Total Noob - Successful Install on a Pi 3 B - How do I open it?
Put a tick before you paste it and at the end of the paste. The tick is your TILDE key (without shift)
magicmirror@2.1.1 start /home/pi/MagicMirror
sh run-start.shStarting MagicMirror: v2.1.1
Loading config …
Loading module helpers …
Initializing new module helper …
All module helpers loaded.
Starting server on port 8080 …
Starting server op port 8080 …
You’re using a full whitelist configuration to allow for all IPs
Server started …
Starting module: newsfeed
Sockets connected & modules started …
Launching application.
Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml -
for future people who stumble here:
“npm start” was what I was missing to get things started upI had a weird black electron pop up - realized it was a config file issue - for mine it ended up being a random address in the “address” section above the ipwhite list.
Thanks to Mykle for the help!
