    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 202.3k Views 22 Watching
    • paviroP Offline
      paviro @CGabo
      @CGabo glad you find it useful :)
      We're all stories in the end. Just make it a good one, eh?
      – The Doctor
      foxF 1 Reply Last reply Reply Quote 0
        jagerpower @CGabo
        @CGabo Thank you, i just installed it to my MM.
          jagerpower
          @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
          here is my config:
          module: 'MMM-Wunderlist',
                                 position: 'top_left',  // This can be any of the regions. Best results in left$
                                 header: 'Wunderlist', // This is optional
                                 accesToken: '----',
                                 clientID: '----',
                                 lists: ["inbox"],
                                 interval: 60,
                                 fade: true
          Note from admin: Please use Markdown on code snippets so it is easier to read!
          paviroP 1 Reply Last reply Reply Quote 0
          • paviroP Offline
            paviro @jagerpower
            @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
            – The Doctor
              jagerpower @paviro
              @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
              • C Offline
                CGabo
                @jagerpower
                Interval: 60 is for refresh all 60 min. You can also restart mm.
                If it’s still nothing, try the curl command which paviro provided 3 days ago.
                • paviroP Offline
                  paviro @jagerpower
                  @jagerpower alt cmd I
                  – The Doctor
                    jagerpower @CGabo
                    @CGabo @paviro when i run the curl command everythings seems right execpt for "public":false is this normal?
                    • paviroP Offline
                      paviro @jagerpower
                      @jagerpower yes. Have you changed the interval?
                      – The Doctor
                        jagerpower @paviro
                        @paviro yes i changed the interval to 1 but it didn’t help
                        • paviroP Offline
                          paviro @jagerpower
                          @jagerpower checked the Web inspector?
                          – The Doctor
                            jagerpower
                            @paviro no i didn’t do that yet but where do i use cmd alt i? in the terminal? and i use a windows keyboard, does this matter?
                            • C Offline
                              CGabo
                              @jagerpower
                              https://developers.google.com/web/tools/chrome-devtools/iterate/inspect-styles/shortcuts?hl=en
                                jagerpower @CGabo
                                @CGabo @paviro alt text
                                • paviroP Offline
                                  paviro @jagerpower
                                  @jagerpower check the log not the element should be another tab.
                                  – The Doctor
                                  • C Offline
                                    CGabo
                                    @jagerpower You find it under “Console”
                                    Btw. changing the interval to 1, I wouldn’t recommend. It pulls the data every 1 sec, leave it to 60 (default) . I personally increased it to 3600 (1h).
                                      jagerpower
                                      • paviroP Offline
                                        paviro @jagerpower
                                        @jagerpower are there any log after that from the module?
                                        – The Doctor
                                          jagerpower @paviro
                                          @paviro alt text
                                          • paviroP Offline
                                            paviro @jagerpower
                                            @jagerpower toggle the array that’s logged by the module anything in there?
                                            – The Doctor
                                            • 6
                                            • 2 / 6
