    Calendar shows "no entries" after MM Update
    37 Posts 12 Posters 35.1k Views 16 Watching
    • tgeimerT Offline
      tgeimer
      I am experiencing the same issue since the update to the current MM version 2.1.1 . I should have checked for issues beforehand :-/
      EDIT: I have all my calendars on my owncloud on the same LAN. All of them work fine except a calendar with all birthdays.
      Since I have no time to troubleshoot myself for the next month, I will have to wait for an official fix…
      Let’s make MM great again ;-)
      tgeimerT 1 Reply Last reply Reply Quote 0
      • tgeimerT Offline
        tgeimer @tgeimer
        I fixed my issue. Some searching led me to this:
        https://github.com/MichMich/MagicMirror/issues/791#issuecomment-289306407
        No dates before 1970 are accepted - but in my birthday calendar I have created birthdays e.g. in 1946…
        Thank you @amcolash
        This is how you can check if this is why your calendar is not working:
        ssh to your pi
        cd /home/pi/MagicMirror
        DIAPLAY=:0 npm start dev
        If you see this in the output, you have dates in your calendar before 1970:
        Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported
            at Object.toOrdinal (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:105:15)
            at Iterinfo.rebuild (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:1409:35)
            at RRule._iter (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:978:10)
            at RRule.between (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:794:21)
            at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:122:24
            at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
            at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
            at emitTwo (events.js:106:13)
            at Request.emit (events.js:191:7)
            at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
        What I did to fix my birthday calendar: Edit this file
        Go to line 56 or search for the first occurance of “ORDINAL_BASE” and change this line:
        ORDINAL_BASE: new Date(1970, 0, 1),
        set it to a lower year like 1900.
        Then restart your magic mirror (pm2 restart mm)
        And it’s (hopefully) GREAT AGAIN :-D :clap:
          sacha81 @tgeimer
          @tgeimer for me thats working THANK YOU !!!
          • Mitch1138M Offline
            Mitch1138
            I tried tgeimer’s fix (many thanks by the way), but without success. Of two calendars, only one displays. Here is the terminal output:
            Whoops! There was an uncaught exception…
            Error: dates lower than Mon Jan 01 1900 00:00:00 GMT-0500 (EST) are not supported
            at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
            at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1081:10)
            Dave
            • tgeimerT Offline
              tgeimer @Mitch1138
              @Mitch1138
              You have changed your ORDINAL_BASE to 1900, but it seems as if you have dates even before 1900 in your calendar as it tells you in line 2 of the exception:
              What kind of calendar is it? Try to change the year to something even lower or even 0. Otherwise you can perhaps guess based on your calendar which entry might cause this error and change that recurring date…
                Mitch1138
                Excellent, changing the date to 1000 fixed it. It is a google calendar, but I have synced with outlook, iphone, etc. so are probably some odd dates and trash squirreled away.
                Thanks very much
                  jasondreher
                  @Mitch1138 said in Calendar shows “no entries” after MM Update:
                  tgeimer’s
                  tgeimer’s fix worked for me too!! Thank you!
                    DazDavid
                    @tgeimer
                    You are awesome!
                    I was looking for a solution since I´ve updated MM but only now when I got the error message with the date 1970 I was able to find that thread and your solution. Now is working again. Thank you very much.
                      Befkef
                      So I’ve set the date to 1000… And even the beautiful year 0, but the only entry it shows is 1 entry which isn’t due in over 5 months… The calendar is very important for me so can anyone please help me!! Thnx in advance!!
                        Mykle1 Project Sponsor Module Developer @Befkef
                        @Befkef
                        See the 28th and 29th post in this topic
                          STH
                          @tgeimer
                          Thanks for your solution! Saved my day ;)
