    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 244.6k Views 20 Watching
    • I Offline
      incubik
      I’ve tried to check the web inspector but when the screen is white… problems ahead —> The web inspector doesn’t pop up.
      I’ve tried this without installing the PIR Sensor module and the web inspector works but again when the screen is in “white mode” doesn’t.
      Any thoughts?
      paviroP 1 Reply Last reply Reply Quote 0
      • paviroP Offline
        paviro @incubik
        @incubik try the serveronly mode (see the wiki) :)
        We're all stories in the end. Just make it a good one, eh?
        – The Doctor
        • IngmarSwartI Offline
          IngmarSwart
          First of all: @paviro, many thanks for this module.
          I ran into some troubles with the module and thought I should share this (and my solution) here.
          Problem:
          Without the PIR module, everything worked as it should. After installing the PIR module, everything appeared fine and the (HDMI) monitor switched off after a given amount of time (set via a variable resistance on the sensor itself). Upon motion detection by the PIR, the monitor switched back on but didn’t display anything (I could tell the monitor was on from the backlight). Remote access via ssh was not affected.
          In the end, I figured out that this was due to an incorrect setting of the virtual terminal. Typing ‘sudo chvt 9 && sudo chvt 7’ on the remote terminal brought the image back to the monitor connected to the RasPi. After stopping the mirror, modifying the ‘activateMonitor’ function in ‘node_helper.js’ as below, and restarting the mirror, the problem was solved. I hpe this is helpful to others.
          Modified section of ‘node_helper.js’:
          activateMonitor: function () {
              if (this.config.relayPIN != false) {
                gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
              else if (this.config.relayPIN == false){
                exec("/opt/vc/bin/tvservice -p", null);
                exec("/usr/bin/sudo /bin/chvt 9 && /usr/bin/sudo /bin/chvt 7 ", null);
          PS: There may be more elegant solutions to this, but I my node.js skills are, shall we say, limited?
          • paviroP Offline
            paviro @IngmarSwart
            @IngmarSwart could you explain what setting this changes? And may open a pull request? Is this only possible with sudo?
            Please also note: Use Markdown on code snippets so it is easier to read!
            – The Doctor
              IngmarSwart
              @paviro, if I understoof the documentation correctly, the command chvt simply changes the foreground terminal. It appears that in my case the the output of the RasPi is send to another terminal than that is displayed on the monitor.
              My apologies for not using the markdown code. I only recently started using GitHub etc, so I have some learning to do when it comes to opening pull requests.
              I just tested to confirm if the use of sudo is required. Unfortunately, it is.
              • paviroP Offline
                paviro @IngmarSwart
                @IngmarSwart Strange that you have this issue, since I do not. I only have the problem when the monitor is disabled via a relay while the Pi boots.
                Could you do some more research on why this is happening and maybe find a way to fix it without root rights?
                – The Doctor
                IngmarSwartI 1 Reply Last reply Reply Quote 0
                  IngmarSwart
                  @paviro, I also don’t understand where it comes from, especially since the MagicMirror appears as it should immediately after boot. At first glance, the monitor (Philips 273V5L) and Pi seem to play nice: EDID information is correct, tvservice -s gives the native resolution and refresh rate of the monitor. If I can find some time, I will look into it. However, I am also quite earger to start playing with your Facial-Recognition module… :relaxed:
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    This is more of a PSA than anything else, but particularly since the tvservice is part of the rPi’s firmware. While running 'sudo apt-get update && sudo apt-get upgrade' will upgrade your rPi’s packages and firmware, it may not be the latest version. For most, this is okay. But if you’re like me, who likes to live on the bleeding edge of things, particularly when something isn’t working right, running 'sudo rpi-update' separately will update the firmware only, including binaries such as 'tvservice' since they’re part of the firmware, not just a standard package (in fact, you can’t find it as a stand alone package through 'apt-cache'.)
                    Use at your own risk. :)
                    • W Offline
                      witschi87
                      I’m getting the following error:
                      start-magic-0 (err): WARNING! Could not find config. Please create one.
                      start-magic-0 (err): App threw an error when running [Error: Module version mismatch. Expected 47, got 48.]
                      start-magic-0 (err): [Error: Module version mismatch. Expected 47, got 48.]
                      I’ve just cloned the git repository and installed the dependencies.
                      And that is my config:
                      	module: 'MMM-PIR-Sensor',
                      		sensorPIN: 22,
                      		powerSaving: true
                      • paviroP Offline
                        paviro
                        Please use Node v5 not v6 one of the dependencies is not yet ready for v6.
                        – The Doctor
                        KirAsh4K 1 Reply Last reply Reply Quote 0
                        • W Offline
                          witschi87
                          Can you tell me how to do that, please?!
                          • paviroP Offline
                            paviro
                            First Google result when searching for downgrade node to v5 :)
                            Also do not forget to execute npm installand if that does not work reinstall the module from GitHub after you downgraded.
                            – The Doctor
                            J D 2 Replies Last reply Reply Quote 0
                            • KirAsh4K Offline
                              KirAsh4 Moderator @paviro
                              @paviro, but but but … @MichMich said … he said … he said node 6.1.0 is now supported. Dependencies be damned, they need to catch up.
                              MichMichM 1 Reply Last reply Reply Quote 0
                              • MichMichM Offline
                                MichMich @KirAsh4
                                @KirAsh4 Yeah, MM supports Node 6.1.0 @paviro apparently still live in the stone age with his modules … 😈
                                • KirAsh4K Offline
                                  KirAsh4 Moderator @MichMich
                                  @MichMich, I have a laser … let’s tie him up and put his hand under the beam. That’ll teach him!
                                  • MichMichM Offline
                                    MichMich
                                    He is from the stone age. He doesn’t know what a laser is. 😱
                                    • KirAsh4K Offline
                                      KirAsh4 Moderator
                                      • paviroP Offline
                                        paviro
                                        Ha, ha :laughing:
                                        Will change my dependencies when I have some spare time.
                                        – The Doctor
                                        • P Offline
                                          Patrick
                                          At first: Thank you very much.
                                          This module is great and works fine for me.
                                          When it’s allowed to make some suggestion…
                                          you maybe could add a possibility to switch wireless sockets.
                                          The effort for this shouldn’t be much, when you can use xkonni’s remote control.
                                          https://github.com/xkonni/raspberry-remote
                                          This would be a great possibity for those, who don’t feel comfortable to use a 230V relais… (I studied Mechatronics, so i don’t care :P)
                                          • paviroP Offline
                                            paviro
                                            Feel free to send a pull request! :)
                                            – The Doctor
                                            • 6
                                            • 7
                                            • 3 / 7
