    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 193.9k Views 22 Watching
    • paviroP Offline
      paviro @laknermi
      @laknermi then set it to http://localhost I thought it was the default.
      We're all stories in the end. Just make it a good one, eh?
      – The Doctor
      laknermiL 1 Reply Last reply Reply Quote 0
      • laknermiL Offline
        laknermi @paviro
        @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
        • laknermiL Offline
          laknermi @laknermi
          @laknermi "@paviro
          Referencing my post for posterity
          I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
          paviroP 1 Reply Last reply Reply Quote 0
          • paviroP Offline
            paviro @laknermi
            @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
            – The Doctor
            • laknermiL Offline
              laknermi @paviro
              @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
              • paviroP Offline
                paviro @laknermi
                @laknermi glad you like it :slight_smile:
                – The Doctor
                  jagerpower
                  @paviro I reinstalled my MM and it works now. Thank you for this module
                  • Wilco89W Offline
                    Wilco89
                    Looks like i’ve got same issue,
                    tried the Curl line you said before, that gives me the info tht is is all correct.
                    but nothing shows up.
                    • Wilco89W Offline
                      Wilco89
                      Seems to work after a second npm install.
                        mikmonken
                        Hi, i’m having some problems with this too.
                        tokens and client ID are generated, and wanderlist appears on my mirror but non of this list content.
                        and when i run the curl command i get this.
                        {“error”:{“type”:“server_error”,“translation_key”:“api_error_unknown”,“message”:“An unknown server error occurred”,“authentication”:[“missing”]}}
                        i am a complete novice and just trying to follow instructions, but i’ve clearly messed up somewhere.
                        Access token and client id are taken as the values that are labelled just that.
                        heres what i have in my config.js ££££ have replaced numbers
                                                module: 'MMM-Wunderlist',
                                                position: 'left',  // This can be any of the regions. Best results in left or right regions.
                                                header: 'To Do', // This is optional
                                                        accessToken:    '07ad3c20bb0500b£££££££££££££££££a759b6a7e07da2',
                                                        clientID:       'f1££££££££££££££££££1eb',
                                                        lists:          ["Inbox"],
                                                        maximumEntries: '60',
                                                        interval:       '1',
                                                        fade:           'true',
                        any help would be really appreciated.
                        Note from Moderator: Please use Markdown on code snippets for easier reading.
                        • 6
                        • 7
                        • 8
                        • 11
                        • 12
                        • 6 / 12
