    Docker Container
    Scheduled Pinned Locked Moved Feature Requests
    5 Posts 3 Posters 6.3k Views 3 Watching
    • K Offline
      Kukielka58
      Hey there!
      I was thinking about a way to easily host MagicMirror and display the webpage on any device in the home network.
      First thing that came to my mind, why not a Docker container for the Server-Only application?
      Would be a really smooth way to host magicmirror on say… a homeserver, and use a rpi zero or any other network capable device to display the webpage in kiosk mode.
      Let me know what you think! :)
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Kukielka58
        @Kukielka58 there will be docker support in the next version
        https://github.com/MichMich/MagicMirror/pull/673
        • K Offline
          Kukielka58 @strawberry 3.141
          @strawberry-3.141 well, that was unexpected… Good for me tho!
          Thanks alot! :)
          • karsten13K Offline
            karsten13
            trying to work with docker after the release of MM v.2.1.1.
            The documentation says to start docker with:
            docker run  -d \
            			--publish 80:8080 \
            			--restart always \
            			--volume ~/magic_mirror/config:/opt/magic_mirror/config \
            			--volume ~/magic_mirror/modules:/opt/magic_mirror/modules \
            			--name magic_mirror \
            That doesn’t work, so google helped and this is working:
            docker run  -d \
            			--publish 80:8080 \
            			--restart always \
            			randyramsaywack/magicmirror
            Now docker ps tells me that all is running but i can’t see the site in my browser.
            I tried localhost:8080 and localhost:8183, doesn’t work.
            The documentation says to update the config with the Docker Host IP address.
            So I tried to get this with
            # As of Docker v1.3 you can attach to a bash shell
            docker exec -it  2e23d01384ac  bash
            # That drops you into a bash shell then use the 'ip' command to grab the addr
            root@2e23d01384ac:/# ip add | grep global
                inet 172.17.0.1/16 scope global eth0
            but inserting this in whitelist still doesn’t work.
            May someone here knows what I’m doing wrong …
            Thanks,
            Karsten.
              karsten13
              Update: I found no valid mm container in the docker store.
              You can build your own docker image locally with
              docker build -t magic_mirror .
              and run it with
              docker run  -d --publish 8080:8080 --restart always --volume ~/magic_mirror/config:/opt/magic_mirror/config --volume ~/magic_mirror/modules:/opt/magic_mirror/modules --name magic_mirror magic_mirror
              and open it in your browser with
              http://localhost:8080/
              Be aware of this issue.
              Karsten.
