    MLB Standings...
    Scheduled Pinned Locked Moved Sport
    30 Posts 6 Posters 26.5k Views 7 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Flip357
      @Flip357 LOL
      • P-Bo726P Offline
        P-Bo726
        I can’t seem to get this module to work. I get a black screen where the module should be. Here is my config file:
        			  module: 'MMM-MLBStandings',
        			  position: 'bottom_center',
        				email: "------@gmail.com",
        				maxWidth: "100%",
        				header: true,
        				confdiv: true
        I did another git pull but still have the same problem.
          cowboysdude Module Developer @P-Bo726
          @P-Bo726 Did you just copy the config and paste into your config.js file?
          Also did you run ‘npm install’? I’m betting you didn’t because I see I didn’t include that instruction in the readme! [I updated that!! Thank you!!!]
          At any rate in a terminal window go to:
          ~MagicMirror/modules/MMM-MLBStandings
          type: npm install
          Then re-run your mirror.
          • P-Bo726P Offline
            P-Bo726
            Yes, I copied it from the readme file. I just copied it again and used a different email address but same result. I ran ‘npm install’ from modules/MMM-MLBStandings directory also but am getting same result.
              What mirror version are you using? My guess is there’s a conflict… so when you run your mirror see what errors you are getting.
              I wouldn’t keep copying it. I would delete the directory totally and start over.
              • P-Bo726P Offline
                P-Bo726
                Sorry, user error! I resolved it. I had some misplaced brackets I needed to reposition. Thanks for your quick response and for building a cool module.
                  @P-Bo726 Thank goodness it was something easy… :) Usually is.
                  You’re welcome! Glad you like it! It was a labor of love for sure…
                  • P-Bo726P Offline
                    P-Bo726
                    Would you have any interest in creating a similar module for NFL standings? Here is some information related to the NFL Standings API.
                    NFL Standings API
                    cowboysdudeC 1 Reply Last reply Reply Quote 1
                      @P-Bo726 I will take a look at it … :)
                      cowboysdudeC 1 Reply Last reply Reply Quote 2
                        cowboysdude Module Developer @cowboysdude
                        Sorry guys I just haven’t had time to even look at this… I’ll get to it… :)
