    Problem with Weather Underground Forecast
    19 Posts 3 Posters 12.8k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @xeroxu
      @xeroxu said in Problem with Weather Underground Forecast:
      There must be something wrong with the apikey. iI try it with the wuforecast module, and here also nothing show up.I have free Membership and choose the anvil plan. Have I to make big changes in the weatherunderground.js? I put in my API and Location pws.
      You shouldn’t make any changes in the MMM-WunderGround.js file. Only make changes to the config.js file. If you have made changes to your MMM-WunderGround.js file then I suggest you revert them. If you can’t remember exactly what you changed then it would be easier for you to delete the entire folder and git clone https://github.com/RedNax67/MMM-WunderGround.git into your ~/MagicMirror/modules/ directory. Then add this to your config.js file, entering your WunderGround API key exactly and your pws
      		disabled: false,
          	module: 'MMM-WunderGround', // Just for forecast w/css entry
          	position: 'top_right',
              apikey: 'YOUR_API_KEY', // private; don't share!
              pws: 'pws:YOUR_PWS', // Richmondtown Weather Station - Very Cool
      		currentweather: 0,
              coloricon: true,
              hourly: '1',
              fctext: '1',
              fcdaycount: "10",
              fcdaystart: "0",
              hourlyinterval: "2",
              hourlycount: "1",
      		animationSpeed: 5000,
              alerttime: 10000,
              alerttruncatestring: "english:",
          	roundTmpDecs: 0,
          	UseCardinals: 1,
          	layout: "vertical",
      		windunits: "mph",
          	sysstat: "0"
      That should get you this:
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xeroxu @Mykle1
        @Mykle1 Thank you Mykle1,now it work,now i hve to make the colour and Icon configuration, the Earth did net not show up but thats no bi deal you helped me so much. I stil got a nothe Problem with the startuo I have to Fix , maybe Ill find the Answer here in the Forum.
          You’re welcome. You are not going to see the earth as part of WunderGround. That is another module I am working on. It’s giving me some trouble right at the very end and I can’t seem to solve it.
          You may also want to change this in your config.js file
          currentweather: 0, Change the 0 to 1
          What is your problem with startup?
          • X Offline
            xeroxu @Mykle1
            @Mykle1 Each Time I starr reboot my Rasberry 3 chromium starts and says that he is not been close7 right before shutdown (cant explain it in english) but I found nothing in an atutostart.
              @xeroxu
              Are you running MM in Kiosk mode?
              • X Offline
                xeroxu @Mykle1
                @Mykle1 where can I see that.sorry I saw it too late that you where on the chat
                  @xeroxu
                  Some people set up chromium to autostart in Kiosk mode. That is why I asked.
                  • X Offline
                    xeroxu @Mykle1
                    @Mykle1 Thank you you also ssolve this problem, It I s great to know that here are People that can help you so fast, :clap:
                      @xeroxu
                      You’re welcome. Glad I could help you. Have fun! :thumbsup_tone1:
