    Update says to "commit your changes or stash them before you can merge." ?
    26 Posts 8 Posters 44.5k Views 8 Watching
      Richard238
      pi@raspberrypi:~/MagicMirror $ git pull && npm install
      Updating 8010e62..1a2b4f8
      error: Your local changes to the following files would be overwritten by merge:
              css/main.css
              modules/default/calendar/calendar.js
              modules/default/compliments/compliments.js
              modules/default/newsfeed/newsfeed.js
              modules/default/weatherforecast/weatherforecast.js
      Please, commit your changes or stash them before you can merge.
      Aborting
      How do I do this, please?
        bluecaka69 @Richard238
        @Richard238 following have the same issues
        • yawnsY Offline
          yawns Moderator
          This is why you should not modify the default modules and css/main.css … treat them as “system files” and don’t touch.
          Option 1 - save your changes, remove them temporary to do the update and apply them afterwards
          Risk is, that your own changes could interfere with changes provided by the update.
          git stash
          git pull
          git stash pop
          npm install
          Option 2 - remove all changes
          git reset --hard
          git pull
          npm install
          R P B 3 Replies Last reply Reply Quote 1
            Richard238 @yawns
            @yawns
            I don’t quite understand.
            Main.css - I don’t know what I’ve changed, I’ll have a look later.
            compliments.js Well, OK, I can re-write those.
            calendar.js / newsfeed.js / weatherforecast.js
            These have to be changed to pull in your calendar, your choice of news, your choice of weather, don’t they?
            yawnsY 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator @Richard238
              @Richard238
              No, there is no need at all to change these files.
              next to main.css you find custom.css, there you can add any css styles which will override existing styles.
              To add compliments, calendars, newsfeeds and forecast you set your values in config/config.js.
              This way you don’t lose your changes :)
                Richard238 @yawns
                @yawns Ok, thanks. I’ve some work to do there then!
                  Richard238
                  Lost and confused already.
                  How much of calendar.js needs to be copied to config,js?
                  johnnyboyJ 1 Reply Last reply Reply Quote 0
                  • johnnyboyJ Offline
                    johnnyboy @Richard238
                    @Richard238 said in Update says to “commit your changes or stash them before you can merge.” ?:
                    About this much…
                    			module: 'calendar',
                    			header: 'My Family Home Calendar',
                    			position: 'top_right',
                                                     maximumEntries: 13,
                                                     maximumNumberOfDays: 365,
                                                     maxTitleLength: 25,
                                                     animationSpeed: 0,
                                                     fadePoint: 3,
                                                     timeFormat: 'absolute',
                                                     urgency: 7,
                                                     getRelative: 0,
                    						symbol: 'calendar-check-o ',
                    						url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
        symbol: `calendar-check-o `,
        url: "https://calendar.google.com/calendar/ical/mydetails.co.uk/private-mydetails/basic.ics"
                    			module: 'compliments',
                      Richard238 @johnnyboy
                      Ok, these are done and no longer an issue, hurrah!:grinning:
                          css/main.css
                      Can’t get
                      into config.js though.
                      			module: 'calendar',
                      			header: 'Calendar',
                      			position: 'top_left',
                                          maximumEntries: 8, // Total Maximum Entries
                                          displaySymbol: true,
                                          defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                          displayRepeatingCountTitle: false,
                                          defaultRepeatingCountTitle: "",
                                          maxTitleLength: 25,
                                          fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                          animationSpeed: 2000,
                                          fade: true,
                                          urgency: 0,
                                          timeFormat: "absolute",
                                          dateFormat: "ddd Do MMMM",
                                          getRelative: 2,
                                          fadePoint: 0.25, // Start on 1/4th of the list.
                                          hidePrivate: false,
                      						url: 'https://calendar.google.com/calendar/ical/PRIVATE_KEY/basic.ics'
                      			module: 'calendar',
                      			header: 'Binday',
                      			position: 'bottom_left',
                                          maxTitleLength: 25,
                                          fade: true,
                                          urgency: 0,
                                          getRelative: 2,
                                          hidePrivate: false,
                      						symbol: 'pagelines ',
                                      titleReplace: {
                                      //	"'s birthday": "",
                                      //	"Recycling": "Bins",
                                          "Red Bin": "Red and Black Bins",
                                          "Green Bin": "Green and Black Bins"
                      What have I missed?!
                      Thanks.
                      • yawnsY Offline
                        yawns Moderator
                        At least there is a single comma missing after the closing ] of your calendars entry
                          Richard238
                          @yawns Brilliant! A comma after each of the ] seems to have fixed it.
                          Thank you.
                            Richard238
                            		module: 'calendar',
                            		header: 'Calendar',
                            		module: 'calendar',
                            		header: 'Binday',
                            With two calendars, how do I get different icons / icon colours again in custom.css?
                             .calendar .fa.fa-calendar-check-o {
                              color: #00d2FF /* 55=Green FF=Blue*/
                             .calendar .fa.fa-trash-o  {
                              color: #C97F7F; /* Brown */
                            • strawberry 3.141S Offline
                              strawberry 3.141 Project Sponsor Module Developer @Richard238
                              @Richard238 you can use the module identifier for it as it is unique
                              #module_7_calendar .fa.fa-calendar-check-o {
                              #module_8_calendar .fa.fa-calendar-check-o {
                              the number is the index of the entry in your config starting at 0
                              e.g.
                                {module: "A", position: "top_right"}, //index: 0
                                {module: "B", position: "top_right"}, //index: 1
                                {module: "calendar", position: "top_right"}, //index: 2
                                Richard238
                                Ok, like this?
                                			module: 'alert',   # Module 0
                                           module: "MMM-MyTemps",  # Module 1
                                            header: "Home Sensors",
                                            position: "bottom_right",
                                                host: "192.168.1.41",
                                                path: "/temp2mcf.php?format=json",
                                                reloadInterval: 2 * 1000   //2 seconds
                                			module: "updatenotification",  # Module 2
                                			position: "top_bar"
                                			module: 'clock',   # Module 3
                                			module: 'calendar',  # Module 4
                                . … …And second calendar = # Module 5
                                making the custom.css look like this:
                                 #module_4_calendar .fa.fa-calendar-check-o {
                                  #module_5_calendar  .fa.fa-trash-o  {
                                  @Richard238 yes this should colorize the calendar icon fa-calendar-check-o in your first instance and fa-trash-o in your second.
                                    Richard238
                                    This post is deleted!
                                      @Richard238 check the part between calendar and compliments module
                                        Richard238 @strawberry 3.141
                                        @strawberry-3.141 I’ve no idea what I’m looking for, sorry…
                                          Richard238
                                          Just tried the default sample config.js, and that doesn’t work either!
                                            @Richard238 you pasted the start function into your config file, but if the config sample doesnt work either your problem is somewhere else
