdaystart: "0",
                                          	//			hourly: '1',
                                          	//			hourlyinterval: "3",
                                          	//				hourlycount: "2",
                                          	//				alerttime: 10000,
                                          	//				alerttruncatestring: "english:" // truncate the alertstring ath this word//
                                            Any log available? At this point i have no clue why it would stall…
                                            • 6
                                            • 7
                                            • 2 / 7
