    Calendar shows "no entries" after MM Update
    37 Posts 12 Posters 31.9k Views 16 Watching
    • tgeimerT Offline
      tgeimer @Mitch1138
      @Mitch1138
      You have changed your ORDINAL_BASE to 1900, but it seems as if you have dates even before 1900 in your calendar as it tells you in line 2 of the exception:
      Error: dates lower than Mon Jan 01 1900 00:00:00 GMT-0500 (EST) are not supported
      What kind of calendar is it? Try to change the year to something even lower or even 0. Otherwise you can perhaps guess based on your calendar which entry might cause this error and change that recurring date…
      • Mitch1138M Offline
        Mitch1138
        Excellent, changing the date to 1000 fixed it. It is a google calendar, but I have synced with outlook, iphone, etc. so are probably some odd dates and trash squirreled away.
        Thanks very much
          jasondreher
          @Mitch1138 said in Calendar shows “no entries” after MM Update:
          tgeimer’s
          tgeimer’s fix worked for me too!! Thank you!
            DazDavid
            @tgeimer
            You are awesome!
            I was looking for a solution since I´ve updated MM but only now when I got the error message with the date 1970 I was able to find that thread and your solution. Now is working again. Thank you very much.
              Befkef
              So I’ve set the date to 1000… And even the beautiful year 0, but the only entry it shows is 1 entry which isn’t due in over 5 months… The calendar is very important for me so can anyone please help me!! Thnx in advance!!
                Mykle1 Project Sponsor Module Developer @Befkef
                @Befkef
                See the 28th and 29th post in this topic
                  STH
                  @tgeimer
                  Thanks for your solution! Saved my day ;)
                  • 4 / 4
